How to repair a zoom telephoto lens and mount it on your DSLR camera by tholopotami
Featured
Telephoto lenses are expensive  and if you have  one intended for an older SLR camera, you may consider  using it with with your DSLR. My experience is that this is doable but there are a few critical issues that you have to deal with.
Contemporary DSLR cameras are rather unfriendly  to older lenses for different reasons such as the lens-sensor distance , the mounting mechanism or even the camera software.
It is important  to mount the old lens on the camera at the precise distance without damaging the internal parts..
In this instructable I'll show you how this can be done by a specific example using common tools and materials.
I picked this used and damaged telephoto from a street market.  It was a zoom 80-200mm F/4.5, ~400gr weight, with the  JCPenney  (an American multistore) brand on it  and the sign "made in Japan" . Even at its own time it would be inferior compared to those made by Yashica, Nikon or Vivitar with similar specifications.
It was practically separated in two and full of dust, but the external lenses did not seem to have any scratches. Initially I intended to remove the lenses for other uses but looking at it more carefully I realized that the mechanical problems could be fixed.
The challenge was to repair it and mount it on my Olympus E-420.
Step 1: Preliminary steps
Regardless if your lens needs repair or not,  this is what you have to do first:
Find out the camera-lens distance
  1. Attach the camera on a tripod and remove its own lens. Holding the telephoto with both hands in front of your camera with the setting of the telephoto at infinity, try to focus a very distant object. If you have a problem to keep the lens to the correct position use a paper inner tube but do not touch the internal parts of your camera.
  2. Rotate the focusing ring a few degrees and focus again. In the final construction it is better to set the infinite point a few degrees before the rotation limit. This will allow sharp focusing by leaving some space around the correct point.
  3. Focus on close objects. Try to find the minimum focusing distance available. In my case the distance  measured  was 1.7 meters at 200mm and 1.5 at 80mm.
Find/purchase the appropriate adaptor
A T-ring is the best type of adaptor for this work. It offers two possibilities for mounting a lens, either by using the 42M threading of the internal ring  or by removing the ring and fitting the tube on the main connector directly. The one shown here is the Olympus Four-Thirds T-ring for DSLRs which has a bayonette type mounting.
crazyg says: May 6, 2011. 12:19 PM
just reassembled a lens of that type from a camcorder,want to make a shift tilt lens for slr,so far no focus on near or far,any dismantling the handycam was fun,i like your diagram
tholopotami (author) says: May 6, 2011. 1:47 PM
Sorry that you did not manage it yet. Let it aside for a while and think again. These things need patience!
craighanson says: Oct 30, 2010. 11:08 AM
Vary Impressive As A action Photographer I enjoyed This article
tholopotami (author) says: Oct 30, 2010. 12:39 PM
I am glad you did. As you see this lens results on soft photos compared to the crystal clear result of the new lenses intended for DSLR. However I enjoyed remaking this lens and at the end you have a nice feeling that you know this equipment inside out!
amclaussen says: Nov 26, 2010. 9:29 PM
Good Instructable...
your comment on the softness of your old Zoom lens is quite logical: in those old days a Zoom was very difficult to design and manufacture.
But NOT ALL old SLR lenses were soft; the best lenses of those years were even more detailed and precise than recent designs, no joke. You would be surprised to see better older lenses compared side to side to latest ones, unless, that is, you are comparing the VERY best of today lenses (like SOME but not all of the Canon "L" series) to old "L" series SLR lenses of around 1980's vintage.
Even when today Canon "L" lenses have Autofocus and some of them motion compensation, OPTICAL quality is NOT much improved, and in some cases, today some "L" series lenses are not up to the resolution and correction of older ones.
Now, compare the price of the better modern ones... you can purchase a new car for that kind of money! Another consideration is about the SPEED of today lenses: Young people think the 50 mm F 1:1.8 normal lens is very "fast" and good lens, (at least much better than the piece of junk of the "kit lens" sold with the Canon cameras, the cheaply made 18-55).
But older people like me know for shure the 50mm F1.8 was the cheap one in the 80's, because the 50mm F 1.4 was better built and better overall... and the
expensive 50mm F 1.2 L was a really extraordinary one, competing and slightly surpassing even the best German Leica 1.2 Noctilux, no less!
Now the surprise: Professionals have found the OLDER lens is not only much better built, more precise and has better materials than the actual 1.2 L; which has dissapointed some owners with Autofocus issues.
The plain truth is that both Nikon and Canon (and others) are now producing LESS than the best lenses possible, maybe because they want to have some "room for improvement", but they are concentrating their efforts more towards the electronics and sofware, than on the Optical quality of their lenses.
Soon, the sensors will continue getting better and better, and then the industry will be forced again to concentrate on Optical quality, but I seriously doubt they will return to the precise and durable construction of the 80's.
tholopotami (author) says: Nov 27, 2010. 8:09 AM
Thank you for the fruitful comment. I have also understood that contemporary lenses although they have more functionalities are not as clear as some older lenses. I have an example. I had CANON 1000F SLR with a 35-80/4-5.6 lens. Sometimes I substituted this with a LEICA 58/2 which was far superior. Speaking about this specific zoom 200of the instructable, I think its worse feature is the sooming part. It has two lenses that move independently on different paths and when you change the zooming , it slightly defocuses.
ax89 says: Nov 5, 2010. 7:46 PM
Good instructable, and something to think about. I spent over $4k in 1980 dollars buying Nikon lenses and now they are useless with dSLRs. I was so angry with Nikon that I bought a Canon.
amclaussen says: Nov 26, 2010. 9:55 PM
I say the Same... but for Canon!!!
My old Canon "New FD" lenses of the 80's, were made UNUSABLE in 90's Canon cameras, BY DESIGN! (INTENTIONALLY). They say it was made for technical reasons and blah blah blah, but the truth is other.
It is called "Planned Obsolescence" and is responsible for much of the waste and pollution damage caused to the planet, not to say the damage to our purse!
One thing is clear: Managers and engineers were not only good, but somewhat perverse: by redesigning the mount, they made the older lens unusable in newer cameras, just to keep people buying and throwing away perfectly good lenses, just to keep "updated with the latest model". It is the business model... I wonder how long that situation will be sustainable. But thanks to clever people at INSTRUCTABLES, we can have old things working again instead of making the trash mountain bigger!
tholopotami (author) says: Nov 6, 2010. 3:35 AM
I also have an SLR Canon and I have mounted several odd lenses on it through an M42 adaptor. I one case I had to remove the final ring of the lens (unscrewing) to gain some distance. If you have a nikon lense that is worth to be mounted on your Canon it may be possible through a T-ring adaptor because Canon has a smaller camera - lens distance. If I were you I would first google " nikon lenses to canon".
LittlestWorkshop says: Nov 4, 2010. 6:52 AM
I like your little organiser. I often use ice cube trays for the same purpose, I number them so that I can create a simple index if I need to when dismantling complex things.
tholopotami (author) says: Nov 4, 2010. 8:23 AM
This small tray has the advantage that you can cover it with a tape and store it , something I did often during the repair. However it should be made a little larger and with more compartments.
twoherbs says: Oct 29, 2010. 10:22 AM
Good use of older lenses and without breaking the bank account
tholopotami (author) says: Oct 29, 2010. 11:21 AM
Thanks!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
