loading
Step 4: Remove old elastic cord and Re-thread new cord
With your poles clear of old cord, push the the threader through the pole aperture. It should glide easily and once the threader is poking out the other end pull the threader through gently. Remember if this is difficult then you probably got too much sticky tape. Once through pull the threader through and continue to thread all the other poles.
Being frugal I use up the old elastic cord. The old cord can be used for lanyards and neck cords. I hung all my USB storage sticks up of the old cord.
<p>I use to have 5 patents on making tent poles specifically used in the Trade Show industry. I purchased over $1 million dollars worth of them over my 14 years. If you are going to use fiberglass ok but they are extremely heavy and will break. I suggest you go to REI (the company that gave me the name of the company I used in South Korea). You can cut them to any length and we used a 1/2&quot; drill mounted on a board, with a custom auto tamper drill that cost about $80 that is sized for each size of aluminum tubing your are using. It simply cuts inside and outside at the same time and complete finished the end of the tube to factory perfect standards... then just run your bungee through it. We used a Fruit Bag stapler, however they are not used any more, but you can use any thing that will hold the bungee such as a small washer tied that will hold the system together. Many aluminum end tips are available with different purposes about $1 each. I made molds and produced our own special design that had a hole through it to staple the bungee and then a bungee tampering to squeeze and hold the end inside the tube. It worked very well and after selling $14 mil of our 1-25 products we had to close after the 2008 bomb sell. If you are interested in how I started my company and moved it from a $14 investment to a $14 mil. sales revenue over 14 years... I am in the process of writing my book. If you would like an advance notice of the book please send your email to: Les@LesLaMotte.com</p>
<p>I just used fishing line or heavy thread and a heavy needle to go through the poles.</p><p>Simply thread the needle and drop it through the pole &amp; pull it out when it falls through the bottom. Go though all the poles one at a time, trailing the fishing line or thread. I connect each poles after I put the thread through. When you finish the last one, push the needle through the elastic cord near the end (like you are sewing), and tie a knot in the fishing line or thread (if you use fishing line tie a good fishing knot, it is slippery). Then pull the line from the other end and it will pull the cord through all of the poles. Rest of the directions from the instructable work fine</p>
Couldn't you sew the new cord to the old with a stitch or two, (after knot is removed) and then pull the other end of the old cord?
<p>ebay do a easy kit which comes with shockcord, threading steel and washers (tie behind so easy secure). Works well I don't tape but use pliers to pinch threading steel closed around shockcord. Ebay prices &pound;3.90 - &pound;5.00 depending on vendor includes postage UK. Enough cord and washers for 3 poles from family tent</p>
cool. very clever. <br>last time I had to restring poles I used a can of compressed air to blow the shock cord thru.
I use a different method, I take my shop vac and suck fishing line thru the poles and then pull the shock cord thru.
That's another interesting method...... <br> <br>I wonder if the fish line could work with just a small lead weight on it without the hoover and just drop the feeder line through the pole vertically. It may not be quick but useful approach with very limited resources at hand (i.e. no hoover or shop vac) <br> <br>Hopefully we will end up with quite a good list of various methods here with this article. <br> <br>Thanks for your input.
If it's a pipe, I find an easier way to thread anything through it is to get some string. <br />Put the string end at the pipe entrance and suck at the other end. The string should follow through unless it's damp/obstructed.
That's another interesting method! <br /> <br />Personally i wouldn't recommended sucking through an old glassfibre pole just for the glass splinters alone. <br /> <br />Aluminum poles OK.
About This Instructable
127,134views
73favorites
License:
More by chaoticandrandom:How to remove and re-attach LCD Ribbon from a PCB with a Fine Pitch How to repair an Xbox Remote Control - Decoupling Capacitor Fix How to repair tent pole elastic cord (Re-thread) - The Easy Way
Add instructable to:
