all you need is :
a soldering iron
a few micro switches
a screw driver
Remove these ads by
Signing UpStep 1OPEN THE PROCESOR
Remove these ads by
Signing Up| « Previous Step | Download PDFView All Steps | Next Step » |
All Steps Viewing
This transistor to replace, would one of these do the job...?
http://nz.farnell.com/jsp/search/browse.jsp?N=500005+1002733&Ntk=gensearch_001&Ntt=BC807-40&Ntx=
Do I have to solder in the new one? Who would I get to do that kind of thing? an electrician?
Many thanks
Russ
when i turn on the device, it keeps blinking.
Does anyone know how to fix this other than replacing the rotary control (what's the proper name btw?), if replacing is the only way could you tell me the spec required to buy the replacement?
i have change Q4 in my zoom g2,but it still keep on blinking,it does not work.
could someone help me?
Is your Zoom G2 working like new after replacing Q4?
im sorry if it took me years to find this comment of yours but im hoping that you can still reply to this comment.
after you had replaced your Q4, did your Zoom G2 worked again?
was Q4 the only one that needed replacement? i mean, no other damaged parts?
Thanks.
Please help
Hello all.
does anyone know what type of IC-10 (regulator IC)?
whether the output of this ic was 3.3 volts?
thank you
thanks
ken
Sorry for the lack of information in this area, the shops here are a little unevolved... and we don't speak english here so... sorry.
I have this unit from d past two yrs.
It has never worked well. The switches are too bad.I have spent a lot for its repair.
Now, I've got a new problem apart from switches.
I am not able to make patches. Whenever I turn the knobs of Gain, Tone & Level , the values doesn't change. Only 2 or 3 values keep coming like SL, 50,1.0 etc..
Any Suggestions Sir..... I would be highly thankful....
I'm trying to fix the "effect type" buttons but I can't get the PCB off. I don't understand how to unscrew the outputs, there are no screws?
