Sugru is great for fixing boots because:
- it bonds to most materials (including fabric and leather)
- is flexible when cured
- is waterproof
A perfect match for the great outdoors.
TIP 1: sugru is not suitable to repair your soles, we recommend that you use sugru for the uppers only.
TIP 2: sugru bonds to most but not all materials, we have seen people repair loads of different types of boots it is worth remembering that it might not bond to yours.
Remove these ads by
Signing UpStep 1Cracks and leaks to repair
I love the colorful repairs!
Thanks
Using a heat gun that generates heat about 500 degrees, blowing the two surfaces for a few minutes might (again- might) make the cement tacky. If it does, you will need to press the sole to the uppers until it cools in a minute or two. pressing the shoe against a cushion will help to envelope the sole to press it securely against the uppers.
Neoprene cement, which you likely obtained doesn't work with a lot of synthetics like urethanes, vinyls and thermoplastic rubbers. It's designed for leather and friendlier synthetics. Probably that is why yours soles did not attach.
Although there are variety cements for a shoe repairman to use that would be effective- your best bet might be to use cyanoacrylate, or super glue along with an activator that forces it to dry instantly. You will find that it does take experience and caution to restore your soles. You might have to glue it in increments, not everything in one shot.
Cheers for the challenge and the positive feedback
Thank again!
You could still use sugru to make the repair waterproof again...
Hope this helps
I've used sugru to fix a lot of plates and pots that had chips in them, and even a rusting hole on my bathtub. It works great for all sorts of repairs.
Next question: what IS a suitable material for the soles? I have a great pair of boots that could benefit from both material and sole repair.
I though that maybe tire rubber would be better and settled on bicycle tire. I went to my local bike shop and they gave me an old worn out tire. It is thin enough to easily cut with shears and it glues well with Shoe Goo. Give it a try.
It's a fairly versatile material in itself and has a lot of uses.
1. Have a scrap of leather of ANY size around. Once you have finished forming the patch where you need it and smoothed it out well, press the scrap of leather into the sugru firmly and evenly but not hard enough to displace any of it, and then peel it back off. This will leave a leather texture in the surface of the sugru and hopefully make it a little less conspicuous. This method will give the texture but might leave the sugru still a little more shiny than the rest of the boot.
2. Find some yarn that is the same color as your boot and with a SHARP pair of scissors, cut fibers from the end of the yard reducing it to the dustiest texture you can manage without cutting yourself. When your patch is done, dust the yarn fibers over the sugru and press them in JUST enough so they will stick and so you don't leave bumps or dents from your fingers. You may be able to find "flocking" materials if you have a large craft store in your area and not have to shred the yarn yourself. This method should take the shine out of the sugru but may not last as long as the other method, if the fibers are worn off.
Maybe the best solution would be a combination of both methods.
Hope this tip helps.
DC.
Thanks, guys!
