3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to replace a Laptop Screen
How to take an LCD screen off of a laptop and reconnect a new one.
When the screen on a laptop breaks, it can be a very intimidating problem indeed for those who have never taken a laptop apart in the past before,
In this Instructable i hope to dispel a part of that mystery in an effort to empower you so you can repair your own laptop next time it breaks.
Things you will need
a small phillips head Screw driver
a few small cups or containers (for the many screws on your laptop)
a small flat head screw driver (for the plastic clips on the top bezel)
and a Replacement screen ( the most expensive part, but if you look in craigslist you can get a broken laptop with a working screen fairly easy and replace your broken machine with the working parts from the other broken laptop)
or you can go through your laptop manufacturer to order a new screen. (usually not cheap)
One more note. by perfoming these actions you will be voiding your warranty assuming you have any left on the machine. if you do have a warranty on the machine, just send it out to the Depot and get it fixed for free.
if you have no more warranty then forget the above and get ready to get our hands dirty =D the laptops already broken any way what more can you do to it =P
also, before touching any circuits or any thing its good to ground yourself to dispel any static electricity you may have on you. so touch some bare metal Or if you have it pull out your anti static strap and make good use of it.
Step 1Pulling screws
pulling screws
start by flipping your laptop over and Removing the Battery and every screw on the screen side of your laptop (remember to pull the screws that are hiding Under the battery as well)
Then you will remove a keyboard screw which is normally in the middle of the laptop (it will commonly have a small image of a keyboard near it to make things easier for you)
the last thing we will do is disconnect the Wireless antenna wires.
On the HP dv9000 series the wireless card is kept under the same plate as the Memory which makes things easy for us since it gives us a little more room.
locate which little plate is hiding your wireless card (it doesn't hurt to open them all up and see what's under them all any way since this is a learning experience)
once you have located the card with the black and antenna wires snaking away from it Note which wire goes to which side of the card (I'm not sure how important it is to re attache them properly since their just clipped wires and they don't close any circuit but its good to re attache things the right way the first time haha)
OK now were ready to go to the top side of the laptop.
30 comments
Apr 27, 2012. 2:18 AMmadmans firework emporium says:
i replaced my screen and my wireless stopped working
Apr 27, 2012. 1:02 PMmadmans firework emporium says:
crap, would those be the 2 white ones?
May 1, 2012. 1:17 AMmadmans firework emporium says:
im screwed, i traced them to the source, the previous owner had re4placed the black one with a white one partway, it broke again, oh well, call on the duct 6tape
Mar 14, 2012. 2:55 PMiamphantom says:
How did you disassemble the hinges? My laptop has a plastic case around the outside of the screen like most do and the hinges are deep in a plastic hole. I cannot get to them and therefor cant remove the case. Any suggestions?
Jan 29, 2010. 11:30 PMANDY! says:
if hte screen plugs are the same, can u use that?
Dec 17, 2009. 7:29 PMbornecw says:
 Just a personal experience with this.  I was afraid I would crack the delicate plastic around the screen so I sent my laptop to a company in Houston.  They repaired it and sent it back very quickly.  It cost me about $100 plus shipping.  Their site is clb-llc.com/
Oct 11, 2009. 3:49 AMjv0010 says:
Great article.  I contacted these guys who also have phone support http://www.laptopscreensaustralia.com.au - they advised what the correct screen was and I also received it within 3 days.
Believe me, it is easy to fix these problems.
Apr 15, 2009. 5:23 AMphiluk2000 says:
Geat little article. The only problem generally people find is actually getting the replacement parts. Laptop manufacturers are stifflers for parts and for the less well known companies it's always difficult to source a good supply.
Phil.
http://www.stuckcomputer.co.uk
Sep 9, 2009. 12:51 PMRogerB says:
After some searching I found a site called www.nylaptopparts.com that offer replacement laptop screens and parts , pretty good pricing and service , I would just recommend anyone that wants to replace their screen to make sure that you feel you have the confidence or make sure to have the installation instructions before getting a part it will save you much headaches (like in my case - aaargh!) so with the help of this article and some instruction I had my screen installed within an hour.
Apr 16, 2009. 4:26 PMtomo pauk says:
Hi, fellas :) Perhaps off-topic, but I have a Compaq Evo N800v whose LCD displays only every second column of a picture. Any hints, like if this is LCD's fault, or the graphics card is to blame? The cable seems okay.
Apr 18, 2009. 11:19 AMtomo pauk says:
I forgot to say that, when I attach an external monitor, the picture there is okay. The problem with LCD remains all the way. Every even/odd column is "broken", while every column inbetween is okay. So, a pixel wide problem, not an inch wide.
Apr 6, 2009. 6:26 PMjj12305 says:
can you tell me how to back up your computer because i have the same one and is infected with viruses and i need lots of help(PS the taskbar or the blue line on the bottom is gon and all the short cuts are gone)
Feb 27, 2009. 12:20 PMlemonie says:
Come on now, the picture in step 5 is the same one you've used in step 2. What's going on here? L
Feb 27, 2009. 3:41 PMlemonie says:
Maybe you can just replace the one in 5 with the finished laptop at some point? L
Feb 28, 2009. 3:08 AMlemonie says:
Yea! Showing the desktop says "it's fixed" nice L
Feb 27, 2009. 2:36 PMPhil B says:
When you buy a used laptop for the screen, must it be for the same brand and same model of laptop; or can a screen for another laptop from another maker be used? If a screen for a different make and model were to be used, can it be put into the old screen case so the hinges fit?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Bernyk
im a young 21 year old guy who doesnt quite know where he wants to go in life and is in no rush to grow up haha.
