Another symptom is a "growling" sound from under the hood when turning the wheel.
Gosh, how much is this going to cost? Well, expect $200+ if you take it to the shop. This DIY repair cost less than $50.
Over the course of a vehicle lifetime, it will likely become necessary to replace or rebuild the power steering pump due to leakage. The power steering pump is a hardened pump, where the failure mode is normally fluid leakage around the gaskets and seals.
So which to do? A replacement or a rebuild? In my opinion, the power steering pump should be viewed as a line replaceable unit. Rebuilding will not be addressed in this instructable.
The pump replacement is easy to do once a few tricks are recognized. For example, do not attempt pump replacement without locating a power steering pump pulley puller. Using a standard pulley puller may make the pulley out of round -- not a good thing!
This paper outlines pump replacement on a 1987 Ford Thunderbird 3.8L V6. The original pump lasted more than 300,000 miles.
Expect Total Time to Repair around 4 hours.
Have fun, and be safe!
--Mark
http://www.marksatterfield.com
Remove these ads by
Signing UpStep 1Gather materials
1) Gather the materials
-- Instructable step 1 - This includes tools, a new pump, fluids, etc.
2) Remove the leaking pump
-- Instructable step 2 - Drain the Power Steering system
-- Instructable step 3 - Remove accessories from Power Steering system
-- Instructable step 4 - Remove the pulley and bolts
-- Instructable step 5 - Remove power steering pump
3) Install the new pump
-- Instructable step 6 - Place the new power steering pump
-- Instructable step 7 - Press on the power steering pump pulley
-- Instructable step 8 - Align the pulley and attach the belts
-- Instructable step 9 - Flush and fill the power steering system
4) Cleanup
-- Instructable step 10 - Cleanup
You'll need some tools to complete this task. Before you start, gather the necessary equipment -- you will not be able to use the car once you start the replacement! It is always a good idea to have a friend on call, or a second car available.
Equipment list:
- Power Steering pump (to replace defective pump)
- Two (2) quarts power steering fluid or appropriate ATF (to flush and fill). More than 2 quarts if flushing the rack is desired.
- Power Steering Pulley Puller set (to remove and attach the pulley). Some auto parts stores will loan the tool sets.
- Socket set.
- Open end wrench set (for use with puller set).
- Leverage pipe or extension bar (in case the pulley is hardened on the spindle).
- Drain pan (to drain & flush power steering system).
- Wheel bearing grease for sliding pulley on the pump hub.
- 2' wood 1x2 for assistance with aligning the pulleys. Any straight tool will work fine -- a level, metal rod, wood, whatever.
comments
Add Comment
bhunter736
says:
LancePenney
says:
Add Comment
