How to replace a valve stem
The other day my brother bought this civic from a local dealership. I checked the car in great detail on and off the lot and I discovered that the car had a bad valve stem on the spare tire.
Warning:
Some vehicles are equipped with tire pressure monitoring system (TPMS). The TPMS could be part of the valve stem and could be expensive to replace.
Step 1Remove Tire
Remove Tire
What you should do is find some flat ground and lay the tire down. After doing so you will need to break the bead. Breaking the bead requires a lot of force. My method is to run the tire over with another car. You should be extremely careful not to damage the rim.
5 comments
Feb 3, 2011. 12:57 PMlalunette says:
Good instructables !!
I always meant to find out how those vavle stems were installed.
BTW, got a good chuckle when I read about the "mental valve extender"
Dec 6, 2010. 11:50 PMthebatman says:
an easier way to get a bead to seat is take the 4 way valve tool and remove the core with the tool then use a compressor to set the bead, do not exceed max psi for the tire to set it, also you need to lube the bead with soapy water if you break it
Nov 1, 2010. 7:48 PMrevkarl says:
I have been meaning to get a "mental valve extender". sounds useful.
May 31, 2009. 4:34 PMkillerjackalope says:
We had a handy little tool for this, made it far simpler to do because every now and again you'll wreck the threads on the valve stem, fine if dust caps are plastic but stem extenders just won't go on...
Mar 14, 2009. 3:16 PMcitydragon says:
Good tips on inserting the stem, breaking the bead and resetting the bead. Thanks!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:ivanbg
