If yours deletes your save and won't let you save anymore then chances are you will need to replace the battery.
This may work with other gameboy games but pokemon gold/silver are the only ones I know about.
Please Note: I take no responsibility for any damage to you, your gameboy, your game or anything else. My game and gameboy are fine and this shouldn't damage them, Just covering myself.
Please note: if you have ANY type of save that loads up then this will wreck that, otherwise lets get started
EDIT: quadcam24 has suggested in the comments that instead of using a screwdriver you could use fine tipped pliers to turn the security screw, this method would be easier and quicker than using a screwdriver if you could find pliers with thin enough tips
Step 1: You Will Need
A small straight head precision screwdriver,
A CR2025 battery, I'm sure other similar batteries e.g. CR2032 etc. will work but on the pcb it says CR2025 so thats what I used.
And
Some sticky tape,
You can also buy special batteries from the internet, which have tabs to solder directly to the pcb which will created the most secure connection possible, however if you tape the battery firmly then it should be just as good.
Step 2: Open it up!
Step 3: Take off the old battery and put the new one on
Take the precision screwdriver and push it from where the tab is stuck onto the battery near the outside in towards the inside therefore removing the tab from the battery but keeping it attached to the pcb. Repeat on the tab stuck to the bottom of the battery.
Stick on the new battery with the tape making sure to get good contact between the battery with the tabs. If that comes loose then your save gets deleted :-(
Note that the battery goes in upside down (see the polarity markings on the pcb)
Please do not solder the tabs onto the battery as this is very dangerous and could cause the battery to explode
Step 4: Your done!
Enjoy your game! :-)
Visit Our Store »
Go Pro Today »
http://hackaday.com/2012/05/02/simple-trick-for-replacing-game-boy-cart-batteries-while-retaining-game-saves/
(Link has a video.)
Note:Don't try it on Pokemon Crystal. If the battery is down you can be sure about that, as the save is OK!
Just picked the metal bits off the battery with a flat head screwdriver and taped the new 2032 battery in with insulation tape. The 2032 battery along with the tape ended up making it a bit tight, so we ended up not having to put in a new screw afterwards. Both copies now work perfectly. Thanks! It's now as good as new (except for a dent on the back from the drill, which I don't mind at all)
Yes, frustrating that Nintendo didn't use a holder that was meant for user servicing, but at least it wasn't that bad of a fix! If you don't solder and feel like taking a chance, you may be able to get someone in a local high school electronics class to do it for you.....
I'm pretty sure I got ripped off on the battery (it was 7.50 :/) but I wasn't in the mood to go hunting for a better deal or order one online. It still ended up cheaper than ordering a new game on ebay and now I have my childhood memories back <3 Thank you so much for writing how to do this, Josh! I've played every Pokemon Game ever made and classic Silver is still my favorite :D I've had it since I was eight and I'm NEVER giving it up so now I don't have to :D
I was able to get the tabs off by firmly pushing the screwdriver underneath the tab (possibly twisting the screwdriver as well).
If you are still having real trouble with this, it might be possible (depending on how far up the tab the hard bit is) to actually cut the tab off the battery, and simply tape the remainder of the tab onto the new battery?
Pokemon yelloew does in FACT use a battery (im looking at it now)
Pokemon yellow uses a CR1616 battery for the constant power needed to store the memory.
