loading
This instructable shows you how to replace a battery in a pokemon gold/silver cart.
If yours deletes your save and won't let you save anymore then chances are you will need to replace the battery.
This may work with other gameboy games but pokemon gold/silver are the only ones I know about.
Please Note: I take no responsibility for any damage to you, your gameboy, your game or anything else. My game and gameboy are fine and this shouldn't damage them, Just covering myself.
Please note: if you have ANY type of save that loads up then this will wreck that, otherwise lets get started
EDIT: quadcam24 has suggested in the comments that instead of using a screwdriver you could use fine tipped pliers to turn the security screw, this method would be easier and quicker than using a screwdriver if you could find pliers with thin enough tips
Step 1: You Will Need
You will need:
A small straight head precision screwdriver,
A CR2025 battery, I'm sure other similar batteries e.g. CR2032 etc. will work but on the pcb it says CR2025 so thats what I used.
And
Some sticky tape,
You can also buy special batteries from the internet, which have tabs to solder directly to the pcb which will created the most secure connection possible, however if you tape the battery firmly then it should be just as good.
Step 2: Open It Up!
Turn the screw on the back anticlockwise until it comes out. Ideally you would use a smaller screwdriver than I used but thats what I had to hand.
Step 3: Take Off the Old Battery and Put the New One On
I did this a while ago so you can see the battery already replaced but you can get the idea.
Take the precision screwdriver and push it from where the tab is stuck onto the battery near the outside in towards the inside therefore removing the tab from the battery but keeping it attached to the pcb. Repeat on the tab stuck to the bottom of the battery.
Stick on the new battery with the tape making sure to get good contact between the battery with the tabs. If that comes loose then your save gets deleted :-(
Note that the battery goes in upside down (see the polarity markings on the pcb)
Please do not solder the tabs onto the battery as this is very dangerous and could cause the battery to explode
Step 4: Your Done!
Put it back together by repeating step 2 (except clockwise). Then put it in your gameboy and turn it on. Start a new game walk outside and save then turn off. Wait about 15 seconds, turn on and if your save is still there it worked.
Enjoy your game! :-)
There is a much simpler and permanent solution. A mildly modified cr2032 surface mount coin battery holder should be soldered into the solder points where the original battery was soldered in. <br><br>This way future battery changes will take seconds and not require additional soldering. It also should be fast enough in the future that your save games will survive, although you can always backup and restore with a retron 5. <br><br>This battery fix works on nes, snes, n64, gameboy, gameboy color, and genesis carts. I have not tried on other carts as if yet, but as long as there is clearance only minor mods should be needed.
Correct me if I'm wrong, but wouldn't JB Weld be an option? I understand it doesn't conduct electricity, but the current should flow nicely if you make sure the direct connection from the battery to the tab is good before applying JB Weld. You can find it at a local hardware store pretty easily, should only be about $5. Just make sure it dries fully before closing the game up. Of course this is a more semi permanent solution and won't be as easy to replace the bay again should you need to (compared to tape)
Correct me if I'm wrong, but wouldn't JB Weld be optional? I understand it doesn't conduct electricity, but the current should flow nicely if you make sure the direct connection from the battery to the tab is good before applying JB Weld.
<p>i'm really happy with this my game could not save and now it can i cant thank you enough thx :p</p>
<p>Used these:<br></p><p><a href="http://www.ebay.co.uk/itm/10-x-Game-Boy-Cartridge-Batteries-Tabbed-CR2025-Pokemon-Red-Blue-Gold-Silver-/231911807794" rel="nofollow">http://www.ebay.co.uk/itm/10-x-Game-Boy-Cartridge-...</a><br><br>Worked really well thanks!</p>
<p>Don't do it this way. Yeah, it works, but it's not worth the risk. It's very easy to damage the board or case using the techniques (and I use that term loosely) illustrated here.<br><br>It's not hard to do it the right way, and a proper security bit to remove the screw is not expensive. It's two soldering points to remove to take the old battery out, and two points to solder the new one in. If you don't know how to solder, give it to someone that does. There are only so many copies of these games floating around, and destroying a copy by pulling stunts like this isn't going to make them easier to find.</p>
<p>Worked perfectly well for my Silver. I had no trouble, and no damage occurred. I get your concerns though. What exactly is needed to remove the screw?</p>
<p>Like I said, the proper security bit, in this case a 3.8 MM star bit.<br><br>This is the one I use. It's less than $5 shipped, and you get a 4.5 MM bit as well. Between the two, you can open up just about any Nintendo system or game, it's an investment that pays for itself in no time.</p><p>http://www.ebay.com/itm/371081162012?_trksid=p2060353.m2749.l2649&amp;ssPageName=STRK%3AMEBIDX%3AIT#</p>
<p>Wasn't sure exactly what I was looking for by name, so I appreciate your response. Thanks!</p>
<p>Shop around for the batteries CR2025. Sometimes where they sell watches like jewelry counters have them cheaper then in the battery sections of stores. Also you can buy individual batteries instead of packages of 2 or more if you can't afford the packs. </p>
The special batteryies are 5 for $5 on eBay if you get the 10 for $10 it comes with a special screw driver too :) soldering is kind of difficult if you've never done it before but I would highly recommend it otherwise if you dropped the game and the battery shifts for a second all your poke friends could disappear... :0
So that's what the inside of a cartridge looks like...
<p>Very easy to follow your steps to replace the battery. Thanks</p><p><a href="http://batterychargersexpert.com" rel="nofollow">More</a></p>
Could you soder the battery to the prongs in place of the tape for a better connection
<p>Yeah, make sure the battery is clean, try adding a dab of solder, let it cool, put it in place and reheat. I turn my soldering iron temp all of the way up and try not to hold it on the battery for very long.<br><br>The higher temp gives the heat less time to spread over the battery, which IMO seems safer than letting the whole thing get to solder melting temp.<br><br>There's a high chance of error so I don't recommend doing this.</p>
<p>You should be be careful with that since batteries are not meant to be heated.</p>
Thank you!!I bought game secondhand (tricky, tricky!)and found out why!
<p>Recently dug up my old GBC and GBA systems and wanted to replace the batteries since I lost all my saves (and Pokemon!!)</p><p>I just followed your guide and it worked like a charm! I was infuriated at not being able to open my Silver cartridge with a flat screw driver, nor finding the right tool at my local hardware store...so i stumbled across this post and <strong>arvin.barcia's</strong> hack comment with a melted pen case that worked so well the first try I couldn't believe it. Then spent a good 20mins detaching the metal tabs from the old battery before replacing it and neatly and securely fastening it all up with electrical tape! Everything's working so well I might just ditch my 3DS and Heartgold to replay ol' Silver...</p><p>Thanks!</p>
Would a hearing aid battery work?
Just did this earlier this afternoon! Worked absolutely awesomely :D Used tweezers to unscrew it (it took a few tries but the whole process was only about 15 minutes) then used a flat-head screwdriver to break the tabs off of the old battery. Getting the one underneath off took a little bit more work because of the angle but it popped off eventually. (For those of you having trouble, kind of slide the edge of the screwdriver underneath and push down as you move it forward. You don't have to worry about scratching the battery so dig into it as much as you can and the solder should scrape off. I also did a little bit of rocking back and forth as well as side to side in order to jimmy it under further.) Then I placed the new battery in, folded the tabs back into place, and layered it with a ton of electrical tape.<br><br>I'm pretty sure I got ripped off on the battery (it was 7.50 :/) but I wasn't in the mood to go hunting for a better deal or order one online. It still ended up cheaper than ordering a new game on ebay and now I have my childhood memories back &lt;3 Thank you so much for writing how to do this, Josh! I've played every Pokemon Game ever made and classic Silver is still my favorite :D I've had it since I was eight and I'm NEVER giving it up so now I don't have to :D
I got three 2025 batterys for $0.88 at kw surplus
<p>the tweezers worked great thanks for the idea!!</p>
<p>for more information about healthy news</p><p><a href="http://goo.gl/Nb5snX" rel="nofollow">harga emas hari ini</a></p>
<p>for more information about healthy news</p><p>&lt;a href=&quot;http://goo.gl/ir1zMo&quot;&gt;grosir tasbih digital&lt;/a&gt; </p><p>&lt;a href=&quot;http://goo.gl/PQI96y&quot;&gt;khasiat buah naga merah&lt;/a&gt; </p><p>&lt;a href=&quot;http://goo.gl/Nb5snX&quot;&gt;harga emas hari ini&lt;/a&gt; </p>
<p>found a cool hack.</p><p>get a pen</p><p>remove the ink bit so you only have the case</p><p>heat/light the end so it is melty</p><p>put out the flame and put to the melty pen to the screw and wait for it to set</p><p>unscrew the cartrige.</p><p>voila!</p>
<p>What I did, is I soldered a new battery with small leads to the existing <br> contacts, leaving the original battery in place. The new battery fits <br>snugly inside the cart, and my save file is still there!</p>
I replaced my battery and it saves again, but the clock still doesn't advanced when it's off. Is there something I need to do? Or is just fate?
It's probably a better idea to buy a new battery with the tabs pre-attached and desolder the existing ones on the PCB, then solder on the ones you bought. It'll mean that if you drop your cartridge/Game Boy the battery doesn't fly out and delete your save data.
It's probably a better idea to solder the battery to the tabs on the PCB, it'll make sure nothing goes somewhere it should if you drop the cartridge/Game Boy, and it's not that hard to do either.
Hey guys. It is possible to keep your saves whilst replacing the battery. You just have to leave the system on while replacing the battery. You should try to do it quickly, but still be careful. <br>http://hackaday.com/2012/05/02/simple-trick-for-replacing-game-boy-cart-batteries-while-retaining-game-saves/ <br>(Link has a video.)
Quick tip for removing the cartridge screw. I suggest taking an eyeglasses screwdriver, preferably a flat-head, and inserting it at a 45 degree angle into one of the prongs of the screw head. Then, while pushing down with the screwdriver with the force aimed almost into the screw, (It's hard to explain) turn the cartridge while keeping the screw in place. I think it gives it more leverage or something, it worked for me. Just keep trying, and don't get frustrated.
Thanks a lot! Gonna try it. <br>Note:Don't try it on Pokemon Crystal. If the battery is down you can be sure about that, as the save is OK!
*and the time is not set.
I am THIS close to giving up on my attempt to repair my red cartridge. I followed your instructions to the letter, and did everything you mentioned with the utmost care, and yet, my game STILL wont save! i've tried with both a cr2025 and a cr2032 battery and neither got the thing working for more than one moment. please, if anybody has any suggestions, i'd be glad to hear them. i also have pictures detailing the procedure, but i cant seem to post them.
I just tried to do this with my good ol' Pokemon Silver game and it worked. I used CR2032 battery which was the only thing I found laying around at home. Thank you for the guide on how to do this, it is much appreciated.
I can't open it up eather
i heated up the end (non-blade side) of a plastic knife and melted it into head of the screw thingy, then let it dry and opened it with that. worked like a charm.
I tried doing that, and all i got was the print of the screw in my knife. Did i do something wrong?
Have you tried the advice which I gave to other people? -josh
Your instructable guide worked!!! Now my pokemon gold and sliver game packs work
Awesome guide. I had used it once already to fix pokemon silver, and then some time later got my sisters copy of pokemon gold. The first time I got help from my dad, and we struggled a bit with getting the screw out, but ended up just trying to drill it loose from the cover. The drill was right next to the screw and ended up spinning it, finally making the screw loose :P<br>Just picked the metal bits off the battery with a flat head screwdriver and taped the new 2032 battery in with insulation tape. The 2032 battery along with the tape ended up making it a bit tight, so we ended up not having to put in a new screw afterwards. Both copies now work perfectly. Thanks! It's now as good as new (except for a dent on the back from the drill, which I don't mind at all)
hey one of my tabs broke off now wat am i suppose 2 do ??? it wont work any ideas?
you need to solder it back on :( . You MIGHT get away with gluing it however the only difficulty is you need to maintain an electrical connection. i.e not block off the current with a thick layer of glue. -josh
I had the same problem. So if i solder it back on then it will be ok?
Yes it will, just make sure not to damage the circuit board when you're soldering it, though.
fwiw, I recently replaced the battery on a pokemon sapphire. In that the battery was also soldered down. It was fairly easy to desolder and I bought a replacement CR1616 at Batteries Plus and they were able to spot weld some solder tabs onto the new battery for me. And before anyone worries too much about the price, don't. It was cheap. I don't recall the exact amount but we are talking $3-5 range for the battery with the tabs spot welded onto it. Of course I still had to solder it down, but I am confident that my repair will last as long as the battery. It was dumb luck that I realized Batteries Plus would provide that service. <br><br>Yes, frustrating that Nintendo didn't use a holder that was meant for user servicing, but at least it wasn't that bad of a fix! If you don't solder and feel like taking a chance, you may be able to get someone in a local high school electronics class to do it for you.....<br><br>
Plan B: there's a conductive electronics cement that seems to work just dandy. I found my tube at gateway electronics ( www.gatewayelex.com ) but I'm sure it's available in many electronics stores. Gateway is just the electronics/electronics surplus that's closest to me.
Worked like a champ thanks Josh!!
About This Instructable
865,229views
105favorites
License:
More by josh92176:How to replace the battery in a pokemon gold/silver gameboy cart How To Play Guitar How to make A transprent wallet for less than 50p
Add instructable to:
