How to replace the engine air filter on the Hyundai Tiburon 2008 by TiburonCare
This is a fairly simple task of replacing the engine air filter in the 4 cylinder Hyundai Tiburon.  The engine air filter keeps dust and debris out of the engine and prevents premature wear and tear.  It can get clogged and reduce performance and fuel economy if not replaced regularly.  How often depends on your environment but I usually do it every year cause it is easy and cheap.  Check out the maintenance manual for specific time/mile intervals.
All you need is the engine air filter which is readily found at most auto parts store as well as the dealer. No tools but your hands are needed.
Step 1: Remove the engine air filter cover
Pop open the hood and find the engine air filter housing.  To open it, you have to unsnap 2 hinges on the front corners of the housing.  The back of the housing has slots from which the top part of the housing slides out after the hinges are unsnapped.
Phil B says: Apr 24, 2012. 6:03 PM
Thanks. I have a new Hyundai Sonata with a 4-cylinder engine. I have not yet checked out how to change the filter in my engine. On previous cars I have used a very similar filter. I liked to write the date of installation on the orange frame, just as a reminder to myself. I also wrote the date of change in a spiral notebook I keep in the glove box.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
