How to Restore Headlights on a Budget!
67,270
101
9
Posted
Introduction: How to Restore Headlights on a Budget!
There are instructions for restoring your faded/yellowed headlights on a budget.  All you need is some 1500 and 2500 sandpaper and clear spray paint.  I found the sandpaper and some automotive clearcoat lying around at the TechShop in Menlo Park so I thought I'd give it a try and it turned out pretty nice.  I'd imagine you could buy the materials for under $10 though if you don't have the stuff lying around.
If you're interested in TechShop, check out their website, http://www.techshop.ws.  TechShop is a membership-based workshop that provides members with access to tools and equipment, instruction, and a community of creative and supportive people so they can build the things they have always wanted to make.
Step 1: Step 1: Sand
The problem with most plastic headlights is that they come with a very thin "protective coating" that is supposed to lessen the effects of rock chips and possibly deterioration from UV exposure.  Unfortunately, these coatings don't last very long and tend to turn opaque as they age.  The goal with the sanding is to get rid of this coating altogether.
It is a good idea to either remove the lens you are working with, or tape of the surrounding area so that you don't accidentally sand the paint.
Start with your 1500 sandpaper, and grab a little cup of water.  Using plenty of water, sand the headlight lens for at least 10 or 15 minutes.  Dry the lens occasionally and inspect the surface.  Once the protective coating is gone, the surface should be even all around.  If you still see any rock chips you can continue sanding to try to eliminate them as well.
Once you have an even surface with no coating remaining, you can move to the 2500 sandpaper.  Using the same process, sand for another 10 minutes or so, until again the surface looks even and you can't see any scratches from the 1500.
Note: When you are done, the surface should be very smooth, but it will not be clear yet, it will still be foggy from the sanding.
Step 2: Step 2: Paint
Once you are satisfied with the finish, simply spray a few coats of automotive clear coat paint and it will clear up instantly!  If you want to buff or polish the clear coat once it's dry you can, but it looks pretty good as is.
Note:  If you didn't remove the lens from the car, you'll want to make sure you've sufficiently masked the surrounding paint before spraying the clear.
  • Awesome! The clear c...-RushFan
    RushFan made it!
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
  • Epilog Challenge 9
    Epilog Challenge 9
8 Comments
I tried everything in the world and nothing would work. Even tried WD40 that people say to use. That lasts for about a week and then back to the grungy headlights. I got the bright idea of using ceramic cooktop cleaner and it worked great. Then used plastic polish you get from auto parts store and after a year they still look great.
FYI. Deep woods off only made my lenses worse.
Something passed around on Facebook is to use Deep Woods Off or mosquito repellant. Spray a good bit of it on a towel and wipe headlight.
toothpaste works shockingly well too
Thumbs up! Good, easy to follow instructions. I'll be removing the yellowing from my headlights now. Thanks for the great Instructable.
this is more cheaper if you use metal polish rather than clear coat will not last for long time it will chip off , what i do is sand it with 1000 sand paper and use metal polish rub it until you see it crystal clear, it takes long but the result is best and last longer, or you can make it shorter by using machine for waxing.
nice one,
our honda civic has the same problem, my gf calls it cataract lens..will buy some sandpaper and clear coat spray paint..
I like your "before and after" pictures. Very nice.
