How to Root Any Android Device
Published
Introduction: How to Root Any Android Device
About: Hi, my name is Jovian and I like hacking, breaking and building things .Doing projects that are interesting is something I love since my childhood. I like to think outside of the box and make amazing tutori...
Hello friends today I am going to show you how to root your bsnl penta . This tutorial may also work for other android tablets/phones. I will show you two methods that you can to root your bsnl penta. I have tested this methods for Bsnl penta IS703C and Acer TD7BP51.
This tutorial is for rooting bsnl penta . rooting your android device means getting super user rights . you can do many things after rooting like overclocking , increasing battery life , changing boot animations ,boot logo and even installing custom rom
Note: Rooting your android device might void your warranty I wont be responsible for any damage caused to your android device.
Step 1: Rooting Using Vroot
Step 1 - Download vroot.apk
Step 2 - Install vroot on your device.
Step 3 - Ensure your device is connected to internet.
Step 4 - Open vroot and wait for some time.
Step 5 - Click on root.
Step 6 - Wait for some time and your device will be rooted.check if kinguser is installed
Step 2: Rooting Using Adb
Step 1 - Download and extract adb root.zip
Step 2 - Make sure you have adb drivers installed on your computer.
Step 3 - Connect your device to your computer using usb cable and enable usb debugging
Step 4 - Open the the extracted folder and run root.bat
Step 5 - Follow the instructions on the computer
Step 6 - For the first time press any key to continue
Step 7 - but for the rest of the time wait until reboot is fully complete and then press any key
Step 8 - Your device will be rooted. check if superuser is installed
Step 3: Troubleshooting
To check if you have rooted your device successfully you need to download and install root checker . Open root checker and click on verify root .Click on authorize/allow if asked .if it says ‘congratulations ! Your device is successfully rooted ’ then you don’t need to follow these instructions but if don’t get these then follow these instructions
Step 1 - Download and install Terminal Emulator
Step 2 - Open Terminal Emulator and type which su
Step 3 - You will get a path (eg /system/bin/su)
Step 4 - Type this path and the $ sign should change to this #
Step 5 - type /system/xbin
Step 6 - After that type cp su and path you got in step 3 (eg cp su /system/bin/su)
Step 7 - Reboot your device.
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    • Clocks Contest
      Clocks Contest
    8 Comments
    Nice information. To get more information about how to <a href="http://howtorootandroid.org/root-samsung-galaxy-s5/">Root Samsung Galaxy s5</a> visit this site also.
    I vote for AnyRooter Android Pro, which is the best rooting program i have ever used. It works extremely well on devices with high Android version whereas the competitor failed to do that.
    Would this work on the droid turbo?
    hiii
    i want to root acer tablet TD7BP51. i tried ur adb zip file with usb debugging on. but it says device not found.
    u said u have tested it on acer TD7BP51 tablet. did it work for u ??
    Sorry for the delay, I was a bit busy (exams). Acer tablet TD7BP51 does not support ADB .however if you root your Tab using vRoot you can install a custom firmware which supports ADB .
    I will be making an instrustable to install custom firmware for your tab
    hiii, since i m from goa. we all have same acer tablet.
    can u tell me any other way to root this acer tablet???
