3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to row a canoe for fishing or excercise, the cheap, fast row boat
Step 6A good foot brace (give me a place to stand and I'll move the earth)
A good foot brace (give me a place to stand and I\
You will need a good solid place to brace your feet while rowing. In my canoe I use the lower leg of the "T" in the center thwart as the place to attach the foot brace. It is just another piece of the AL angle with a U-bolt to secure it to the pipe. You want the foot brace as wide a possible as in rough conditions spreading your feet out gives you more stability.
On my canoe I moved the center thwart forward about 6 inches to get the proper distance. I don't plan on carrying my canoe that often so if the aft end drags on the ground it won't kill me. I could have put a block in to make up the distance instead, but the area between the thwarts is for my two older kids so they need the extra room.
These gate hinges are amazingly strong, they flex very little, mostly up and down, not to much twisting, just a slight twist during each stroke, which just like a springy oar is returned at the end of the stroke. I rowed dories in high school and always wanted 9' 6" oars to get the proper effort, so when I made my own oars they ended up at 9' 7" not so much by design, just that was the length they ended up at. At that length I bump the ends of the handles on each return. Someday I'll have to post how I made them also.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
15
Author:rowerwet
airplane nut since forever, rower since high school, airplane mechanic since '94, father of four
