3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to run Windows on a PSP!
Step 4Finishing touches!
Finishing touches!
The installation should now be complete, and you are ready to test it out. Exit USB mode on the PSP, and run DOSBox. If you get any errors, or you do not see DOSBox, then go back to the folders and files and make sure everything is where it should be. Sometimes it will freeze, just restart it.
Next, I will show you how to get Windows running. Whether it be 3.1, or 95.
This is the file that automatically runs on start up, with what each thing does:
[autoexec] --- This is found in the DOSBOX.CONFIG file
@ECHO off
cls --- Clears the screen
SYSOPT clock 333 --- Sets the psp to run at full speed
mount g ms0:/hdd --- Will mount the folder that we made that is called HDD as drive G:
imgmount c g:/w95.img -t hdd -fs fat -size 512,63,16, --- Mounts the Image as a drive in DOSBox
imgmount d g:/win31.iso -t iso --- Mounts the Image as a drive in DOSBox
mount m ms0:/MUSIC --- Mounts the Music Folder as drive M"
PAUSE --- Will say "Press any key to continue"
g: --- Switches to drive G:
osrun.bat --- Starts the OS Starter to Startup Windows
So Once it starts you press START or any button on the psp.
Then It will Show...
OS Starter 1.2
Next, You press START or any button Again.
Then it will ask you...
Do you want to start Windows 3.1?
Y is Left-Up(you press the Left Arrow the Up Arrow )
N is Circle-Triangle(You press The Circle button then The Triangle)
Then is says...
Press Y or N:
If you want to start Windows 3.1 You Press The LEFT Arrow then the UP Arrow.
If not You Press the Circle button And then The Triangle.
If you say no It will ask you if you want to start Windows 95
It will show...
Do you want to start Windows 95?
Y is Left-Up(you press the Left Arrow then the Up Arrow )
Press Y or N :
If you want to start Windows 95, Then you press The left arrow key Then The Up arrow Key On your PSP.
Then you have to wait about a Minute for it to start Windows 95(If your on a PSP Slim but if your on a PHAT it may take longer)
You don't need to login to Windows 95, Instead it will automatically start.(NOTE:If it does not load within 5 Minutes Close DOSBox and try again)
Windows should be running by now, if not, you most likely made a mistake with the directories and folders.
It is sometimes very slow, it may take a long time to start up, and may lag quite a bit.
Enjoy!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:N1CK4ND0
Nick Anderson; Gamer; Happy.
