How to safely disassemble a CRT monitor
 by thermoelectric
Do you have a old CRT monitor lying around your house but you think it's too dangerous.
Now is your chance to do it moderately safely do it.
I take no responsibility for any injuries ect. caused by you disassembling a CRT monitor.
Step 1: Tools
  • Screwdriver (Insulated handle)(one that you don't mind the tip getting a bit melted)
  • Piece of wire, one that you don't mind melting, preferably a thick wire (to ground the screwdriver)
  • Nail (to puncture the tube to fill the vacuum)
  • Rubber shoes (To insulate you from the ground)(optional)
1-40 of 56Next »
logamuthu says: Dec 8, 2012. 8:55 AM
Very clear exposition of a daunting job. Kudos!!
UATradition says: Nov 19, 2011. 2:09 PM
So I just straight up cut through all the wires and the big red one leading to the suction cup and no sparks or melting wire cutters ... could something still be charged ? Other than any capacitors ? I haven't removed the suction cup yet ...
synchr0nize says: Nov 15, 2011. 4:10 AM
errr why would you need to do this?
Greyfox95 says: Oct 29, 2011. 10:20 AM
I disassembles one of these today, i wish i would have seen how to ground it before i shocked myself! dang flyback...
highvoltageguy says: Apr 6, 2011. 10:40 AM
when my tv breaks im goona take it apart cuz i want a flyback but i thin that the tv will have gone bust beacause of the flyback great instructable by the way
RefStone says: Jan 12, 2011. 10:34 AM
Nice intructable, someday I'll do a follow up on using the parts if there isn't one already.
There is one piece I really like for non-electrical reasons. You can see (step 5) a metal ring going around the tube, just below the green topper, with a bolt through it (the bolt is at a tangent to the green circle, on the bottom left). This thing can be really useful. I keep one on my belt loop to hold a standard plastic bottle at my waist. It just pops in and out, no adjustment necessary, once you get it right.
Be well.
-Ref
drresearch says: Mar 28, 2010. 11:20 AM
Why do you have to break the CRT? Can't you leave intact?
thermoelectric (author) in reply to drresearchApr 16, 2010. 6:46 AM
As you already got a answer, I don't need to answer, but I want to. You can leave it intact, but filling it (getting rid of the vacume (I still can't spell that), reduces the risl of implosion etc.
drresearch in reply to drresearchMar 28, 2010. 11:28 AM
Ooh, I found the answer below!
mason0190 says: Oct 12, 2009. 10:02 AM
isnt there like radiation or summin in der!?
thermoelectric (author) in reply to mason0190Oct 13, 2009. 4:59 AM
No, unless you call the poisionous lead and phosphors radiation...
Xellers says: Oct 6, 2008. 4:13 PM
Would it be possible to somehow extract the CRT without damaging in and to use it again for another proejct?
mason0190 in reply to XellersAug 25, 2009. 4:10 PM
might you be planning on making a CRT fishtank? WOW! I am too!
mason0190 in reply to mason0190Aug 25, 2009. 4:10 PM
thermoelectric (author) in reply to XellersOct 6, 2008. 10:32 PM
Yes, but i broke the vacuum so it didn't implode if i dropped it.......
drresearch in reply to thermoelectricMar 28, 2010. 11:30 AM
But if someone didn't brake the vacuum, what could be done with just the CRT? I would also be interested to know.
thermoelectric (author) in reply to drresearchApr 16, 2010. 6:44 AM
There is very little you can do with the CRT once you get rid of the driver circuitry. Making your own drivers are not a good idea, Unless you want to potentially give yourself a mega dose of all types of radiation.
golddigger1559 says: Apr 15, 2009. 7:59 AM
if you break the vacume dont you have to worry about explosive decompression????
thermoelectric (author) in reply to golddigger1559Apr 15, 2009. 5:10 PM
Yep, Breaking the neck of the CRT or piercing a hole in the place where it was originally filled (at the top of the neck) slows the decompression because there must be a restriction in the neck somewhere... But it's always good to be careful.
joinaqd says: Feb 5, 2009. 5:30 PM
nice.i gave you a 5 star
thermoelectric (author) in reply to joinaqdFeb 5, 2009. 10:07 PM
mg0930mg says: Feb 1, 2009. 5:57 PM
I just throw rocks at them from 30 or so feet away. Never taken the parts out,though. It was just a monitor in the woods, someone left. May bring it out, and get parts.
thermoelectric (author) in reply to mg0930mgFeb 1, 2009. 9:41 PM
Oh.
Enter 77 says: Jan 17, 2009. 10:42 PM
personnaly i find a 12 gauge is the most fast, efficient and most important, FUN method of dismantling and old CRT :P
thermoelectric (author) in reply to Enter 77Jan 18, 2009. 1:09 AM
I, I, I, I'm speechless....... :-P
Fliboi in reply to thermoelectricJan 18, 2009. 1:25 AM
i was there, that was one hell of a weekend :D. we gota top it next year now lol XD
thermoelectric (author) in reply to FliboiJan 18, 2009. 5:59 PM
Good luck.....
Enter 77 in reply to thermoelectricJan 18, 2009. 1:20 AM
also note the mcdonalds toys and nail gun fuil cylinders littering the ground around it. And the burn marks from tracer rounds/butane explosions
thermoelectric (author) in reply to Enter 77Jan 18, 2009. 5:59 PM
Yeah, I usually just hit the mcdonalds toys with a hammer, Give them to my dog.....
grampafish says: Nov 22, 2008. 4:10 PM
i talked with a tv repair person and they said that a screwdriver can't handle 10,000 volts.he says that you should use a high voltage probe connected to a 1mega ohm half watt resistor just to be safe. here is a pic of the probe.
thermoelectric (author) in reply to grampafishNov 22, 2008. 8:44 PM
Yeah, But a exploding screwdriver is just part of the fun. Thanks for the warning anyway
grampafish in reply to thermoelectricNov 24, 2008. 3:59 PM
your welcom
thermoelectric (author) in reply to grampafishNov 24, 2008. 11:08 PM
Yeah...
awang8 in reply to thermoelectricDec 30, 2008. 3:56 PM
the screwdriver is grounded so it's 0 volts.
thermoelectric (author) in reply to awang8Dec 30, 2008. 4:24 PM
And you discharge that to the positive of the flyback and the capacitor to be safe......
kitrule says: Dec 17, 2008. 4:55 PM
Don't you need to connect the screwdriver to something really grounded rather than the earth connection from the power cable socket which isn't connected to the mains?
thermoelectric (author) in reply to kitruleDec 17, 2008. 11:32 PM
Well, I connect it to the ground of the device because it's pretty hard to try to discharge capacitors with only one lead in the ground, But it's worth a try....
grampafish says: Nov 22, 2008. 4:14 PM
use caution because the crt can recharge even if it is unplugged for 2 years. to avoid serious injury or death DO NOT attempt this:-)
thermoelectric (author) in reply to grampafishNov 22, 2008. 8:46 PM
Yeah, That's the electrolytic caps charging up, I like challenging myself so I attempt anything dangerous
TheWelfareWarrior says: Aug 15, 2008. 9:06 PM
you don't release vacuum. Vacuum is the absence of particles inside something so when you puncture it it fills up, not comes out. Aren't those things filled with like radon or something... I know there is lead in the glass to reduce radiation.
1-40 of 56Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
