How to Safely Set Your Hand on Fire
18,820
51
19
Posted in PlayParty-tricks
Introduction: How to Safely Set Your Hand on Fire
WARNING! There is some risk involved in this trick, make sure you have some means of extinguishing yourself handy. This is NOT a good trick for children. And as always, use common sense ;)
What you will Need: Hand sanitizer, matches, bowl of water or sink.
step 1: put a good coat of hand sanitizer on your hand
Step 2: light it on fire with the match
step 3: Your hand will escape getting burned for a second or two while the fire burns the sanitizer away, once that is gone then it will start to burn you, give you hand a shake to put it out or use water.
    • Space Challenge
      Space Challenge
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    19 Comments
    Are there other things you can use that will prevent the burn for longer?
    It is safe as long as you use your head. Don't be drinking and do this as alcohol is flammable, the longer lasting the flame the higher the alcohol content.
    It does work and I could make it last 10 seconds.
    You can pretty much use any flammable aerosol to do this. The trick is to make sure you apply a thick coating and have a wet towel handy to extinguish the flame. I have done this too many times to count & have only been burnt once. The 1 time I did get burnt was when the friend who was supposed to throw me the towel (when i called for it) panicked & froze.
    it is so cool i tried it AND IT DIDN'T HURT AT ALL until 4 seconds later
    did it hurt?????
    If you had to say that it's going to burn your hand, it's not safe.
    I find it ironic that someone with the word 'pyro' in their username is concerned about getting burned. This is completely safe, and the flame is easy to extinguish.
    I vaguely remember doing something as a kid (a VERY long time ago) that involve mixing meths (denatured alcohol) 50/50 with water then setting it alight.
    I'm guessing that the alcohol burned off leaving enough water on the hand to protect it.
    Experiment first - Like I said, it was a long time ago andI may well have got the proportions wrong! But it did work...
    I just did it twice. you honestly have 2 secs befor it starts to burn but us is safe if you know what your doing
    Yay... lets have all the little kids to try this with their faces.... JK. No this idea is awesome but I'm afraid that I might not have a hand after I try this.... Maybe I should wear a rubber glove?? :D
    I think that would be a bad idea - imagine the glove catching fire, it would not be a very pleasant experience. You can put your hand in a bowl of water either way, but given the choice, I'd prefer to do it without smoldering rubber fused to my skin ;).
    As for the instructable, I like the idea, but I don't think I'll try it anytime soon for safety reason - and not to give the kids wrong ideas ;).
    I have not tried this but i would not because the handsanitizer might not stick to the glove
    do not I will say do not wear long sleves
    Children WILL read this and WILL try it when their parents are out.
    And WILL get burned. Sure as eggs is eggs.
    I suggest all authors of dangerous instructables should consider this.
    (Obviouly there's no point in suggesting a ban on dangerous intructables.)
    If kids do try it and get burnt its their own fault. They will have to face their parents AND davidfz7 did issue a warning for kids not to try it. That is all. *~*
    You can also light your arm on fire by soaking it with axe first.
    Safely set your hand on fire? What's next, how to safely play Russian roulette? This should not be an instructable.
    I personally like this instructable. Setting yourself on fire is awesome, and makes you feel like a badass. And, actually, stuff like this works. Since alcohol burns at a low temp, many alcohol based solvents can be used. Its fun. Stop being negative.
    I'm not suggesting that children try it. I agree with you to some extent, but I think there's a balance. There are dumb things you can do that are very dangerous, but I don't think this is one of them if done with the proper Safeway measures. I can add a warning if it would make you feel better.
    A little bit about how this could go quite badly would be most appropriate!
    I, personally, like this trick and it looks cool at parties, but the way this is written sounds as though it's 100% safe, which it certainly isn't.
    Keep posting!
