How to save 11,644.07 on a designer lighting fixture!
 by edwinston14
Featured
My wife and I posted almost exactly a year ago a request for ideas on how we could recreate the chandler pictured. We got mostly comments on how amazed people were that a light could cost almost 12K! In the past year we have worked hard remodeling our 1880 home to a modern contempory dwelling. So after a year we came full circle and were staring at our small dining room. We really wanted that light. Of course you know the economy being what it is, and well, we wouldn't have the money to buy this light in 3 liftimes. So, I contructed it myself. I have left out the details on the electrical wiring, I consulted my electricion friend and would advise you to do the same. FYI, its basic electrical work but I don't want you coming at me if you burn down your house. I hope you enjoy this. I'm excited to show off my work!
Step 1: The Goods
Ok. Once again IKEA pulls through with the Hemma light. We chose to go with 7 bulbs on our light since our dining room is not that large. The silver "cups" which cover the sockets were easy to find on the internet. The "canopy," which covers the wiring in the ceiling, I salvaged from an old lid to a dog container. The ring... It was the hardest thing to find for the lamp. I have to get points for imagination on this one. All I can say is if you visit an adult novelties store and look, you'll find what I used.
Step 2:
'After opening the light packaging, I unscrewed the shade holder that comes with the light and loosened the top plastic nut. With the pliers I broke off the plastic rim around the socket.
Step 3: Sizing Socket
Due to the size of chrome cups we bought online, I had to remove some of the socket so they would fit into the cups. This also smoothes out the lips I just broke off with the pliers. I used the beltsander to achieve this. I recommend gloves unless you don't like your skin. Yes I bite my nails alot.
Step 4: Snip Snip
Cut off the plugs; you won't need them.
Step 5:
Slide the chrome cup and plastic nut that comes with the light fixture over the wire
Step 6: Attaching Cups
If you removed enough of the socket the cup will slide right over it. Tighten down the plastic nut firmly.
Step 7: Measure and remove extra wire
The Hemma light comes with ample wire. Cut it to the length you will need.
You might notice the invisible bookshelves in the background. Made those using an Instructable from another wonderful user.
Step 8: Straighen wire (optional)
In boiling water, I dipped the wire for 5 sec. Do not get the socket or end of the wire wet. Others might just recommend using weights and letting the wire hang for a few days.
Step 9: Pull it (opional)
Put your foot on the bottom of the wire and pull it upward. Caution! Pulling the wire too hard can break the copper inside.
Step 10: The result of straightening
See the difference?
Step 11: Bundle Wire
Ziptie wires together to make it easier to handle.
Step 12: Assembly and wiring
After removing the handle from the dogbone lid, I drilled a 3/4" hole to feed the bundled wire through. The "ring"' was slid over the bundled wires. Once the wire was pulled through the hole, I used the zip tie to hold the wires and keep them from sliding back down. I made all the connections for the wires and made the final connections to the power source.
Step 13: Ring
Slide the ring over the wires
Step 15: Finished light with bulbs
This is the light powered up in the dining room. These are the same G40 bulbs used in the original light. I will tell you this light is as bright as the sun! The original also has 19 bulbs and I can only see it used in a huge home or large commercial space. We have it hooked to a dimmer so that it can be used at certain times.
Step 16: Comments
The original light uses cloth wire which I was able to find in white, then dyed red. I was unsure about using the wire so used the Ikea lights instead.
I would love to hear from anyone that has ideas on how to make this design more eco-friendly. While these bulbs are only 60W each I think it can be made better. Smaller bulbs take away from the size and design. I was thinking of running small led lights inside the bulb once the element burns out...some how.
Retail cost: $11,700, Instructable cost: $55.93
Hope you enjoyed my first Instructable!
1-40 of 138Next »
jmitch77 says: Apr 3, 2013. 7:28 AM
I just found this i'ble! I just made my own light using the HEMMA light cords and those exact bulbs! I had no idea this was on here! Way to go and great look! I wish I would have seen how you straightened the cords before I made mine!
ClarissaMark says: Apr 4, 2012. 10:30 PM
Where on the internet did you find the silver cups? thats the only thing I can't find.
lbranscombe says: Jun 28, 2011. 10:23 AM
hey there.. maybe I missed it, but I am pretty sure I looked at every one of your slides - how do you connect ALL of the wires to the single electrical box? (pardon my non-electrician terms).
If i were to remove a ceiling light from my house there would be a place to connect two wires - not 16..
piaferre says: Mar 5, 2009. 6:37 AM
Here's an awesome 2nd option, enjoy.
mrwd40 in reply to piaferreMay 31, 2011. 1:50 PM
is there an instructable for the fixture in your picture?
HeidiJJJJ in reply to piaferreJan 12, 2010. 5:58 PM
If you make this version you can use these...
www.bluelounge.com/cabledrop.php
brandon9271 in reply to HeidiJJJJFeb 21, 2010. 4:10 PM
I'm probably the only person on Earth that thinks those Cabledrops looks slightly obscene :)
wufeisgirl in reply to brandon9271May 25, 2010. 8:10 PM
No... No, you're not. *GRIN*
brandon9271 in reply to wufeisgirlMay 25, 2010. 9:27 PM
They should've been called CableToes.  lol
brandon9271 in reply to wufeisgirlMay 25, 2010. 9:23 PM
It looks like a camel's err.. hoof :)
Foxtrot70 in reply to brandon9271May 26, 2010. 4:39 AM
I really had not thought of the item looking like that...but then I have just awaken for the day!
eoutlaw in reply to piaferreNov 12, 2009. 9:16 AM
This is very nice.  Is there an Instructable for this version?
scott! in reply to piaferreJul 14, 2009. 6:28 AM
That looks good!
daftpusher in reply to piaferreJun 25, 2009. 11:46 PM
Ooohh...nice! :o)
Anathema_Herem in reply to piaferreApr 17, 2009. 2:16 PM
Wow. That's freakin' awesome.
alahti says: Mar 4, 2011. 8:21 AM
Where did you find the chrome cups? I did a quick google search and I only get bad wall sconces. EEK. Overall, I have to say you have done the design justice!
edwinston14 (author) in reply to alahtiJan 26, 2013. 6:41 PM
http://www.grandbrass.com/catalog.cfm?category=Cups&subcategory=Stamped%20Cups
HannaO says: Feb 6, 2011. 6:07 AM
I love those bookshelves but can't find the instructable for it. :(
edwinston14 (author) in reply to HannaOFeb 6, 2011. 7:59 AM
Pick one! I can't find the one we used, lot's of others have posted after the orginal.
http://www.instructables.com/pages/search/search.jsp?cx=partner-pub-1783560022203827%3Anpr2q7v5m6t&cof=FORID%3A11&ie=ISO-8859-1&q=invisable+book+shelf
HannaO in reply to edwinston14Feb 6, 2011. 8:27 AM
Ah, I just realized your photo sideways - now it makes sense! I kept looking for shelves where the books would be upright. Thanks!
edwinston14 (author) in reply to HannaOFeb 8, 2011. 11:13 AM
I already figured out how to make your idea come to life! Love it?
polar bear6 says: Jan 17, 2011. 8:11 AM
i think this instructable should be called "How to make 11,644.07 magically apear in your hands from nothing"
edwinston14 (author) in reply to polar bear6Feb 6, 2011. 7:54 AM
If you make that money appear and post how to do it on here. You'll have the number one instructable! EVER!!
Valche says: Nov 20, 2010. 1:15 AM
Could someone PLEASE direct me to anyone with information on how to do the wiring for this? I'm working on something similar in my apartment but I refuse to risk anything by going about this uninformed, so I need as much help as possible.
hogthrob says: Jun 6, 2010. 3:19 AM
http://www.thelightbulbshop.co.uk/Shop/B22BayonetCap/Product/30945/MLEDBulb/MASTERLEDBulb.aspx these phillips bulbs are the most similar off the shelf bulbs I could find they are 6-7 W each Part of the aesthetic of the original is the big clear glass bulbs and the elements inside which you dont get with led or cfl bulbs however, I thought the detail on the cup around the bulb made up a little in aesthetic . They are smaller then the original bulbs but then you can have 10 bulbs for the same power consideration of 1 incandescent bulb. and they are dim-able down to 10% or about 35 lumens.
EdurusFas says: May 28, 2010. 11:23 PM
edwinston14,
I'm not sure if this would work - or if it would be green - but here is an idea.  As already mentioned - a dimmer switch -- then maybe see if the same type of LED bulbs used for car's headlights could be modded to fit into the fixtures?  I don't know the specs for those type lights - but if I'm not mistaken, the highest voltage for the bulbs would be approx 12 volts.
Good Luck!
P.s.  Very clever saving a LOT of money on the fixture.  Kudos to you! :)
lasersage says: May 26, 2010. 5:52 AM
if you had an even number of bulbs you could put pairs in series.
Wiring all 7 in parallel gives each bulb the full voltage, but if each pair was in series you'd have half the voltage.
It'd be like permanently dimming it by half (assuming lux falls off with voltage uniformly).
It'd probably make the filaments last forever and you'd still get to use those cool giant bulbs but at only half the wattage.
If that's still too bright and power thirsty you could always put three in series but that might be getting too dim.
Just an idea, speak to your electrician if you're uncertain.
Combine Clite says: May 26, 2010. 5:45 AM
Nice
JohnJY says: May 26, 2010. 4:21 AM
 Could you do this to hook up 1,369 filament light bulbs to your roof?
boarder2k7 says: Dec 4, 2008. 10:59 PM
One addendum to your instructions.... Don't cut the cord that close to the plugs!! Leave yourself a couple feet and toss them in a drawer to use for a different project when you need a plug!
Morganbarker in reply to boarder2k7Feb 15, 2010. 7:20 AM
(removed by author or community request)
kiaas in reply to MorganbarkerFeb 21, 2010. 12:04 PM
You seem to not consider the possibility of -replacing the entire cord- with it, which really should work just fine..assuming the requirements of the application are about the same.
YAMAHAMMER in reply to boarder2k7Dec 7, 2008. 9:02 PM
NOW THATS THINKIN! LOL
boarder2k7 in reply to YAMAHAMMERDec 7, 2008. 10:17 PM
haha I always end up needing those plug ends for something, and I never have them around when I need them....
pirateaboard says: Feb 19, 2010. 8:12 AM
If you want to make it eco-friendly I'd recommend using LEDs.  I attached a picture of a few light bulbs that I installed LEDs inside of.  I broke the back off of the bulb and put a warm white 1/2W 10mm LED inside of each.  If it was used for lighting a room (as opposed to accent lighting) then I'd go for a 1W LED and build a larger bundle.
tommywiles says: Feb 14, 2010. 2:34 PM
i'm trying to recreate this but i cannot loosen the nut that you mention. It looks easy but it isn't working at all. Can you eleborate on this step? Is it a snap or a twist?
edwinston14 (author) in reply to tommywilesFeb 14, 2010. 9:15 PM
It is a twist. I think I had to use the pliers; could not start them by hand.
jacob2die4 says: Feb 8, 2010. 9:11 AM
i would recommend hanging them with weights and heat them a bit with a blowdryer, that should do the trick and would take about 20mins
edwinston14 (author) in reply to jacob2die4Feb 8, 2010. 3:44 PM
Thanks for the tip. My electrician said I run the risk of damaging the wire inside with weights but have seen it used by may other people.
ttrruu says: Aug 16, 2009. 2:06 PM
I love this lamp! I've also seen the original in mags and was wondering how to put it together at a reasonable (do-able?) price. I'm thankful for all the artistic talent that there is out there, and I want to support them, but I've limited means for the time being.
I noticed you mentioned you wanted to use red cloth wire. I live in Europe where we have 'Habitat' stores which sell it (http://www.habitat.net/pws/landing.html) so for those of you in one of the lucky countries you could always try there.
Again, congrats on the great solution!
1-40 of 138Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
