3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to save a wet MP3 Player, Cell Phone, Camera, PDA, etc.
Step 5Dry (Low risk)
Dry (Low risk)
Dry it as much as you can via paper towel, q-tips, a small brush, and dry it as much as you can.
If you want to use faster, but higher risk drying methods, move onto the next step.
Lay out some paper towel, prop it up on something if you can (airflow), and get as much as you can by hand. Get those Q-tips in the nooks and crannies, and soak up and get rid of as much moisture as you can.
Then all your parts out, put it in front of a fan if you can, and let it dry for 1-7 days, longer is always safer.
I've heard success/failure stories on all of the below (as I failed the first time or so when I tried to dry out my phone).
When you have a lot of heat (Oven, blow drier, dry in the sun), you run the risk of all the things that come with it: melting things, overheating transistors, burning into an LCD screen. I'd highly recommend the slow and steady fan method, but these can work if you don't have the time.
--Laying it out to dry/Fan--
Set it in front of a fan for a 1-7 days (the longer, the more likely EVERYTHING is to be dry and thus work again). If you really can't wait a week, at LEAST wait a day.
Pros: No problems with heat, increased airflow by using a fan, BEST chance to save device.
Cons: Slow.
Risk: Very low.
--Tupperware with rice/paper towels--
Put it in a container, fill it with rice or paper towel for 1-7 days. After 1-7 days, take it out and make sure all the rice/paper towel is out of the phone.
Pros: No heat, the rice/paper towel help pull the moisture out
Cons: Slow, rice can get stuck in your phone and cause problems down the line
Risk: Low
1 comment
Oct 9, 2010. 7:43 PMcoolrobot says:
yeah,i dropped some water on my ipod touch(without knowing) and it somehow went inside(i think by the dock connector) so i turned it on.it turned on,everything worked fine,then after a few seconds the vol. up button reacted as a on/off button as well as the power button.i got scared so i put it on top of a heater and left it there for about2 mins(hoping to dry the water inside),andguess what?it didn't turn on.i put it outside for a couple of mins(winter) so it would stop being hot.yeah,it got cold and still didn't turn on.i left it there for 2 days(on my desk) without touching it and hoping my parents wouln'd kill me.in the end it turned on but the touchscreen did not work.AND THATS MY STORY
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:skinn076
