Here are some methods i use to get 50% more fuel efficiency out of my 2 litre diesel toyota.It sounds impossible to get 50 whole more percent but the internal combustion engine and the way we deliver the power to the wheels is extremely inefficient process, but it is easily achievable.
Before i started driving more efficiently i used to get about 10miles to the litre and now i get about 15 to 16miles per litre.It sounds like nothing extra but do the maths.
previous fuel consumtion at 10m/l = 200miles per 20 litres
new fuel consumption at 15m/l = 300miles per 20litres
so i get another 100miles "from nothing"!
Only about 20% of all the energy in petrol or diesel is converted to motion, the rest is wasted in heat, vibration, noise, which i think is just not good enough and thats why i think that the internal combustion engine is an old technology in need of retirement or at least semi retirement and used in hybrids.
There are 5 steps to increasing fuel effiency:
Resistance
Momentum
Acceleration
Weight
Drivers Attitude
Velocity or speed
Remove these ads by
Signing UpStep 1Resistance
To reduce rolling resistance:
I always fill my tires to their maximum inflation pressure or maybe about 2 psi under,the higher the pressure the less surface area in contact with the road and therefore the less resistance therefore the less energy required to move the car along.The negative side to this is to fill the tyres with too much air,and the life of the tyre will be reduced because it will wear out in the middle of the tread so you need a good balance(usually about 2 psi under the max pressure printed on the tyre)This will probably increase overall efficiency by about 5-10 percent.
To reduce air resistance:
There isn't really much you can do to affect this one because as we all know the vehicle is a fixed shape and we cannot change it.But if say you have roof racks on the car,this can effect the resistance a surprising amount so take them off when not in use.Also a shark fin low profile type aerial is more efficient than a stalk aerial.Taking these off will increase overall efficiency by probably 5%.
Here are a number of tips to save money.
http://www.muni.org/iceimages/healthesd/Fuel%20Efficiency%20Strategies.ppt
If you drive a manual, make sure you accelerate in the appropriate gear, not too low a gear. Gasoline engines tend to be happiest at ~2000 rpm, whereas diesels prefer lower revs, RTFM!
Careful... not 100% accurate - but its easier for the masses to understand. Vehicles that have adaptive control will keep the same a/f ratio while in closed loop (where fuel trim is directly adjusted based on sensor feedback). Certain events will cause the computer to go into open loop (events such has a preset throttle %, detected sensor failure, warm up enrichment programs).
On my last car, this happened at around 80% throttle. I discovered this with a signal monitor attached to my O2 sensor. If you have the money, or know someone with a fancy OBD2 interface (if your car is OBD2 compliant) - you can find out actual numbers and get stored trends out of the box :)
I'm not sure what my current car does - it uses a wideband O2 sensor - so the 0-1v voltage comparator won't work on it :P
Something to add to resistance... Internal resistance plays a HUGE role too. Keep up with oil changes. 3K miles is a little early in my opinion (disturbs oil films too often). But keep oil at the max correct level and use a quality oil. What's a quality oil? Can't say - you'll have to do oil analysis on used oil to see how your motor handles it (this testing costs $20). Also DO NOT overfill. You'd be amazed at the viscous losses you'll have if your crank (or counterweights) is in contact with your oil.
LOWER RPM does not mean HIGHER fuel economy. However, LOWER LOAD is related ;)
I found that in a high gear under heavy load (say final gear at 25mph) - my fuel consumption goes up significantly (and into open loop). Your car's computer takes into consideration engine load (which is measured based on a variety of inputs including throttle %, engine speed, etc.).
Otherwise, you make very good points... weight is a big one, saves a lot while accelerating. Weight is not as big a factor once you're at momentum (that would be due to wind resistance) - but if there's a significant amount of excess weight, rolling resistance may become a significant factor ;)
Also, Mitsubishi published a technical paper on vortex generators several years ago... Apparently, they actually do reduce cD by .006 (for those that don't know, that is in the realm if significant) -- but a damn ugly in my opinion :P
http://www.mitsubishi-motors.com/corporate/about_us/technology/review/e/pdf/2004/16E_03.pdf
1. Coasting out of gear (especially down hill) is VERY dangerous.
2. Keeping the clutch disengaged puts extra wear on the throw out bearing
3. While in gear with 0% throttle -- just about every car nowadays will cut back on fuel... Less than fuel required to idle.
Replacing a clutch and getting a clutch replaced are two very different things. If you can DIY - $50-$200 is about the cost of materials (depending on make/model, type, brand etc.). If you are getting it done... expect that to be much higher. My last car cost $400, my current car costs $700-$800 using an aftermarket OE replacement.
Actually, all you'll be saving is your brakes.
By downshifting, and using the engine's drag to slow you down, all you're doing is increasing RPM, which increases the amount of fuel you use. Granted, your fuel injectors will be working at a minimum duty cycle already because you've got your foot off the gas, but minimum duty cycle * 1500rpm is less fuel than minimum duty cycle * 2500rpm.
Your best bet, if you have a manual transmission is to take the car out of gear (which will drop it to idle speed RPM), and coast, and apply brakes as needed.
Granted, this is a tiny bit of fuel savings, but if you do a lot of driving down hills, it could save some gasoline (err petrol).
