Remove these ads by
Signing Up
Remove these ads by
Signing Up
Remove these ads by
Signing Up
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
I am in the industry. (Decorative side of things)
Cold patch products are temporary at best.
To respond to comment about heat needed, yes it should be used if regular asphalt is being employed.
The components of cold patch don't respond to heat like normal asphalt and should not be used.
One tip: If you are going to saw cut the area heat should be used at edges and once warm, take a flat shovel and cut a chamfer on a 45 to give the edge a shoulder. Next fill the area as normal and you prevent shearing or dropping lower because of the support of the angled edge instead of a sheer edge.
Just FYI.
However, as property managers are quite cheap they never seem to get around to that sealing step and the hole gets worse and worse each passing day... My place got cited twice for having driveways that were so riddled with holes that the city had to come out and fix them the right way and charge the complex.
