3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to seed a bell pepper - the *easy* way!
I invented this new way to seed bell peppers this weekend. I'm sure I'm not the first person to seed peppers this way, but I've never heard about it.
All you need is a small knife and a bell pepper. If you want to get fancy, you can use both a big knife and a small knife.
Step 1Gather your materials...
You will need:
a bell pepper or similar
a small knife
a large knife (optional)
a place to cut
20 comments
May 21, 2008. 11:53 PMexplosivemaker says:
SAVE THOSE SEEDS!!! PLANT THEM IF YOU HAVE A GARDEN!!!! FREE PEPPERS!!!!
Oct 26, 2010. 3:27 PMMesmerize says:
unfortunately most commercially-grown crops are self-terminating; i.e. the seeds will not grow if planted.
Jun 16, 2009. 11:34 AMrozzie says:
i found it a lot easier to cut around the heart right at the stalk, all the seeds will come out on that you have nothing left inside
Aug 28, 2008. 10:20 AMI_am_Canadian says:
Works like a charm :-) Good instructable.
Aug 16, 2008. 9:50 AMjabbaduhut says:
I saw Ken Hom do peppers on T.v. he just sliced the round portions off the pepper leaving the seeds all together! He must have done it 'like a million times!'
Aug 8, 2008. 8:57 PMthenear1send says:
For all of you who seeded your peppers and are interested in growing your own peppers, check out my instructable. Its pretty fun and easy, check it out!
http://www.instructables.com/id/Propogating_Peppers/
Jul 24, 2008. 12:11 PMchunkynutz says:
You might find it quicker and easier to just stick your fingers in and pull the insides out in one go.. then a quick run under the water tap maybe..
Jan 14, 2008. 11:40 PMDeLorean4905 says:
Haha, "bonus" points if you find a baby bell inside? I de-seed my bell peppers the same way.
Dec 8, 2007. 1:08 AMBurnzee says:
Great idea, here's another. Try leaving the seeds in for cooking,ie, stir fry. Simply cut peppers into strips and go from there.
Nov 26, 2007. 7:46 AMincorrigible packrat says:
I like to cut mine lengthwise, from blossom end to stem end (don't cut all the way through the stem end -yet), to separate the three lobes of the pepper (guess yer just sol if you got yourself a 4 lobe pepper). When wifey tires of the sandworm puppetry (apologies to the late Frank Herbert), I merely cut each lobe off at the stem end, and trim away the whitish pithy crud from the edges of each lobe. Then just slice,dice or eat the wee beggar as it is (ever try buttered rye bread, with a hunk of red pepper inside, sandwich-wise? D-lish!!!).
Oct 14, 2007. 2:51 PMhomonotsohabilis says:
I use a teaspoon, although a grapefruit spoon would be even better.
Oct 10, 2007. 7:53 PMSteveGerber says:
>> frankly, I don't know what this is called The central part of the pepper which bears the seeds (the part you are removing) is technically called the placenta.
Oct 10, 2007. 7:40 AMPatrick Pending says:
To seed, usually, means to plant in order to grow! The correct term for what you are doing is de-seeding. Cheers, Pat. Pending
Oct 8, 2007. 12:14 PMBabyshoes says:
I used to do it it this way, but after some experimentation I came up with an easier way (I find it easier anyway) - will have to take photos and instructablise it the next time I am using peppers for those posters who don't seem to like this method.
Oct 8, 2007. 11:03 AMkillerjackalope says:
done that for years great minds think alike... ah I remember Home economics my teacher hated me cos I never had to scrape a pepper out...
Oct 8, 2007. 7:23 AMFlea says:
I just cut a ring around the top and then twist up. It usually pulls the seed stem out with it. Then I just rinse it out to get any leftover seeds.
Oct 8, 2007. 6:31 AMninjapants says:
You could also use kitchen shears (or kitchen-dedicated scissors) to cut away the sides. I don't like cleaning bell peppers either. I tend to buy the frozen pre sliced variety.
Oct 7, 2007. 9:57 PMtrebuchet03 says:
I cut my peppers down the middle (lengthwise) and then pull out the seeds and pithy white bits out with my hands/fingers :p It saves quite a bit of time (when you have to seed a lot of peppers) as you don't have to fiddle with a knife :)
Oct 7, 2007. 9:56 PMxrobevansx says:
That's funny, that's the same way I do it!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:AncientWays
