But if you know the trick, it's very easy...
This is the trick:....
Remove these ads by
Signing UpStep 1What u need
Remove these ads by
Signing Up| « Previous Step | Download PDFView All Steps | Next Step » |
All Steps Viewing
i tried your method and it works lie a charm
wanted to try the dental floss method but mine was epoxied
Don't try to *lift* the magnets apart. you need to *slide* them apart.
Many have a bit of glue. I used a thin edged chisel, (though it had a dull point, -- dull might be best, not sure) positioned at corner between metal and magnet. Then used hammer to tap on the wedge, and I EMPHASIZE, *tap* -- gently, until the magnet moves. My first magnet, I hit it a bit too hard and had crumbled magnet.
But after that, I realized a gentle tapping, gradually weakened the glue, until the magnet becomes unglued/detached from the under-side metal. I used Lockjaws or vice-grips to hold the metal while I tapped. You will have to position the end of the chisel by holding the tip until you get it into place.
Be careful not to move it -- it's likely to jump up to the surface of the magnet, and you'll have to reposition.
After that...if you have steady firm grasp and a good set of pliers: recommendations:
1) for pliers -- Crescent, w/blue&grey rubber on handle -- they have a 2:1 force multiplier (grip part moves 1/2 angle for ever 1-unit of handle angle), so that really helps in any holding on, and virtually zero risk over over tightening -- but they can slip, so it takes steady grip.
2) Lockjaw adjustable grip-pressure pliers -- these are great, you can set the pressure of the grip -- and it will be the same grip-pressure no matter what size item it locks onto. my friend was amazed when I set it to the lightest tension -- showed that they closed all the way down to zero -- but then stuck my finger in them and closed them -- same tension --next to nill on my finger! Try that with the better known but third option:
3) Vise grips. Whatever kind you are comfy with. I like the newer easy release/no pinch variety. They have the screw on the bottom you adjust for the each exact width -- taking many tries to get it right, but when you do -- dang -- they can crush things (including your magnets if you use them on the magnet.
I'd suggest the lockjaws or vice grips on the metal part. that way you have a firm grip on that and they won't be going anywhere. Then use the force-multiplier Crescents. Position the ends to one side of the magnet (as opposed to putting them over the center or lengthwise). Put them over a side closed to an edge of the metal. Then rotate the magnet so the edge sticks off the edge of the metal. Once you have that done, most magnes can be pried off by hand -- if not, use the piers. But the idea is to slide it off of surfaces -- not pull it away.
And a note of WARNING -- while _most_ of the magnets are not super powerful (though they are alot stronger than household magnets) beware of 15K RPM SCSI magnets from 3.5" disks -- I had a pair separated by thick metal spaces and used a screwdriver to pry them apart. Upon removing the screwdriver, they snapped back together and caught the tip of my finger -- instant blood blister -- *OOWEE"!... Put a cramp in my typing for almost a day after...It could have been worse from what I've heard..
Good luck, have fun, and be careful!
A*a
http://www.wondermagnet.com/images/fpnum2.jpg
