How to setup dual monitors with Microsoft Vista
 by patricksanford
In this instructable I'll be showing you how to setup two (or more) monitors with Microsoft Windows Vista. This is a handy trick to know if you're needing more space to work with and can really increase your productive use of your computer. What we'll be doing is hooking up the second monitor, extending the desktop across the second screen, and calibrating the display. It's all pretty basic and simple to do. If you're experienced with computers then this will seem like a needless instructable to you but if you're unaware of how to do this then it'll be a little bit of an eye opener.
Step 1: What you need
In order to be able to do this you will need a computer with at least two video cards, Microsoft Windows Vista (you don't need this, but this instructable was written for Vista), two monitors, and the cable to hook up the second monitor. I'm using a laptop that has a preinstalled auxiliary video output that doubles as a second video card (the laptops LCD and associated hardware counts as one) so I just used that one. If you're using a laptop then all you'll need to do is connect your second monitor to your external display port. If you're using a desktop then you'll need to purchase and install a second video card.
Sagar Gondaliya says: Mar 7, 2009. 3:34 PM
i need to know how to do it on a pc. not a laptop
cornboy3 in reply to Sagar GondaliyaMar 9, 2009. 1:00 PM
You need to get a graphics card with multiple outputs or multiple graphics cards
JCO72 in reply to cornboy3Oct 9, 2009. 6:23 PM
If your motherboard supports it, you can simply adda a graphics card.
Mattheous says: Jul 29, 2009. 6:49 AM
This may sound like a stupid question, so please forgive me, but how do I check if my laptop has a graphics card with multiple outputs?
patricksanford (author) in reply to MattheousJul 29, 2009. 4:47 PM
The only stupid question is the one not asked! Checking for a video output on your laptop isn't at all difficult. You'll be able to tell very easily be checking to see if there's a port on it that matches up with the monitor cable. Basically, if the plug on the end of the monitor cord fits into one of the ports, then that's most likely the one you're looking for, Additionally, because most newer computers have the ports color coded, the one you're looking for will probably be blue. The image i've included is rather blurry, but the blue thing is the video output port on my laptop, and it's a 15 pin adapter. Hope that helps!
pogo13 says: Apr 18, 2009. 10:16 AM
mine doesnt say personalize anywhere
ReCreate in reply to pogo13Jun 11, 2009. 4:51 PM
Well then it is probably not Vista!
Derin says: Jun 3, 2009. 10:56 AM
If you want a HUGE thing for Virtual Aviation or similar,then you can even try QUAD MONITORS.Seriously though,those gauges take a lot of space!
djfrosty214 says: Apr 25, 2009. 10:26 AM
is there a way to do it an opposite way
N1CK4ND0 says: Apr 21, 2009. 9:26 AM
haha, yeah I've been using dual monitors for a while now, really easy using Radeon's Catalyst Control Center.
Wills42 says: Mar 29, 2009. 10:15 AM
Just did this, and it works! :D Thanks a lot, i've been wondering how to do this for a while. 5/5.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
