Why this style? Because it's the style I like and it's easy for kids to adjust on their own. D-ring buckles have a way of coming undone when you least want them to. It's hard for a little kid to re-thread the end of the tie through them and a pain for their parents to do it for them. It's also easy to tie your hair inside the bow of tie-behind-the-neck aprons. If you're bald, this isn't really a problem but if you're not it hurts just as bad as back in second grade when that jerk Craig McKenna grabbed your braid as you were rounding first base during kickball.
"But a casing is hard!"
No, it isn't. Don't be a nancy. This pattern has only four pieces, three if you cheat and buy bias tape for the tie. Really, it is crazy-easy to make. You can use cute fabric to make a hostess apron or use matching fabric to make a parent-child pair of aprons. Use denim or a masculine print and you've got a great Father's Day present for the dad in your life. Add a pocket if you want, add rick-rack or trim or a heart-shaped lace pocket. The look of the finished apron is up to you. Be creative!
Remove these ads by
Signing UpStep 1Supply List
Adult: 1 1/2 yards of pre-washed and ironed fabric, give or take. You can get by with a little less if you make a shorter tie. I like the tie to be long enough to cross in the back and wrap back around to the front to tie so I can tuck a dishtowel in there for handwiping and such. If you are ok with it tying in back, you'll only need about 1 1/4 yards.
Kid: 1 yard of pre-washed and ironed fabric. A little less if you want a shorter tie.
Paper to make your pattern, pins, thread, a big safety pin, and an iron.
Optional: a 1" bias tape maker, rotary cutter, acrylic ruler, self-healing mat.
Also, first time I've seen the tape maker, wow, all the time I've wasted doing it by hand!!! So cool!
