Step 6Start strippin'
Now's the time to add fun fabric on! I use 2" strips, cut across the grain (from selvage to selvage) for this. You can certainly change the size, but I like it as a standard size and tend to just have a shoebox full of strips leftover from other projects.
Pin your first strip onto one side of the center piece, right sides together, lining up the edges. Stitch at 1/4", which is typically the edge of your presser foot. Clip your threads and press it over. At this point I like to baste the other side down with a big zig-zag in the seam allowance, which you totally don't have to do, but I find that it really helps to have everything nailed down and neat as I go along, then you don't have to worry about it later.
Keep going around the center piece, adding on and overlapping the strips, in sort of a log-cabin block sort of style. Just make sure you keep a constant 1/4 seam allowance, if you go off of that you go off of that it just won't work as well, and you'll get puckers and weirdness.
Add Comment
