3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to silence AND power up a Nerf Maverick
This is my first instructable, so plz don't get upset if it isn't "great". This will show you how to power up your Mav and also silence* it.
* You really can't completely silence a Nerf gun, but this comes pretty close.
Step 1Supplies
What You Need
1. A Nerf Maverick gun
2. A small Phillips- head screwdriver
3. Wire cutters (a small wrench will work too)
4. 3/8" Felt pads (used for moving furniture, can be found at Walmart or any hardware store)
5. A pair of scissors (not in picture, sorry)
6. 15- 20 minutes for both silencing and powering up the gun
41 comments
1-40 of 41next »
May 15, 2012. 6:41 AMpeyton14 says:
i cant get the revolver part apart!
Aug 28, 2011. 1:10 PMbook54321 says:
the air pump brok in mine but I ficsit somhow
Sep 3, 2010. 4:06 AMmeburnfire says:
Umm i need some help, as when i try to pry the gray piece offf the barrel it wont come off. I tried with a screwdriver, hammer, wire cutters, pliers, pencils and all manner of these funny little metal rods i have. WHAT CAN I DO
Jun 14, 2011. 11:24 AMjwood7 says:
if its the grey bit on the black end i had the same problem, its screwed on from underneath. rather than take it off i just unscrewed the whole bottom bit and it comes off with the grey bit still attached :)
Sep 4, 2010. 8:10 PMmeburnfire says:
That dosent work. I got my uncle to help me, hes REALLY strong, but he cant open it either with a hammer, wirecutters, pliers, NOTHING WORKS FOR EITHER OF US
Sep 4, 2010. 8:25 PMmeburnfire says:
If possible, could you please tell me how you "do it right"
May 9, 2011. 11:04 AMctavolazzi says:
If you're having trouble getting the orange ring off, try hitting the metal rod out of the back of the barrel with a screwdriver. Flip the barrel over to the black side, not the orange side, and position a small screwdriver or equivalently sized thing on the metal rod inside the other orange ring. Hit it out using a hammer to drive the screwdriver. Mine came out very easily this way.
Jul 12, 2010. 8:14 AMKing Julien says:
Does the silencing work? It would seen so. I will try this with my mav.
Apr 2, 2011. 7:48 PMTHECHINABOY says:
it hardly sileces it. but now plastic dont hit plastic as much.
Jan 19, 2011. 2:56 AMaj69 says:
i undone the un only with a knife.
Jan 19, 2011. 2:53 AMaj69 says:
ok thanx now i no wat to do.
Jan 18, 2011. 1:31 AMaj69 says:
can somebody please tell me wat the rod thingies r im not much of a moder so could u explain a little bit easier.
Dec 31, 2010. 1:58 PMFamoosh says:
I had the same problems as well. Im wondering if new versions have the metal rod glued or melted to the plastic. In any case, just a penny mod still bumps the range up hugely, so I dont need to take the Air Restrictors out yet.
Jan 16, 2011. 10:45 PMFamoosh says:
I actually got it out, after I had my dad over and he kept badgering me that it wasnt going to come out, yadda yadda yadda. Anyway, had to use a vice, but got it out. Maverick now shoots Clip System Darts 60feet, whistlers at 50 and suction at 45, and all I did was penny mod (four of em) and AR removal.
Jan 15, 2011. 6:29 PMmanuel846 says:
My maverick lost power when I did it.What should I do?
Dec 23, 2010. 1:58 PMtaowyman says:
when i took my gun apart i lost all my screws except for one before i read this
Dec 23, 2010. 1:39 PMtaowyman says:
hey that silence thing really works THANKS!
Aug 16, 2010. 7:47 PM[corosive] says:
very cool power up. does anyone know if there is a way to silence it after powering it up? after the power up, mine just makes a loud bang when firing.
Aug 2, 2010. 10:22 PMcannibal_hect0r says:
I've heard replacing the spring with a stronger one also increases power. anyone know if this is true?
Aug 14, 2010. 2:02 AMcraig3 says:
yes very, but if you put one in that is to string, the plastic holding the metal rod in the cocking mech will break
Jul 11, 2010. 9:28 AMdarknessfalls says:
when i removed the prongs from my mav i got a snapping sound... does the "silencing" help with that issue?
Jul 12, 2010. 6:30 PMdarknessfalls says:
hmmm well mine did it about half the time there was darts so i reassembled it with the prongs....
Jul 11, 2010. 8:14 AMSaturn V says:
Does removing the air restrictors really work? I have seen on many sites that this mod doesn't work, and it makes the gun worse.
Jul 10, 2010. 7:03 PMubcrazy2 says:
the silencing works. I went to this guys house and he did this silencing mod and it works.
Jul 9, 2010. 4:53 AMAPunchInTheTeeth says:
I recently did a power mod on my Maverick, the only problem was that it made it ridiculously loud. So i'll definitely try the silencing. Great I'ble!
Jul 6, 2010. 3:25 PMbillybenj says:
good job, the air restrictor removal isnt anything new, but the felt pad thing is kind of interesting..
1-40 of 41next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:Maverick REV-6
