How to sneak booze into the Kentucky Derby (or a concert)
 by Gunner_sc
Contest WinnerFeatured
Step 2: The honey hole
The best part about buying a cooler used is that the bottom is already scratched up. This does you a favor in camouflaging the cuts you'll make in the bottom of the cooler.
Flip the cooler over and note the most scratched up parts.
Using an exacto blade, utility knife, or other razor blade with a handle, cut into the outer shell through about the middle of the scratched parts. If you just use a knife the gap might be just a little too big.
A) Be careful not to cut your finger off. If you cut your finger off you're gonna have a bad time.
B) The cut doesn't have to be deep, but try to make the cut straight.
C) Have patience. Go slow. Be careful. Win.
tydymiler says: May 24, 2012. 10:16 AM
Hello fellow redditor.
ccopyrites1986 in reply to tydymilerMay 24, 2012. 1:01 PM
hahaha yes... i was thinking the same thing
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
