Introduction: How to Softmod Your Xbox...for FREE
Picture of How to Softmod Your Xbox...for FREE
This instructable will show you how you can convert your normal xbox into a super crazy multimedia, avi , mp3 playing GOD...All without a mod chip...This also allows you to still be able play on xbox live. All you needs is a computer, a cd burner and a torx 20 screwdriver: will go into this in a later step.
**NOTE: I am not responsible for any damage that may be caused while attempting anything in this tutorial. If you attempt in doing this, you do so at your own risk. If something gets broken, it's only your own fault and you should not blame anybody. Please notice that according to ANSI standards, hotswapping is not considered safe and is therefore only recommended if you cannot find another way to modify your Xbox.:**
Do everything in this video and much more:
Step 1: Materials:
Picture of Materials:
Xbox
Desktop PC with an ATA connection NOT SATA
CD Recorder in your PC
Blank CD-R
ISO Recorder v2(Or any other program to burn ISOs to cds)
WinRAR or the very awesome and free 7-zip
XboxHDM v1.9 (Scrow down to download it)
Kingroach's NDURE 3.0 (Scrow down to download it) or go here NDURE 3.0
Torx 20 Screwdriver for opening the xbox
Whatever is needed to open up your computer case
Some intelligence and patience
Download the necessary files from above. Install ISO Recorder and WinRAR. After WinRAR is installed, use it to extract xboxhdm.
Step 2: Create Boot Disk
Picture of Create Boot Disk
First - Find your xbox's kernel and dashboard version...To do this, boot up to the MS Dashboard, go to Settings, and the System Info. After the scrolling text, you should see this at the bottom.
Note: It is recommended to update your dashboard to MS Dash version 5960. While this may not be necessary for everybody, this tutorial will not work for people who have the 4034 dash. To avoid any and all problems, upgrading the dash to 5960 is highly recommended because nobody should have problems if they are running that dashboard. This softmod works perfectly with the 5960 dashboard version.
To update your dashboard, you can use any newer (post-Halo 2) retail Xbox LIVE game. You don't have to have Xbox LIVE, you don't have to have an internet connection, and you don't even have to have a network cable plugged into the Xbox. Just load up Halo 2 or any game made after that, select Xbox LIVE, and it will proceed to upgrade your Xbox dashboard.
K:1.00.XXXX.01
D:1.00.YYYY.01
Second - Run NDURE 3.0 program...click next and you should see this screen:
Ndure Options
First, I will briefly explain what each option does.
Basic Files - These are the basic files and are required for the softmod to function.
Retail Files - These are the files necessary so that you can have MS Dash access. Most people should leave this checkmarked, the only people who would not need this are people who do not have Xbox LIVE and have no need for the memory and music functions of the MS Dash. You dont gain anything by leaving this box unmarked, so you might as well include it.
Shadow C - Recommended for all users, because it prevents your Xbox from dash updates overwriting the softmod.
NKPatcher Options
NKP .67 - Use this if you have a hard drive over 200 gb, this will create a G partition.
NKP RGB - Use this if you are going to use the Xbox primarily with VGA output on a computer monitor (Only works with Focus video encoders)
NKP Progressive - This forces 480p for anything that attempts to run in 480i.
Kernel Specific Fonts - These fonts are designed to work exclusively with a certain kernel version. It is recommended to use a kernel specific font, as it should prevent any problems and provide an incredible level of stability.
Default boot xonlinedashconsole - Enabling this option will set up the dualboot feature. When the Xbox is powered on by using the eject button, and the softmod detects an open disc tray, it will boot to the Xbox LIVE Online Dash. In this screen, you can manage all of your network settings, as well as manage Xbox LIVE accounts.
UDDAE - This is a backdoor rescue dash that is based off of the Easter Egg Exploit, the uberdash, and an audio exploit. The thing about UDDAE is it allows you to completely turn off your softmod, going to a retail, unmodded state.
Now, once your softmod is deactivated, how are you going to activate it? In order to switch it back on, we need to change some files around on the Xbox, and we can't mess with the files in an unmodded state. Basically, the problem lies in we need to have it modded in order to 'turn on' the mod. Which really makes no sense.
This is where UDDAE comes to the rescue. Even with the softmod deactivated, we have a way to run homebrew code through a set of actions in the MS Dashboard. While this is a great feature for advanced users, it will not be used by the average user, but it doesnt hurt anybody by installing it. If you are interested in this, you can read up on SCEEE HERE and UDDAE HERE.
Ndure Toolset - This is a set of tools designed by kingroach to help with your EEPROM backups and other maintenance. It is basically a simple menu that helps you to protect your softmod and keep it running smooth and provides you with the information needed to save your Xbox if anything goes wrong. Just another way kingroach looks out for his users and wants to make them feel safe. While I have never personally used this, I would recommend installing this.
Create XBOXHDM Installer Obviously, we want this enabled, as this entire tutorial is for installing NDURE with XboxHDM.
My Setup goes like this: (X equals a checkmark)
X Basic Files
X Retail Files
X Add ShadowC
+ Kernel Specific Fonts
X 4034 (You would choose the number of your kernel that you found using System Info at the beginning of this tutorial I told you to write it down)
X Default boot xonlinedash console (because I have Xbox LIVE)
+ UDDAE
X Add UDDAE
+ Select Kernel Specific ST.DB
X Add NDURE Toolset
X Create XBOXHDM Installer
Step 3: Create Boot Disk 2
Hit next and it will ask you where you want to save your NDURE folder. Save it to /xboxhdm/linux/ , which is wherever you extracted your Xboxhdm ZIP archive you downloaded earlier. Hit Install and wait for it to finish. When it is finished, the last line will say Completed and you can hit Next, then Finish to close out of Ndure.
First, you must download the updated script (at the bottom of this step). When you save the file it will ask you where you want to save the file and what do you want to name it. It may add a .txt or .htm or .tmp file extension to it, so you will have to delete the file extension so it is just ndure. *Make sure your have explorer set to show extensions.*
Save this updated ndure script file to the /xboxhdm/linux/ndure/ folder. Since there is the old script already in there, it should ask if you want to overwrite. Say yes. If it doesn't ask you if you want to overwrite, please check the /xboxhdm/linux/ndure/ folder and make sure you named it just ndure and not ndure.htm.
Go back to the main xboxhdm folder and you will see a bat file titled make-iso-win. Run this, and wait for it to finish making the ISO. You should now have a new ISO file in the xboxhdm folder titled linux.
All you need to do is insert a blank CD into your CD Recorder and right-click the linux ISO File and hit Copy Image to CD. Just hit Next on the burning screens and wait for the recording to finish.
Step 4: Opening Your Xbox
Picture of Opening Your Xbox
Take your xbox, disconnect anything and everything from it and flip it on it's back.
Now Peel off the corner plastics (see picture 2) and poke through the plastic to unscrew all 6 torx screws.
Flip it back careful not to let it open and when you have it on same ground lift the top part of the case off.
Now in order for you to hot swap your xbox you will need to move your xbox as close as possible to your computer. With the case off connect the power and video cables back on.
You have both the Xbox and PC hooked up as normal. You will use the Xbox power supply to supply the power to the Xbox hard drive.
DO NOT DISCONNECT ANY CABLES FOR NOW
Step 5: Booting From Cd
Picture of Booting From Cd
Go into the BIOS and set your PC to boot on the cd drive.To check this, restart your computer. When it starts up, you will have to hit a key in order to enter the BIOS configuration screen. Usually it will say on screen to Hit key to enter Setup. Watch for this. If you cant see it anywhere, I have listed the following BIOS config keys for some computers.
Acer: - Ctrl+Alt+Esc
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
Compaq: (F10) (do this when the cursor is in the upper right corner of the screen blinking)
Dell: - F1 or Del.
Dell: - Some require pressing reset twice
Dell: - Ctrl + Alt + Enter
DTK BIOS: (Esc)
Gateway 2000: - F1
Hewlett Packard: - F1
IBM:
" Older Models - In order to get into the configuration of the IBM setup screen (CMOS) screen you need to hold down both mouse buttons during bootup.
" Aptiva - Press F1
" IBM PS/2: (Ctrl)(Alt)(Ins) after (Ctrl)(Alt)(Del)
" IBM PS/2 with reference partition: - Press Ins during boot
" Some PS/2s, such as 75 and 90: - Ctrl Alt ?
" Some PS/2s when pointer at top right of screen: - Ctrl + Ins
NEC: - F2
Packard Bell: - F1 or F2
Phoenix BIOS: (F1), (F2), or (Ctrl)(Alt)(Esc)
Phoenix BIOS: - Ctrl Alt S
Phoenix BIOS: - Ctrl S
Phoenix BIOS: - Ctrl Alt Ins
Sharp Laptop 9020: - F2
Sony: (F3) while you are starting the PC, then (F2) or (F1)
Tandon computers: - Hold down the key after turning on power
Tandon: - Ctrl + Shift + Esc
Toshiba Laptops: - Toshiba Utility
Toshiba: - Press Esc during boot
Toshiba, Phoenix, late model PS/1 Value Point and 330s: - Press F1 during boot
Olivetti PC Pro: - Shift Ctrl Alt + Num Pad Del
Miscellaneous PC's: - Ctrl + Esc or Ctrl and Alt and +
Zenith: - Ctrl Alt Ins
MAKE SURE THE FOLLOWING ARE GOOD TO GO:
PC is set in BIOS to boot from CD
My xbox is close enough to my computer that the primary master cable can reach it.
My IDE cable that will be used for hotswapping is connected to the primary IDE channel.
My CD/DVD drive is connected to anywhere but the primary IDE connection.
My primary master IDE connection is vacant, as this is the one I will hotswap the Xbox drive to.
Softmod Time!
Make sure your XboxHDM disc is inside your CD/DVD drive. Boot up your Xbox and PC at the same time.
Your Xbox should go to the MS Dashboard.
and
Your PC should go to the XboxHDM main menu.(See picture 2)
Step 6: The Art of HotSwapping
Picture of The Art of HotSwapping
Hot swapping is the act of allowing the xbox to unlock the hard drive, so that you can gain access to it, by connecting it to a PC. It involves removing the IDE ribbon from the Drive, while it is power on.
Ok so you removed the xbox top (using the 6 Torx screws on the bottom) and set this as close to the pc you can get it. ATTENTION The Xbox must have the Video Molex connector connected to the xbox to unlock the hard drive, IT HOWEVER doesnt need to be hooked to the TV, just the xbox.
For a hotswap to be successful the Xbox hard drive needs to be unlocked. This can be done by simply doing this:
- put an audio cd in the xbox
- copy one track to the hd
- play the track from the HD, let play for a few seconds
- pause the song
- you HDD is now ready for hotswap!
More ways to unlock the drive:
1. Let the Xbox sit at the dash for a little while and then hotswap
2. Play a music track off of a soundtrack, pause it, then hotswap
3. Boot a game and start playing it, then hotswap
4. Unplug the DVD drive's power cable so you get an error 12 and hotswap
5. Hotswap right after you see the MS splash logo
6. If not connected to a TV, unhook the DVD drive's power cable and hotswap right when you get the red light.
Imagine this if you can:
You have both your computer and your xbox next to each other. The xbox is open so that you can easily disconnect the cables inside. Now turn on both your computer (the primary IDE slot should be empty and the secondary slot should be with your cd drive) and your xbox. You should be booting your computer from the ndure cd. Now once your xbox finishes loading, go to the music tab and play a song for 5 minutes. After five minutes disconnect the IDE cable from the back of your xbox and connect it to the primary IDE slot on your computer BUT DO NOT TURN OFF THE XBOX or DISCONNECT THE POWER CABLE from the xbox hard drive. Now on your computer type xbrowser and see if your computer is unlocked.
After making the swap, type 1 on the keyboard to enter the VGA console. (1 and 2 are basically the same thing) After the scrolling text, you should eventually end up at a screen like this(Picturte2):
Type xbrowser and you should see a screen that looks like this:
+<-/CD/----------------------------------------------------v>++<-/xbox----------------------------------v>+
|              Name                      | Size       | MTime         ||      Name     | Size        |   MTime       |
|/..                                            |UP--DIR|                       ||/..                    |UP--DIR |                      |
| ABOUT_THIS_CD.txt        |      1392|Apr 14 17:48|| C                   |       4096|Apr 14 17:48|
| C                                           |      4096|Apr 14 17:30|| E                   |       4096|Apr 14 17:48|
| E                                           |      4096|Apr 14 17:30||                       |                 |                      |
| eeprom                               |             0|Apr 14 17:30||                        |                |                      |
| F                                           |      4096|Apr 19 02:13||                        |                |                      |
| check                                  |       6013|Apr 18 21:47||                        |                |                      |
| isolinux                               |      4096|Apr 14 17:30||                        |                 |                      |
| ndure                                  |                |                       ||                        |                 |                      |
| readme.txt                          |                |                       ||                        |                 |                      |
| xbox                                     |                |                       ||                        |                 |                      |
GNU Midnight Commander 4.6.0
1Help   2Menu   3View   4Edit   5Copy   6RenMov   7Mkdir   8Delete   9PullDn   10Quit
Go into thendure folder and you should see this screen(Picture 3):
Hit enter on the *ndure script and you will be presented with the NDURE Installer Menu.
First, you will want to backup your C drive. This is very important. So choose Option 4 to backup your C drive to E:/backup. It may take awhile, but let it finish. When it's done, it should go back to the installer menu.
Now, we're ready to install Ndure. Select option 1 to install ndure. It will proceed through the 3 parts. Be patient, this process takes a long time (around 15 minutes or more). Part 2 takes the longest. Even if you think it might have frozen, let it go. There have been many times where I was wondering if it had froze, and then just see it finish up.
After all 3 parts, it should give you a message saying "Done, now exiting". At this point, you can turn off your computer and turn off your Xbox. Connect the hard drive back into your Xbox, and if everything went well, you now have a softmodded Xbox running Kingroach's NDURE 3.0. And the best part about all of this is it was free!
Step 7: Now What?
Picture of Now What?
Turn your xbox on for the first time and it will behave the same.
To run the softmod:
In the xbox dashboard go to Music,
there should be a blank soundtrack,
Copy>Select>Copy>New Soundtrack and name it (SEE PICTURE):
(with two '<' Symbols, capital 'E', beta Accent '�' and two '>' Symbols) click Done
(UberDash starts)>Music>blank soundtrack>Copy>Copy>New
Soundtrack>Done
THIS VIDEO EXPLAINS EVERYTHING FROM ABOVE:
I would advice that you backup basically, everything. First, launch EvoX, go down to System Util, and hit Backup. It will look like it didnt do anything, but rest assured that it did. Now, FTP into your Xbox and backup your entire C and E drives to your computer and keep it safe.
Do add applications simply FTP to your xbox and drag those illegal files on the E drive with FileZilla.
Here are some pages i used (copied/stole) from, everybody should read these:
Total N00b Guide To Everything
HotSwap Faq
FTP
NDURE
If you want to replace your dashboard with a media center dash simply download XBMC from below and replace the files in your E:dash folder...
****Where to get XBMC? HOW or latest T3CH release from here: T3CH
I finally go to purchasing an HDTV and had trouble getting XBMC's resolution to change. Here's what I did:
1. Create a file in the root of the E:/ drive and title it "EEPROM_off.bin" without the quotes. It can be any size.
2. After creating the file, manually reboot your Xbox by powering it off then back on by using the power button.
3. When the softmod loads back up, there will be no virtual EEPROM protection, so you can change your video settings and they should stick from now on.
MaxM123 (author)2016-06-05
nothing works for unlocking the hdd, i always get no xbox partition found on ...
Antonio96 (author)2016-03-09
i cant tell if it worked for me. the power light is solid orange and everything seems to work except when i type in <<EggsBox>> it just shows me the creators of xbox like the ending credits of a movie and then it reboots. everything looks the same, shouldnt it look differant at all?
andrewh244 (author)Antonio962016-04-29
I have the same issue. when i installed ndure, i checked the box for kernel specific fonts, and not the individual one, which i think is causing it. also, make sure you have the proper caps and accents for <<EggsBox>>. Now, im gonna delete everything on the hard drive and try this again.
srdjang2 (author)2015-12-06
i have pc with sata cables so i was trying to connect xbox hard drive with usb external rack for dvd/hard drive.But when i boot from cd and write xbrowser it tells me "Linux CD not found".I didnt do anything with idle cable in my pc
KeithH14 (author)2015-08-06
Worked liked a charm great tutorial. Modded 2 xboxs so far and got three more lined up. Bought one at the DI for 25 bucks and modded it out with this and now its running with a 250 gig hard drive with several games on board. Cor those looking to download games google is your best bet. Most games are 2 to 3 gig downloads but once downloaded all thats needed is to ftp them to you gamea folder. I use F:\Games for mine, reboot the xbox and I can select them from the games tab and play away. I can also copy game discs as well. If your going that route though upgrade the hard drive because the original hard drive can hold maybe one game.
Kynis (author)2014-04-01
Hey, thanks! This worked perfectly.
I just have a few questions (if you don't mind):
Do I really have to use the easteregg exploit each and every single time I want to acces unleashX?
and (a bit more complicated one):
My xbox works perfectly, outputs sound/video (trough compostie/scart), runs games, the softmod works etc. but after the console boots to the ms dash the console's power indicator turns orange (solid orange, no flashing) and the fans start to make noise. I also have noticed an electrical noise coming out of it, but when I tried to search the internet about "solid orange original xbox" i literally found nothing. This started to happen immediately after the softmod was complete.
I'll swap the HDD to a bigger one next weekend and I'll see if it's the hard drive but I would appreciate any information about it.
robnjin10 (author)Kynis2015-03-03
Try moving your video cables away from appliance cords. They should not cross. Run them up and down without crossing. You should notice immediate results if it is the humming noise i think it is. Orange light could be the kiss of death red ring i keep seeing
Xtracomputerguy (author)2015-02-16
i dont work, when i boot the cd and select 1-2 options and its loading then my computer beeps and says this:
feeblington (author)2014-12-16
error 12 means the DVD isnt connected properly....push all the leads in again should be fine mate
I have modded my old xbox in a similer mannor and its now 120gb home media center......the old xbox's are awesome to mod
BadZombie (author)2014-09-27
I don't know if I can change my drive, any suggestions on what one I should get?
I should try something like this to my xbox.
lsmile (author)2014-07-03
Okay, I have a bit of a problem.
The softmod works fine and all, and worked great when the Xbox was all gutted, but once I screw everything back in I get the blinking red light and the service error (error 12??). I don't know how to fix this, or what's causing it, but maybe someone can help?
djremix71 (author)2009-06-26
For those of you having trouble getting your computer to recognize the xbox hard drive do this: Have the IDE cable you are going to use plugged into a separate hard drive and boot the computer and the xbox. Follow the normal unlocking procedures on the xbox end (aka: copy music file and play it). Unplug the IDE cable from computer's hard drive, and plug it into the xbox hard drive. Then do everything else like normal. I could not get my computer to recognize the hard drive until I did this and I suspect this would fix the problem for you.
lsmile (author)djremix712014-07-03
This is the only thing that worked for me, thanks!
Having an extra HD to switch with helped a whole lot. I kept getting errors on the drive being found, but this process worked for me. Wish I could have tried this earlier after hours of trying to figure it out though.
JGridlock (author)2013-11-20
Alright, so here is where I am stuck. Someone please post a reply! After all the linux messages I get the following..
"Found HardDrive.
We will now search dev/hda for an xbox partition table...
No xbox-partition table found on /dev/hda
Done!!!"
Is this issue caused because the hard drive is still locked?
Ghostprototype (author)JGridlock2014-02-18
See my other post for a possible solution.
I'm afraid I can't quite remember the context in which i received your particular error so I'm not exactly sure of the cause.
It's worth noting that of all the steps in this complicated process, the unlocking/hotswapping part was the most trouble-free for me! It seems that once it's hit the dashboard, it's pretty much unlocked, playing a track should ensure it though.
It's just my experience, but I think it's much more likely to be a misconfiguration (not helpful, I know) than the drive being locked.
Ghostprototype (author)2014-02-18
Hi, thanks for the great guide!
I got it to work but it wasn't exactly smooth sailing so I'll try to be as thorough as I can for the benefit of others with similar problems.
I can, of course, only speak for my particular hardware and BIOS and it may not work on other machines but it may help nevertheless.
Issue:
My main pitfall was the "Linux CD not found" error when trying to access xbrowser.
As I went through different configurations I even received an error where I was told that I had no disk drive connected!!
I occasionally got the same error as JGridlock aswell ("No xbox-partition table found on /dev/hda") but assumed (perhaps incorrectly) that they stemmed from the same issue.
Other errors I encountered were errors 10 & 20.
My (working) Configuration:
I have a Pentium4 "Acer Power FV" with a single IDE port on the motherboard and a two-port IDE cable; my BIOS is a 2005 American Megatrends (R01-C4).
Note that I used ONLY the IDE connection, no SATA or USB etc...
I used the cable's port nearest to the motherboard for the Xbox harddrive and the end-port for the DVD-drive. I set the jumper on the Xbox-HD to master and the jumper on the DVD-drive to slave.
I set the DVD-drive to boot first in BIOS.
When it came to hotswapping I played a music track for a few seconds (and then paused it) each time and never encountered any apparent problems.
My solution:
As it turns out, it was a BIOS issue, or more specifically an issue with the "ATA/IDE Configuration" (something I was previously unfamiliar with).
I solved it by going into the BIOS and under the heading "Standard CMOS Settings" changing the ATA/IDE Configuration mode from "Compatible" to "Enhanced". There should also be a menu that shows all the IDE devices that are currently connected to the PC.
After a restart the BIOS detected the DVD-drive (and the xbox harddrive, if connected) as Third IDE Slave & Master, respectively (rather than Primary or Secondary, for some peculiar reason).
After this I was able to hotswap as usual and reach the xbrowser window.
I encountered no further problems and was able to install ndure thanks to this fantastic guide and I hope this helps others in their quest to mod this now-ancient console!
cody777 (author)2012-11-23
What do i do if my primary master for my board is a sata?
andwan0 (author)2012-08-13
Anyone know how to un soft-mod XBOX if done via this method?
ssetnicky (author)2011-03-21
I tried to download NDURE 3.0 and Avast! says it's a Decompression Bomb. I'm not touching that file!
acain3 (author)ssetnicky2012-06-29
I agree with Jas, I have use NDURE many times on multiple systems safely. I'm a paranoid IT Support Volunteer so I try to keep my system locked up tight. You may have just got a bad download, it happens.
jas330 (author)ssetnicky2011-07-30
i have avast nothing happended so its prob safe i also scanned it with mcaffe and avast
dfalk (author)2012-04-27
Nice!, I think I will use this! :) I have 2 Xbox's I don't use.
stevedelarosa5879 (author)2012-04-02
dude i cant understand the process. could u send the by the numbered instruction here stevedelarosa5879@yahoo.com. thanks!
Hanjin (author)2009-11-18
sweet worked perfectly
stevedelarosa5879 (author)Hanjin2012-04-02
MrAlekos (author)2012-02-26
Hey guys i have made all the necessary work (burn cd ,conect xbox) and i when i go to the point to write (xbrowser) i am writing it tells me that i need to put the linux cd... WTF?? (looking for cd.Incert linux cd)
Please help me...
liquidice (author)2012-01-30
after suffering for hours trying to unlock my HDD, I figured I would tell everyone what I've learned and what this tutorial doesnt mention. Ive learned that if you swap the IDE cables AFTER your PC has booted up, it wont detect the xbox drive.
1st step: unplug dvd ribbon on xbox.
2nd step: turn on PC, boot to your bios (we're doing this so the pc wont boot all they way yet)
3rd step: turn on xbox and the instant u see the red ring, unplug the IDE for the hard drive (be fast, yet gentle), then plug in ur primary IDE from PC. if it didnt work, u were either too fast or too slow, try again.
4th step: exit bios, let PC boot to CD. Then press 1, type xbrowser. if all goes well, u should see a directory of files on the xbox hard drive.
5th step: finish tutorial, and crack open a beer, you earned it ;)
if this tutorial had mentioned to connect the pc-xbox BEFORE the PC posts, I'd have saved me a few hours and a headache >.<
dfalk (author)2012-01-21
Does I need a game to do this?
saucygamer (author)2011-11-04
This worked for me but there were a couple of tips I want to share: first off, be sure the CD/DVD disc you burn is readable by the drive that is installing NDURE. Not thinking, I used a 10yr old drive and it failed on a couple of critical files and I had to rebuild my XBOX hard drive and do other nasty stuff.
Also, for me, generating error 12 was a great method to unlock my hard drive but it can be tricky to get: dont pull out the DVD drive cable until about halfway through the startup animation or you will instead get error 11 and the HDD wont be unlocked.
cowboymiller (author)2011-10-26
hey guys, i hope people are still reading these comments.
So i followed the tut to the T the first time and it worked like a charm (minus using a diff method to unlock the drive)
Got myself a 250gb drive, and aout 50 of my Fav games on the drive along with a dedicated FTP stream of movies for the XMBC. its amazing.
So i thought i would get a couple cheap xboxs and do this to them for the rest of the house (lots of kids)
I felt confident i had memorized the entire tut so i proceeded with out it on the 1st xbox. low and behold it didn't work, unlock worked, install of ndure work however when the box restarted, i only got the splash screen then a black screen.
it will play games from the CD still but will NOT boot without a GAME in the drive.
Still able to unlock the drive and access is it from the boot cd with the browser, but when i try to restore from the backup, it errors saying either no disk space OR read only file system. So not able to restore from backup, then with out thinking, i tried it again and it wiped out the backup and created a backup of the broken system.
after racking my brain for weeks i realized that i had totally used the original BOOT CD i had created which I'm guessing was the wrong kernel.
This is Xbox 2. is there ANYWAY to fix this HD?
This brings me to the 3rd xbox, i discovered the problem with the kernels AFTER attempting the same thing on the 3rd box. so kinda in the same delima however this one is still unlockable but ill NOT boot to any game or theHD, just a service 21 error. When i look at the drive with the browser i can see the backup is still intact but will not let me restore it, giving the same disk space error or READ only error. Is there a way to fix this one?? please if ANYONE has some answers that would be great. other wise its a loss of $100 on my part. Expensive mistake I'm trying to fix. i did however get a lot of games and accessories out of that $100 hope to hear from someone.
bbear4 (author)2011-10-15
It worked for me! Thanks for making it vzjrz
b37ho (author)2011-10-11
i have a problem whit my xbox classis, how to install software in new hardisk in xbox classic. PLEASE HELP ME, Thank`s
Pinny89 (author)2011-10-06
PLEASE someone help...
i follow the instructions to the letter, my XBox HDD is unlocked etc. i made the boot disk with the ndure script and when i enter XBROWSER i see the ndure script there but when i try to start it, it just says "no such file in directory"
i tried to make the ndure script into .exe, .bat, nothing works, just the same old error... but when i hit F3 i can view the script and i can edit it...
please help, im loosing my mind trying to figure this out :/
pspuser924 (author)2010-01-05
I couldnt get it running until i read this:
easiest way i found to unlock the drive is to disconnect the ribbon from the dvd player and also its power cable.
use a molex from your pc to power the xbox HDD.
now boot the pc into xboxhdm and turn on the xbox.
once the xbox has booted it will give you the "xbox needs service" screen, when this shows up you need to swap ata cables.
dont do it like the tut suggests as i tried all ways mentioned and it just would not unlock, my way unlocks first time everytime.
adamvan2000 (author)pspuser9242011-10-05
This worked awesome, dude! Thanks for the helpful tip. On my way to having an xbox linux server. Bwahahahahaha! in yer face, MS!
bkhabir (author)pspuser9242011-09-13
Please how can i vonvert my x box so that i can download game to it.... Please help me out
tylerwatt12 (author)pspuser9242010-07-05
wow. that actually works cant believe it. i tried every other method... and not having an xbox controller with me didnt help either lol. i found this xbox in the dumpster XD
thellt (author)tylerwatt122011-02-05
well hello tyler i found you lol. its helti.... im moding my xbox 2. XD
tylerwatt12 (author)thellt2011-02-06
need help?
pspuser924 (author)tylerwatt122010-07-05
It's sad how these perfectly operational systems end up in the dump. They make an awesome dvd player.
sonicfan10312 (author)2011-09-09
i find it funny when people think macafe and avast are good avg hasnt said a thing.
bkhabir (author)sonicfan103122011-09-13
Hello..... Please i am tired of buying disc on my x box can you please help me out i really want to know how to convert it and download games on it and the software to down and steps to take please if any suggestion mail me into my mail bhakhay@yahoo.com
pspuser924 (author)bkhabir2011-09-28
Follow the tutorial, don't get frustrated, and try snesorama for the games.
bkhabir (author)2011-09-13
noizetank (author)2011-09-06
HI Guys
I have managed to lock my deagate drive, followed all your instructions and half way through hotswap (After Ihad saved C drive) the processed errored and stopped.
Now I get red lights when i turn XB on. How do i sortr this out, and what could have gone wrong?
Thanks in advance
acevell (author)2011-07-16
Ok I made a bad I installed it all correctly but I may have deleted my m$ dash file because I can't return to the ms dashboard when I hot swapped I made a back up my question is can I restore the xbox to retail state with the back up?if so can anyone fill me in on how?Thanks a million
hansley (author)2011-07-10
my cd didn't boot why? help plzz!thx
theend757 (author)hansley2011-07-10
Did you follow the guide to make the ISO. What software did you use to burn the ISO?
jsleight (author)2011-06-09
I somehow broke my dashboard doing this. Is there anyway to fix this? I got errors when it tried installing ndure onto the xbox and then the next time i turn it on i got an error everytime the dash tried to load. I can't restore the c backup either because i didn't restore before trying the install again and it saved my broken c image as the backup.
About This Instructable
1,015,999views
480favorites
More by VzjrZ:How to softmod your xbox...for FREE
Add instructable to:
