Step 2Create boot disk
Note: It is recommended to update your dashboard to MS Dash version 5960. While this may not be necessary for everybody, this tutorial will not work for people who have the 4034 dash. To avoid any and all problems, upgrading the dash to 5960 is highly recommended because nobody should have problems if they are running that dashboard. This softmod works perfectly with the 5960 dashboard version.
To update your dashboard, you can use any newer (post-Halo 2) retail Xbox LIVE game. You don't have to have Xbox LIVE, you don't have to have an internet connection, and you don't even have to have a network cable plugged into the Xbox. Just load up Halo 2 or any game made after that, select Xbox LIVE, and it will proceed to upgrade your Xbox dashboard.
K:1.00.XXXX.01
D:1.00.YYYY.01
Second - Run NDURE 3.0 program...click next and you should see this screen:
Ndure Options
First, I will briefly explain what each option does.
Basic Files - These are the basic files and are required for the softmod to function.
Retail Files - These are the files necessary so that you can have MS Dash access. Most people should leave this checkmarked, the only people who would not need this are people who do not have Xbox LIVE and have no need for the memory and music functions of the MS Dash. You dont gain anything by leaving this box unmarked, so you might as well include it.
Shadow C - Recommended for all users, because it prevents your Xbox from dash updates overwriting the softmod.
NKPatcher Options
NKP .67 - Use this if you have a hard drive over 200 gb, this will create a G partition.
NKP RGB - Use this if you are going to use the Xbox primarily with VGA output on a computer monitor (Only works with Focus video encoders)
NKP Progressive - This forces 480p for anything that attempts to run in 480i.
Kernel Specific Fonts - These fonts are designed to work exclusively with a certain kernel version. It is recommended to use a kernel specific font, as it should prevent any problems and provide an incredible level of stability.
Default boot xonlinedashconsole - Enabling this option will set up the dualboot feature. When the Xbox is powered on by using the eject button, and the softmod detects an open disc tray, it will boot to the Xbox LIVE Online Dash. In this screen, you can manage all of your network settings, as well as manage Xbox LIVE accounts.
UDDAE - This is a backdoor rescue dash that is based off of the Easter Egg Exploit, the uberdash, and an audio exploit. The thing about UDDAE is it allows you to completely turn off your softmod, going to a retail, unmodded state.
Now, once your softmod is deactivated, how are you going to activate it? In order to switch it back on, we need to change some files around on the Xbox, and we can't mess with the files in an unmodded state. Basically, the problem lies in we need to have it modded in order to 'turn on' the mod. Which really makes no sense.
This is where UDDAE comes to the rescue. Even with the softmod deactivated, we have a way to run homebrew code through a set of actions in the MS Dashboard. While this is a great feature for advanced users, it will not be used by the average user, but it doesnt hurt anybody by installing it. If you are interested in this, you can read up on SCEEE HERE and UDDAE HERE.
Ndure Toolset - This is a set of tools designed by kingroach to help with your EEPROM backups and other maintenance. It is basically a simple menu that helps you to protect your softmod and keep it running smooth and provides you with the information needed to save your Xbox if anything goes wrong. Just another way kingroach looks out for his users and wants to make them feel safe. While I have never personally used this, I would recommend installing this.
Create XBOXHDM Installer Obviously, we want this enabled, as this entire tutorial is for installing NDURE with XboxHDM.
My Setup goes like this: (X equals a checkmark)
X Basic Files
X Retail Files
X Add ShadowC
+ Kernel Specific Fonts
X 4034 (You would choose the number of your kernel that you found using System Info at the beginning of this tutorial I told you to write it down)
X Default boot xonlinedash console (because I have Xbox LIVE)
+ UDDAE
X Add UDDAE
+ Select Kernel Specific ST.DB
X Add NDURE Toolset
X Create XBOXHDM Installer
Also, for me, generating error 12 was a great method to unlock my hard drive but it can be tricky to get: dont pull out the DVD drive cable until about halfway through the startup animation or you will instead get error 11 and the HDD wont be unlocked.
