Step 5Booting from cd
Acer: - Ctrl+Alt+Esc
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
Compaq: (F10) (do this when the cursor is in the upper right corner of the screen blinking)
Dell: - F1 or Del.
Dell: - Some require pressing reset twice
Dell: - Ctrl + Alt + Enter
DTK BIOS: (Esc)
Gateway 2000: - F1
Hewlett Packard: - F1
IBM:
" Older Models - In order to get into the configuration of the IBM setup screen (CMOS) screen you need to hold down both mouse buttons during bootup.
" Aptiva - Press F1
" IBM PS/2: (Ctrl)(Alt)(Ins) after (Ctrl)(Alt)(Del)
" IBM PS/2 with reference partition: - Press Ins during boot
" Some PS/2s, such as 75 and 90: - Ctrl Alt ?
" Some PS/2s when pointer at top right of screen: - Ctrl + Ins
NEC: - F2
Packard Bell: - F1 or F2
Phoenix BIOS: (F1), (F2), or (Ctrl)(Alt)(Esc)
Phoenix BIOS: - Ctrl Alt S
Phoenix BIOS: - Ctrl S
Phoenix BIOS: - Ctrl Alt Ins
Sharp Laptop 9020: - F2
Sony: (F3) while you are starting the PC, then (F2) or (F1)
Tandon computers: - Hold down the key after turning on power
Tandon: - Ctrl + Shift + Esc
Toshiba Laptops: - Toshiba Utility
Toshiba: - Press Esc during boot
Toshiba, Phoenix, late model PS/1 Value Point and 330s: - Press F1 during boot
Olivetti PC Pro: - Shift Ctrl Alt + Num Pad Del
Miscellaneous PC's: - Ctrl + Esc or Ctrl and Alt and +
Zenith: - Ctrl Alt Ins
MAKE SURE THE FOLLOWING ARE GOOD TO GO:
PC is set in BIOS to boot from CD
My xbox is close enough to my computer that the primary master cable can reach it.
My IDE cable that will be used for hotswapping is connected to the primary IDE channel.
My CD/DVD drive is connected to anywhere but the primary IDE connection.
My primary master IDE connection is vacant, as this is the one I will hotswap the Xbox drive to.
Softmod Time!
Make sure your XboxHDM disc is inside your CD/DVD drive. Boot up your Xbox and PC at the same time.
Your Xbox should go to the MS Dashboard.
and
Your PC should go to the XboxHDM main menu.(See picture 2)
First
Where you need to be and xbox and computer must be on when hot swap
http://imageshack.us/photo/my-images/838/sany1874.jpg/
Second when you hot swap
http://imageshack.us/photo/my-images/819/sany1862.jpg/
Google is your best friend!
can anyone pls help.
thank you.
a. PC is set in BIOS to boot from CD
b. My xbox is close enough to my computer that the primary master cable can reach it.
c. My IDE cable that will be used for hot swapping is connected to the primary IDE channel.
d. My CD/DVD drive is connected to anywhere but the primary IDE connection.
e. My primary master IDE connection is vacant, as this is the one I will hotswap the Xbox drive to.
It isnt quite clear.
a. I got that down
b. Which primary cable? XBOX or computer?
c. The IDE cable that will be used for hotswapping, which one is this? And specifically which primary IDE Channel? XBOX or computer?
d. CD/DVD Drive. Is this the computers CD/DVD Drive thats connecting to anything but primary? Or XBOX?
e. Is it the XBOX or Computer's IDE Channel that is vacant?
Sorry. But its just too vague. Thanks for the tut.
