**Warning, if you are reading this to try and learn how to solder for computer circuits, read no further. Soldering jewelry involves an open flame torch and temperatures up to 1700 degrees Fahrenheit, or about 930 degrees Celsius. This will very likely destroy any circuitry that you attempt to use this technique on. Unless, of course, you intend to destroy said circuits, then by all means, read on.***
The next page will include a list of tools and materials you will need for this project.
Remove these ads by
Signing UpStep 1: Materials list
- Sterling silver wire or jump rings
- A torch. The one I am using is a small butane powered plumbers torch by Ronson which I got for about $30 at Walmart. Butane refills are about $2 each and fill it up almost twice.
- A soldering pick. I got mine in a set from Home Depot for about $5, but just about any kind of long thin steel rod will work.
- Borax Flux. You may need to look for a specialty store or order this online.
- Silver Solder. Silver solder is an alloy of silver, copper, and sometimes a little zinc. It comes in three main grades - Hard, Medium, and Easy. Hard melts at the highest temperature, Easy at the lowest. For this Instructable, I used Medium as my torch is a bit small to melt Hard very quickly. If you have a larger torch you might want to start with Hard, then use Medium on your second solder joints to prevent reflowing your Hard solder and loosing the connection. You will probably have to order this online or over the phone from a precious metals supplier.
- Wire cutters. Use these to snip the silver solder into small pieces.
- Tweezers. You may want these to hold something in place while soldering. Good ones have wooden grips so that they don't burn your fingers during extended soldering.
- Pickle. No, not the food. Pickle is a weak acid that is used to dissolve oxides and flux from the metal after soldering. Basically it makes the metal really clean by eating away all the dirty stuff. Also, never put anything made of steel in the pickle. The steel reacts with the pickle, making it so that the pickle will copper plate your silver. It's a weak acid, but it's still an acid, so if it gets on your clothes it will bleach or eat holes though them, and you should wash it off if it gets on your skin, and be especially careful to keep it out of your eyes. Update: I've heard some people use citric acid or a salt & vinegar solution instead of the acid pickle you can order from jewelry supply stores. I've never tried these methods myself, but they seem like cheap and easy options for beginners so I thought I'd list them.
- Some kind of plastic/ceramic container to put the pickle in. I just used a old Tupperware container. You can't use metal, especially steel.
- Earring hooks to attach to your earrings to make them dangly.
- A short length of thin copper wire. Use this to dip your silver in the pickle. Never put steel in the pickle.
Optional tools or materials you may want:
- Sandpaper - Use this to clean up your solder seams. I prefer 320 or 400 grit, but these will not leave a high polish.
- A polished hammer and anvil. You can hammer the silver to flatten, harden, and planish it a little bit instead of sanding, saving a lot of time. Planished silver is shinier than sanded silver, but you can't use a regular hammer for this because if there are any marks in the hammer face, those marks will transfer to the silver. The same applies to the anvil.
- If you're looking to save some money, or you want to practice with something less expensive than sterling silver, these techniques can also be applied to copper or brass wire and sheet as well. Just remember that if you use silver solder on copper or brass, the silver will show up against the brown or yellow of the other metals.
http://www.hauserandmiller.com/ - Hauser and Miller supplies precious metal materials such as Sterling silver wire and silver solder. They have low minimum purchase requirements, and their shipping is fairly low too. Their selection is somewhat small though.
http://www.ccsilver.com/ - Another good site for raw silver materials such as wire and solder.
http://www.riogrande.com/ - Rio Grande can supply you with pretty much everything you'll need for this project. The only problem with them is that they have some high minimum purchase requirements for raw materials, such as silver wire or solder, and they also have high fabrication fees. They do however, have an enormous selection. This would be a good place to find flux, pickle, sterling components such as ear posts or hooks, etc. You can also purchase tools from them such as hammers, small anvils, soldering tweezers, and torches.
http://www.monsterslayer.com - I've never ordered from them before but I hear their prices are pretty good and they seem to have a decent selection of things like raw materials and findings.
While I am by no means saying you must order your materials from one of these sites, several of them I have used previously and not had any major problems with them. If you prefer to do your own research, these sites may be a good starting place to compare prices, although for most silver items the price fluctuates daily with the precious metals market, so the best way to check prices on silver items is to call the company and ask for a price check.
Visit Our Store »
Go Pro Today »
I was wondering if I might be able to use a soldering iron - if you know - possibly a low-temp? If so, do you know what type of flux and other material might be needed?
I would attempt to solder the metal together, first, then load the crystals in the prongs after cooling.
thank you.
What type of solder/flux and other supplies would I need?
I would greatly appreciate any help!
Thanks again, though!
https://cgmfindings.com/
https://cgmfindings.com/index.php?id=6&page=75
wire jump rings silver solder and even a some gemstone beads if inclined to add some to the design.
The mesh is stainless steel while the structure around the base, that needs repaired, is silver.
Is this the way to go?
Thanks in advance.
D
Now, the other consideration is that since the mesh part is stainless steel, if you try to use it with a Sparex type pickle solution, it will contaminate the pickle and make it copper-plate anything that is silver. This can be removed using an abrasive but that is usually a huge pain in the butt and can also damage the finish of the piece. You can try a vinegar/salt pickle or a citric acid pickle, but once again I'd test that on something you don't mind messing up. I've never worked with those pickles so I don't know if they contaminate with steel the same way Sparex pickles do.
Hopefully this advice helps!
Without poisoning the tea with bad metal.
Where is a pot tinker when you need one?
any advice would be much appreciated
thanks!
The easiest way to do this would be to use solders with different flow temperatures, usually referred to as hard, medium, and easy. 'Hard' solder melts at the highest temperature, and 'easy' at the lowest. There is also a 'very easy' but it is usually only used for repair work. You should start with hard solder and progress downwards so that the first things you solder are at the highest melting temperature and you get progressively colder. If you are working on silver, you want to use the highest melting point solder you can on all visible seams because hard solder has a better color than medium or easy does. On brass it shouldn't matter too much.
The other alternative is to get your hands on some yellow ocher. If you make a paste of yellow ocher and water and paint that onto the solder seams you do not want to flow, the ocher will inhibit the flow of the solder. If you use yellow ocher you should be very careful to wash it all off before you place the piece in your pickle because the iron in the ocher will contaminate your pickle and cause it to copper plate your metal.
Hope this helps!
http://www.contenti.com/catalog.html
I'm new at this (and very grateful for your tute) what do you recommend for a fireproof work surface? I looked but couldn't find a source.
TYVM
My current workspace is actually just an ancient wooden desk that has a 1 inch thick piece of wood for the top, and I solder on a ceramic soldering pad (Rio Grande) on top of a kiln brick. Some people will get a metal lazy susan pan and fill it with pumice pebbles, then put their soldering pad on that so that they can spin it as they work. I believe this is the soldering pad I have:
http://tinyurl.com/24klysk
Hope that helps!
btw very clear and helpful instructable
I have a question that's a bit specific, but considering your breadth of knowledge as you've shared here, I figured you could help me out.
I'm looking into incorporating sterling silver findings/bevel settings into a metal clay work before firing. I know I have to fire and pickle the sterling silver pieces several times to remove the copper oxidation on the surface so that they will bond to the metal clay while firing the two together, but I was wondering if an ultrasonic cleaner is a suitable replacement for using pickle to remove this oxidation. Using an acid, even a weak one like pickle, sounds like something I'd have to work up the courage to do ; I'm guessing it's not a suitable substitute from what I've read, but I'd like to know for sure :).
Thanks again for the extremely helpful and easy-to-understand tutorial!
anyone interested in a micro torch (similar to the one here) can find one here: http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=42099
cheaply... i use one almost exactly like it but i paid way too much for mine :-(
Cheers,
WL
I can see why you'd be concerned about inhaling something originally intended as rat poison... :-) I've never tried that stuff, but perhaps sometime I will. I'm going to have to look into this 'shock-it' stuff too. Even the money saved on shipping the pickle would be worth it.
I've tried to plate copper pieces using steel-contaminated pickle before, but not with any real success. How long does it usually take?
I usually make my own clasps for necklaces and bracelets, but I can't ever bend two earring wires the same, and I just haven't gotten around to making a jig for them. Plus I usually consider it a reassuring point for customers with sensitive skin that the bought earring wires are actually stamped with '925,' proving they're solid sterling and not just plated.
Plating with pickle is generally instant. I usually add the piece to the pickle with some binding wire loosely wrapped around it and the plating happens right away. I save all my old pickle just for that purpose.
This is a great site with lots of tips and bench tricks: http://www.ganoksin.com/
https://www.onlinemetals.com/
i get most of my metals from them although i am closer to them (250mi) and shipping has been very reasonable for me but may be more for you.
Cheers,
WL
