Step 2Prepare to solder!
Cut your solder into tiny chips, like the size shown on the penny. You don't want a lot, otherwise you'll have more to clean up.
Lay your silver rings or wire onto the kiln brick and push the parts you want to solder together until they're touching. Sometimes using your tweezers or soldering pick to move things around can be helpful.
Mix a little water in with the flux until its a watery paste, and use the paint brush to apply dabs of flux to the joints you intend to solder.
Using your tweezers or damp paintbrush, pick up the solder chips and place them on the fluxed solder seams.
Double check that everything is where you want it to be before picking up your torch.
Check and make sure that the torch is set to high flame, so that it will be hot enough to melt the silver solder.
Ok, time to start soldering!
Add Comment
