3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to solder (for Jewelry purposes)
Step 4Check your work!
Check your work!
Once your metal in the pickle looks silver again, take it out, rinse it off, and take a look at the solder seams. If your solder did not flow into a joint, re-flux and add more solder, and try to reflow it again. This is a common problem, so don't worry if it happens to you.
Once you have a pair of well soldered earrings, you may wish to sand the solder seams to make them smoother, or hammer the earring flat (also making the joints smoother).
Once you've polished the earrings to your liking, attach them to the hooks with some smaller jump rings. Open your jump rings by twisting them apart, not by pulling them.
Not like this: <-- O -->
Pulling a jump ring apart deforms it, and it is hard to make it perfectly round again. Twisting the ring makes it easy to twist back into place.
Once it's polished and has the hook attached, you're done! Put them in a pretty box and give them to someone special, or keep them for yourself!
2 comments
Dec 13, 2011. 10:30 PMemilyspreiser says:
I've been making jewelry for a long time now. I started with crochet craft wire necklaces which I look back on and laugh at now. Then I started doing basic beading, and then wire wrapping, and now hammering...And I think now I'm ready to start getting serious. Soldering seemed like the next logical step, especially as I've been hammering wire to make bangle-like bracelets but always have to improvise some kind of closure, and would love to make bangles. I'd really like to be able to do rings, as well, without having to design some flourish to mask the ends. This tutorial will be very helpful in making my decision as to whether soldering is right for me. It was very well written, easy to follow, and accessible. And now I know everything I need, where to get it, and what to expect. Thanks very much.
Jan 31, 2011. 9:08 PMC.G. says:
This was amazing, but way too much work for me. I want a bail to be soldered closed and trying to find a sterling silver jeweler is not easy. Apparently, Jewelers only like to work on gold.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
31
Author:soundinnovation
I'm a metalsmith and jeweler that just graduated from UNT. I work primarily in sterling silver, copper, brass, enamel, and occasionally beads, semi-precious stones, and found objects.
