If the instructions given in this article are followed carefully, even someone new to soldering should be quite competent with a few minutes practice, it's really not difficult at all. If you dont want to take the time to read all the details, I have put the main points in bold at the end of each section.
Remove these ads by
Signing UpStep 1Soldering iron
My advice would be to spend your money on a good fixed temp. iron, it will probably cost you at least as much, even a bit more than one of the cheap adjustable temp. irons. You can always build a temp. control unit for your iron later if you want. You don't need adjustable temp. to do fine work though, if you put a smaller tip in an iron it doesn't transfer as much heat, and most people will only want to go to a fine tip if they are working with surface mount components, and even then some wont go to a fine tip.
The iron I like is the one in the photo, it's a 'Goot' made in Japan, has a ceramic heating element and will go from cold to ready to solder in under 30 seconds. This one is actually 46W and most people will want something around 30 to 40W for general work. But I love the control this iron has, I can solder the most delicate IC and go straight to heavy gauge lugs with the same set-up.
I think some people use underpowered irons with very fine tips, thinking this will be delicate, but end up holding the iron on the part for half a minute to get it to solder, and still get a weak joint. You should only have to hold the iron on something like an IC pin for about 2 or 3 seconds.
If you switch to a fine tip because you want to neaten up your PCB work, for example you're getting solder bridges between pads or IC pins, you will probably find it doesn't help very much. Instead you might find yourself having to hold the iron on longer because it wont heat up enough, and the solder wont flow properly. The tip probably isn't your problem, and you might find switching to thinner solder will help more. Using thinner solder makes it much easier to control how much solder you feed into the joint, if you are using around 1mm diameter solder, try switching to about 0.5mm diameter, but keep the normal size tip.
To sum up: Get a decent soldering iron with the right size tip.
My favorite soldering irons are temperature controlled soldering irons with digital display. It is possible to set very accurate temperature on tip of soldering iron. My favorite models of soldering irons are Weller WESD51 and Weller WES51 (WESD51 has digital display to show temperature of the tip). There are some reviews about temperature controlled soldering irons here:
http://www.soldering-store.com/
FYI its a GOOT brand of iron, they are made in Japan, its 46Watt which I find is a really good general purpose type iron. The tip maintains its preset temperature well and its safe to use on sensitive parts, I have used it to solder everything from big chunky contacts to very small surface mount components no problem.
Here is a link to the Australian version http://www.jaycar.com.au/productView.asp?ID=TS1430&keywords=goot&form=KEYWORD
it is a 240 volt model, But I'm sure you can get 110V models. There are other brands which are good, I just think you are better off spending money on a good quality fixed temp. iron instead of getting a lower quality iron with adjustable temp. The problem with some of the cheaper variable temperature irons is that they don't actually maintain their set temp. very well, plus they dont allow you to set a prticular temp. but rather just vary the temp. up and down by varying the power.
So if you adjust the temp. down and it is at say 280 degrees, ( you wont know what the temp. is unless you measure it with a thermometer) you start soldering and the tip cools down as you are working to say 180 degrees and now it isnt hot enough. You might actually have to stop soldering for a while until it heats up again. With a good set tmp. iron the tip is set at an optimal temp. say 320 degrees and the iron tries to maintain that temp. all the time. The heat recovery is so good that you don't even notice the iron cooling down.
Of course you can get good variable temp. irons that have great recovery, some even allow you to set it to an exact temp. but they are very expensive. I just think if you wanted to spend say 50 bucks you would be better off putting that money into a good fixed temp. iron rather than a cheap variable temp. iron. Also if you really want variable temp. you can always build your own temp. controller for the fixed temp. iron later on. A quick way to cut the power to the iron down is with a diode, this will 'half' rectify the AC power and give you a little over half the power to your tip. Chuck in a switch and you have a 'two temp' iron, a kind of 'high/low' setting, which could also be used for 'standbye' to possibly increase tip life by running it on lower heat but having it almost instantly ready to use when you want it.
I am a maintenance technician at a manufacturing plant just breaking in to playing with electronics. I have purchased a few soldering irons and have found for the price if you are just getting in to soldering period Weller is a good brand of irons to use. They are priced any where from $30 all the way into the thousands for professional setups. I myself purchased a Weller WES51 and haven't regretted it since.
Thanks!
The copper is held to the bpard by a glue. The glue loses ~80% of its strength while it's at soldering temperature. To avoid lifting pads, never push on the board with your iron. Giving the board mechanical stress _while it's how_ is almost guaranted to lift a pad.
When the board cools down, the glue should retun to its usual strength.
May I suggest that you include some description on the 63-37 solder.
I've never understand why the hell the solder manufacturers bother making the 60 Sn-40 Pb (tin-lead) solder. It is plainly stupid since Tin is a little MORE expensive than Lead...
But 63-37 solder is what is called Eutectic, which means it has a SINGLE fusion temperature (183 °C or 361.4 °F) that is the LOWEST temp of all the In-Lead alloys. This means that the melted solder solidifies instantly, which greatly reduces the possibility of bad joints or "cold solders", and also reduces the risk of damaging delicate components. Since all solders containing Lead are being phased out by the almost crazy inflated worry about Lead, it is a very good idea to buy a large (by amateur standards, that is) quantity before it becomes unobtainable.
Regards.
Alfredo M Claussen, Mexico City.
big quantities X(times) little bit of money = alot of money
But good point about stocking up though.
amclaussen
