What is interesting is that heat is localised and is present only for a very short time (sort of induction cooker).
Be very careful with the car battery and use a battery in perfect condition - I would suggest to use a battery charger (choose one which is fused) instead.
Do the experiment outside the house where air is circulating and wear arc welding goggles and filter mask.
A video of the results is here:
http://www.metacafe.com/watch/733036/graphite_pencil_soldering/
Remove these ads by
Signing UpStep 1Hack the AA battery
You will need pliers and a knife.
Be careful not to break the carbon rod.
Conclusion: 12V is *safe* if you use it correctly.
You can grab a car battery's leads and squeeze them really hard and still not feel a thing. The only way to feel the 12V is when a lead penetrates your skin, and even then you won't die from it.
(+) ---------- (solder) ------------ (-)
< Spark ! >
Regardless of the intensity, arc lamps have very high UV emissions. Some sort of protection should be used--if you value your eyesight.
D and C cell type batteries have larger electrodes inside of them, so they are probably easier to handle.
My conclusions?
-Only the ones marked "Heavy Duty" as you said (however it wasn't mentioned what exactly it was) have the graphite. The others all have some gooey stuff in the middle.
-My family likes to buy a lot of Duracell. (NOT with graphite).
So yeah, out of a nice mess I only extracted 1 rod. All the others were alkaline (Duracell).
Let me relate something that happened to a friend of mine, a dentist by trade who likes to work on his sports car occasionally. In preparation for some other work, he elected to remove the battery from the car, using a box wrench to loosen the battery clamps. The wrench made contact with his wedding ring (he's lefthanded), and the ring in turn made contact with the battery holddown. A massive short circuit welded his ring to the holddown and to the wrench, which in turn was welded to the positive terminal.
Car batteries store an enormous amount of energy, and they're optimized to deliver it in a very short period of time. A shorted car battery can easily deliver several hundred amps — more than an arc-welding machine. Within a second, my friend's wedding ring was almost red-hot, and only a fast reaction with his other hand to break the connection by hitting the wrench prevented it from remaining connected long enough to melt. The ring had to be sawed off his finger at the emergency room, and it was more than a month before the burn specialist was sure he wouldn't lose the finger altogether.
Two lessons here. First, remove all jewelry when working with tools, even something as simple as a box wrench. That's fairly obvious, eh?
Second, always remove the battery's ground clamp before loosening the positive. If you remove the negative clamp and inadvertently complete a circuit to ground, there will be no current flow because the ground clamp is already grounded. Subsequent shorting of the positive terminal to ground will then produce no current flow because the current has no return path to the negative post. And, of course, always reconnect the ground last.
