3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Solder
How to Solder
This guide focuses on soldering for the beginner and explains how you can solder a variety of components using a few different techniques - from the classy to the downright caveman. Although soldering can seem daunting at first, once you give it a try you will see that in most applications it's quite simple to do.
Please note: this instructable is written for beginners, and contains lots of very basic information. If you have lots of experience soldering, please use the comments to share your knowledge. Clarifications and corrections are especially welcome.
This Instructable was the lead-off for "How to Solder" month, where we rewarded soldering tutorials with Instructables patches. See the original call for project here at submitting a How to Solder Instructable or just check out all the other soldering Instructables here at the How to Solder group.
Step 1Tools and materials
Tools and materials
Soldering is the process of using a filler material (solder) to join pieces of metal together. Soldering occurs at relatively low temperatures (around 400 degrees Fahrenheit) as compared to brazing and welding, which actually melt and fuse the materials themselves at higher temperatures. In soldering the filler material becomes liquid, coats the pieces it is brought into contact with, and is then allowed to cool. As the solder cools it hardens, and the two materials are joined. Soldering is a quick way to join many types of materials, from copper pipe to stained glass. It creates an electrically conductive strong bond between components that can be re-heated (desoldered) if you should ever want to disconnect two items joined together. It's great for joining electrical components and wires and is used in just about everything electronic. In this Instructable I explain how to solder the basics you see in most Instructables: electrical components and wires.
For further information and some more technical specs on soldering check out the wikipedia article.
As with many skills, having the right tools for the job effects the quality of the work being done. When it comes to soldering you can end up using a lot of fancy tools, or just a few simple items you can pick up at the hardware store for a couple of bucks. I am going to use a couple of different soldering tools in this Instructable; there are many ways to solder, and you should use what works for you.
At the very minimum you will need the solder and a heat source to melt it - preferably something small which can get to 600-800 degrees Fahrenheit. If you've got that, your ready to make a connection. That being said, there are a wide range of soldering tools and accessories that can be really helpful if you're going to be soldering frequently. Ladyada has compiled a nice list of equipment and sources to buy the tools on her site. I got together a solid supply of soldering tools by raiding the Squid Labs soldering station. Here is the complete list of what I used...
1. Soldering iron
Most people opt for using a soldering iron to solder. It's a great heat source that heats up and cools down quickly and can maintain a pretty constant temperature. Soldering irons can be purchased from a variety of places. I have picked up some at Radioshack - evil yes, but convenient, some from the hardware store, some from garage sales and a bunch more from retailers online. Low wattage (15-40 watt) soldering irons work best for soldering components on circuit boards while more powerful (60-140 watt) soldering irons work well joining thicker materials like braided speaker wire. If you use too powerful of a soldering iron on a circuit board you might damage the components you are trying to join. I like to keep a low-wattage iron around for detail work, and a high-wattage iron that I can use when I am not too concerned about exposing the material I am working with to high temperatures. It's a real pain to solder thick wires without a powerful soldering iron.
The soldering iron in most of the pictures is made by Weller, and has a variable temperature control. This is the best of both worlds since you can set the heat exactly where you want it, but it's significantly more expensive than fixed-temperature irons. If you're just going to do some occasional soldering it isn't a must have by any means. Anyone interested in modding a soldering iron should check out DIY Hot Air Soldering Iron by charper.
2. Solder
There are lots of kinds of solder available. They come in different thicknesses from around .02" to some really thick stuff you would only use on copper pipe with a butane torch. You use thin solder for detailed work like putting resistors onto circuit boards and thicker solder for joining larger materials like speaker wire. I use solder around .025" for most jobs. Most solder is made from a combination of tin and lead - it's about a 60% tin, 40% lead mix depending on what solder your using. Recent international health codes from Japan and the EU (California and New York have adopted similar policies as well) mandate that lead solder be phased out of certain commercial products and substituted with a lead-free alternative. The manufacturing deadline was this past July so we should be seeing the changes now. Even if you don't live in California or New York its still worth staying away from lead solder since lead has been known to cause all kinds of a nasty health effects from birth defects to severe developmental and neurological damage. Plus it's pretty easy to find the lead-free stuff.
Some solder will contain a small amount of silver. This pushes the melting temperature up a bit, but the silver helps the solder to flow and makes a stronger joint. If you are worried about burning whatever your working with, try to stay away from solder with silver in it, but it works very well if you're just joining wires or something that won't be easily damaged. The last thing to know about solder is that you want to use a solder that has a rosin core. The rosin acts as a flux when soldering and helps the connection - it's also the kind that's most readily available at the hardware store and from electronics suppliers.
3. Soldering iron tips
Soldering irons come with a tip, so you don't have to go out and get a special one, but it's important to know the differences between them and make sure you're using the right tip for the kind of soldering you're doing. Some small-wattage irons come with conical pointed tips for detail work, while most high-wattage irons come with a flatter screwdriver-style tip that works well on wires. You want your tip to be a little smaller than whatever you are soldering so you have good control of what you heat up and what you leave alone.
4. Soldering iron holder and cleaning sponge
It's nice to have a safe place to put the soldering iron down in between soldering. A soldering stand safely holds the iron and gives you a place to clean the tip. Some soldering irons come with their own holders. If yours doesn't have one, you can buy one or make one. jaime9999 has a Homemade nearly-free Soldering Iron Stand that is pretty much identical to what you can buy. The stand isn't a necessity for learning how to solder, but it does help.
5. Tools to work with wires
I have a go-to stock of tools that I round up when working with wires or electrical components. They consist of wire cutters, a wire stripper, needle nose pliers, and an automatic wire stripper (courtesy of the Squid Labs soldering station.) The automatic wire stripper is really convenient if you're going to be stripping lots and lots of wire, but by no means necessary. I have stripped lots and lots of speaker wire using my teeth (not the best idea, I know I know.)
6. Clips to hold your work
Often called "third hands" or "helping hands," these little guys help a whole lot when soldering. You have to hold the soldering iron with one hand and the solder wire in the other, so it really helps to have something else to hold the components you're actually trying to join. You can use alligator clips, clamps, or even some tape to hold things in place if you need to. The third hand is generally a good investment if your going to be soldering regularly, and there are plenty of Instructables with with ideas to modify them if you do happen to pick one up. Check out: Make a 3 degree of freedom 'hand' to help with soldering / gluing work and make your 'helping hands' 100x more useful for soldering / gluing small parts by leevonk to start.
If you would like to make a set of helping hands of your own there are already a number of good Instructables on that too. Quick helper for surface-mount soldering by http://www.instructables.com/member/bikeNomad/bikeNomad, QuickMods - Soldering Arms by Aeshir and Build a Pair of Helping Hands by john otto should get things started.
7. Exhaust fan
I do most of my soldering at a soldering station that is equipped with an exhaust fan. It's really not such a good idea to breathe in solder fumes, and soldering does produce fumes. Any kind of ventilation/fan you can rig up will help. Vent the fumes outside or use an indoor fan with a filter if you can't vent them outdoors. Here is a Window-mounted solder fume extractor (not just for RVs!) posted by bikeNomad. Also check out Dr. Solomon's low tech, but functional Solder Fume Extractor if you're looking to build something that you can place right on your table. If you're just doing a quick soldering job, the fumes wont kill you by any means. I have certainly done my fair share of soldering without a vent, but anyone doing repetitive soldering should definitely pick one up or make one.
8. Safety goggles
I hadn't ever used goggles before while soldering, but while doing research for this post I saw it mentioned elsewhere and agree that its a good idea. Little molten bits of solder tend to fly out of the soldering joint when you're feeding in the solder, and if it landed in your eye it wouldn't feel too good.
9. The materials that you want to join together
I was just messing around, and mostly soldering for the purpose of this Instructable so my materials didn't necessarily make anything. You can solder wire, electrical components like resistors and capacitors, circuits, breadboards, electrodes, small pieces of metal and whatever else you can think of. Don't know if it can be soldered? Give it a try - you won't blow anything up.
Once I have got my tools and materials rounded up, I like to pretend that I am a pilot and begin my pre-flight/solder checklist.
317 comments
1-40 of 317next »
Jan 5, 2009. 7:12 PMwoodswalker says:
I bought a 30W soldering iron from Radio Shack. I'm having a lot of trouble because it takes as long as 90-120 seconds for the solder to heat up. And if I don't touch the solder directly to the iron, it never gets hot enough at all. Plus, the solder doesn't flow well and it turns into balls & blobs. I'm puzzled. What's wrong?
Mar 9, 2012. 11:36 PMChevota says:
I know this is an old post, but someone may benefit.
There's a few possible problems, the obvious one is you're iron isn't hot enough. I prefer a 40W iron over a 30W any day. It seems 30W are the most common, but they just don't cut it for me.
Try a cheapo model form ebay etc for $5 or so and see how it works for you.
Another fix is to heat the iron up a bit with a torch. I rarely need to do this to boost heat, but I will use a torch as the heat source for the iron if I'm too far from an outlet..
The other problem could be thinking the flux inside the solder is enough. It is not.... At least it has never been for me. You need to flux the surfaces and be sure the surface can be soldered in the first place.
The surface could be coated or plated with something that either the solder or the flux doesn't like. It might also be corrosion, a lubricant, protectant, or who knows what. In those cases I clean it with a chemical such as electric contact cleaner aka brake cleaner, or even carb cleaner, but most people use alcohol. If that doesn't work then it's probably some kind of coating you'll need to remove with force, like sandpaper or a Dremel tool to break thru to the good metal. Once you've ground the bad part off, clean it, coat it with flux and try again.
If it's still being difficult you can try using sandpaper on it while it's coated in flux. I like 320-400 wet/dry paper, maybe 180-220 if it's really bad. Cut a small piece for sacrifice because you don't want to use it again now that it has flux on it. After you have either roughed it up nicely, or ground thru the problem coating whatever it was, clean it, flux it, and try again.
I prefer to coat the problem item in solder first, that way I know it'll work when it's time to attach something. Assuming the iron is hot, clean, and will hold solder (plain old rosin core 60/40 works best for me), put a little on the tip, then apply it to the surface and hold until it flows and coats your surface. If it's a large item and you can't get it hot enough you will need to preheat the item with a torch or whatever, I've used anything from little butane torches to my oven, as long as everything can handle the heat that is. (fyi; preheating also works for welding when the machine can't generate enough heat). Once it's hot enough the solder will flow nicely into the area worked on, and your problem is solved.
If you never could get the solder to stick then you might be working with the wrong metal, like aluminum, so use the appropriate method for that metal, or simply try using a screw or bolt as a contact. If you can figure out what the base metal is, then search the net for a bolt material that will not react with it. Example; drill a hole and use an appropriate bolt/nut and torque it down good, then apply solder to the bolt's head which should be a snap. Common steel bolts are usually coated with something which probably needs to be ground off. Grind off just enough area for what you need, and preferably solder it in a way you can still use the tool to remove it if needed. Now flux your spot and apply a little drop of solder like described above. Being a bolt it's probably heavier and may need a little boost with a torch.
I flux/solder each piece first so I know they're both good to go, then I put them together and add a drop of solder with the iron until it flows.
I hope this helps some people with their soldering problems...
Apr 11, 2011. 1:06 AMrobot1398 says:
at which temp dose the solder melt
Apr 12, 2012. 7:27 AMnprince says:
Depends what solder you have.
Tin/Lead = around 200C
Lead Free from 217-250C
Mar 30, 2012. 9:31 PMBompata says:
How can I tell if there is hole in the circuit board where the pad is? Do I have to try to push a wire through while the solder is melted?
Sep 11, 2011. 7:04 PMknexsuperbuilderfreak says:
What about metal plates and soldering them together?
Dec 13, 2011. 4:40 PMHuntman00 says:
that's called welding
Jul 6, 2010. 4:55 PMkingmii says:
One time I was soldering and i knocked my soldering iron out of it's stand and then i grabbed it by the hot rod. That was the only time I've had good reaction timing
.FAIL.
Nov 14, 2011. 4:05 PMco083121 says:
sorry, lol. i just have to comment. i've burnt myself quite a few times and i've got a friend who recently done it for the first time. i felt bad for him. . no offense
but i laughed at your comment. i'm sure you did as well looking back on it. sorry if i offended u. but i know how hot those are and i can almost see it happening!
Nov 14, 2011. 9:47 PMkingmii says:
Its fine lol I laughed at myself just after it happened although I couldn't bring myself to solder for a while after that
Sep 2, 2011. 1:35 PMageorgia says:
Hi, this "through hole component" soldering is exactly what I've been trying to do. The DC jack on my laptop is broken, and I've been attempting to fix it. But for the life of me, I can't get the solder to behave the way yours does in the video, where you get the "ant-hill" shape.
When I do it, the solder either balls up on the end of the solder wire, or bunches up into a little blob around the lead, which is only a good enough joint to last for a week or so before I start losing the connection again. (I had the exact same problem while I was soldering the pickups in my guitar as well, although that was soldering a wire to a plate so it was quite different.)
So can somebody please tell me....WHAT am I doing wrong??
Sep 11, 2011. 3:40 AMpfred2 says:
Just a guess but you may be trying to solder lead devices with lead free solder and equipment. I don't have any experience with the lead free stuff myself but I hear it is hard to work with. Maybe someone else can shed some light on this?
I cannot see what you are doing but it sounds to me like your iron tip is not tinned properly, or it was, and it is dirty now. Something like that. Take a paper towel fold it into a little square and soak it with clean water, then wipe your hot iron tip on it with a rolling motion a few times see if you can make it shiny bright.
You should be able to get a droplet of solder to stick right to your iron tip. If you can't do that you can't solder. Well, not you can't solder, just you can't solder with that iron tip.
When you solder to a metal plate it is helpful if you sand the smooth metal with emery or sand paper to put some scratches in it that the solder can grip to. Solder won't stick to all metals either. Like you can't solder aluminum. Well you can solder aluminum, just not with regular solder.
Confused yet? Good! I think that is how they want us to be.
Insist on genuine lead solder!
http://i.imgur.com/l1z0g.jpg
Aug 16, 2011. 7:28 AMcoolo52 says:
can i use my wood burner to solder?
Jul 9, 2011. 3:28 PMzcarter34 says:
Thanks for the great guide. I teach a metalworking class at a Boy Scout Camp and I kind of knew what i was doing but couls never quite get it right. I would always get cold solder joints, but now i shouldn't have any problem!
Mar 21, 2010. 10:22 AMzack247 says:
this is the third time i have read this, and i still dont solder like a pro. the only thi i remember after reading this is the part about soldering the leads (and i still use way too much solder) one question: how would i take off a surface mounted LED? i have removed 2 8-pin ic's but i am afraid i might melt the led. help?
Mar 21, 2010. 10:23 AMzack247 says:
PS: i have no solder braid and no solder pump.
Mar 22, 2010. 8:27 PMstatic says:
OK for the poorboy methods. Use the braid from coax a poor substitute for solderwick, if you have a tin of rosin flux using that flux with make the braid work better. Have a can of air? warm up the excess solder and use the air to blow it off the board. No can of air? Warm up the solder, grab the board and fling the solder off. Of course the last two suggestions com with risks, don't attempt them if you can't figure out the risks. ;)
Mar 22, 2010. 10:10 PMzack247 says:
well i have no where near enough money to buy any of this stuff, my basic unsoldering routine is generally do what it takes to get it off, if at first you break it, try again until you think you've broken too much. i find that for the surface mounted stuff a pair of needlenose pliers and a lot of patience works just as good. im gona try my luck with the leds, i have already repaired a computer mobo, so how hard can it be? and dont give me a lecture on safety, because i have heard it all before and yet i still continue to burn myself (about 5-10 times a day)
Apr 18, 2010. 9:59 PMstatic says:
Relax, I wasn't lecturing you, I included the warning because I suggested potentially hazardous methods in a public forum.  How hard can it be? That depends on your goals. In the event you want to salvage parts that are usable after removal or leave a circuit board undamaged, "it" at times can be difficult. One method that served you well in the past may not serve you well tomorrow.
May 13, 2011. 11:23 AMphenoptix says:
I understand this is a really old post to reply to but zack's problem is a common one.
With a small surface mount product you can "wipe" the component off onto the soldering iron buy using a large blob of solder on the tip of the iron. Large enough to touch both ends of the component is ideal but if it's a big component you can move it up and down the component to melt both (or all three) solder pads at once and the component will slide off with just the pressure of you soldering (you don't need to push it). If you have something to wipe the component off onto you can usually clean it up and reuse it too.
May 13, 2011. 3:29 PMzack247 says:
after trying my luck, i managed to get 8 blue leds off of a cell phone motherboard, without solder. i took a small utility knife and cut underneath the led, somehow it cut a layer between the led and the board, but it didnt take off the pad or break the led.
May 14, 2011. 3:57 AMphenoptix says:
Good effort, everytime I've tried a mechanical method I've broken something!
May 14, 2011. 10:01 PMzack247 says:
haha every time i try unsoldering smd leds they always melt!
i need to find some soldering braid..
May 15, 2011. 12:05 AMphenoptix says:
How heavy (what Wattage) is your soldering iron? They do come apart if your iron is too hot. I find using braid fairly fiddly somehow never have enough hands to keep it where it's needed! I'll try and get a video together of the solder wipe technique. It really does work well!
May 15, 2011. 2:56 PMzack247 says:
its a 30/35w soldering iron.
May 13, 2011. 11:30 AMphenoptix says:
Best bit of kit I ever bought for soldering (besides a soldering iron) was a metal tip cleaner, like a scouring pad. It takes any oxidation off of the tip and allows you to tin it again (put solder on it) the real secret to soldering is keeping the tip tinned, that way you get heat, and therefore solder, onto the components quickly. Great guide. Soldering glasses is also a good tip, I'll wear my safety specs next time!
Apr 27, 2011. 1:35 AMjwoo2023 says:
Lead-Free solder is dangerous(the smoke that is)
Apr 18, 2011. 10:53 PMtaukir000 says:
I once saw another soldering and desoldering guide along with soldering iron buying guide at http://eoler.tk. I liked the remedy got from touching the iron. It recommended to apply toothpaste immediately on the affected area. It really works! It helped me alot. And I got more tips on soldering by reading this! Thanks :D
Apr 16, 2011. 10:09 AMThereyouhaveit says:
Woah , dude , your tip is extremely worn out .
Not even there and i would run off to buy a replacement tip ...
Jul 16, 2010. 8:23 AMUgifer says:
You can also solder with the "iron" rather than the flame - I once needed to fix a radio with a dry joint but had no soldering tools at all to hand. Heat a skewer in the cooker gas flame and it has enough heat capacity to reheat a joint before it cools. Hold it with a cloth!
Apr 11, 2011. 12:58 AMrobot1398 says:
works for me too.
Feb 1, 2011. 9:33 AMTeamDuck says:
Thank you so much, you helped me make my mum a sun jar in time for her birthday :)
Sep 12, 2010. 2:18 AMCyborgGold says:
I did a how to solder a pcb search on google which brought me here. I am tryig to solder a few points on an xbox 360 controller, but the soldering points are not bare, there is nothing but a hole where I need to connect some wire. Would you mind letting me know what I can do to get the wire to stick? Thanks!
Dec 8, 2010. 7:14 AME_MAN says:
Why do you need to solder to the inside of a xbox 360 controller??? There is a solder mask that will keep solder off of everything but where the connections a supposed to be. (that is why the board is colored and not yellowish) Follow the trace that connects to this hole. It has to connect to another component somewhere. Just use that connection.
Hope this helped
-Eric
Dec 8, 2010. 9:37 AMCyborgGold says:
I am trying to add LEDs to the controller to light up the buttons when they are pressed. The buttons are part of the PCB, not external components. I need to wire the LEDs away from the button so the buttons can be pressed without coming down on the wires. I tried scratching off the solder mask gently with a knife, and soldering to the trace, but the wire won't hold strongly to the trace.
http://tinyurl.com/27c77zm
Dec 13, 2010. 4:34 PME_MAN says:
Soldering to the traces usually does not work very well. I would follow the trace that connects to the buttons. It has to connect to another component somewhere. Just solder to that connection there.
Aug 1, 2010. 10:43 AMactionjksn says:
I don't have a heat gun, so I always use a Bic lighter. I have used it dozens of times and it works perfectly. You just hold it under the heat shrink tubing for a couple of seconds, and it shrinks around the wire nicely. For solder, the thin stuff works best for electrical work. I bought some Kester brand 60-40 alloy 0.31 inch - 0.79 cm diameter. Also for electrical work you are not supposed to use acid core solder, or it will erode your components. You should use rosin core only. The ones that look like a gun are not for electrical components, they will run electric current through your components, which can fry them. You should use the ones that you hold like a pencil. The gun style would be Good for wires though I taught myself, but I was already experienced at sweating copper pipe, so I already knew to heat the piece instead of the solder. My first project was the coax connector on my TV, which had broken off. I found my high quality solder at a hobby shop. I got my soldering iron at Radio Shack. I didn't buy the cheapest one they had, nor did I get the most expensive one. It has lasted me since 2000. But I don't use it every day either, It's a 40 watt..I want to get the one with a separate transformer, with an adjustment knob. Microcenter has some good deals on them, if you live near one.
May 26, 2009. 5:30 PMkjjohn says:
I am having a very hard time soldering together some mini camera charging circuits for a coilgun. I have to solder several wires that are each about a quarter cm long onto a board that is maybe a little over a square cm.
Jul 26, 2010. 11:54 PMmrwolfe says:
You'll need a magnifying glass, tweezers, a very fine soldering iron tip and some fine solder wire (0.5mm should do it). Oh, and steady hands!
Sep 19, 2009. 7:35 PMthecrow117 says:
ya me to can any one help
1-40 of 317next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
895
Author:noahw
Editor of the Workshop and Outside channels...I'm back!
