Step 4Soldering components onto a circuit board
Soldering on a circuit board takes a little more care and attention, but it's still very doable. I pushed a few of the leads from some spare LEDs and resistors that I had from my LEDs for beginners post through some open holes in a circuit board that was lying around. I soldered the leads onto the bottom of the circuit board where the electrodes push through. This is called through hole component soldering.
To solder the LEDs and the small resistors to the circuit board I switched to the adjustable temperature soldering iron. The tip was smaller so it would be easier to get the solder right where I wanted it, and using the soldering gun on a circuit board is probably way more heat than necessary and it could end up damaging the components. I set the temperature of the iron to 675 degrees Fahrenheit and waited for the tip to heat up. I then loaded the circuit board into the alligator clips and got myself ready to solder - iron in one hand, coil of solder in the other.
When soldering leads into circuit boards you want to heat the metal contact on the board and the lead itself. Applying too much heat can damage the circuit board or even your components. The surfaces being joined in this application were much smaller than the twisted wire, so things heated up a lot faster.
I touched the tip of the iron to the crack between the lead and the metal pad on the circuit board. After waiting a couple of seconds, I dipped the tip of the solder into the joint and placed a very small amount of solder at the connection - no more than the head of a pin or so.
Once the solder pooled a bit and soaked into the joint I removed the solder wire and then the iron. I remove the solder a second or two before I remove the iron so that the tip of the solder doesn't get stuck to the joint. The solder begins to harden as soon as you remove the iron.
Using the proper amount of solder is more important while soldering small components on a circuit board than when soldering wires. If you apply too much solder and it pools up outside of the metal pad, it can cause a short. Too little solder and your component won't make a good connection with the circuit board and might not work the way you want it to. When you've got the right amount of solder it looks like a small ant hill that forms right at the base of the lead and the circuit board.
Here is a video of the process.
When I do it, the solder either balls up on the end of the solder wire, or bunches up into a little blob around the lead, which is only a good enough joint to last for a week or so before I start losing the connection again. (I had the exact same problem while I was soldering the pickups in my guitar as well, although that was soldering a wire to a plate so it was quite different.)
So can somebody please tell me....WHAT am I doing wrong??
I cannot see what you are doing but it sounds to me like your iron tip is not tinned properly, or it was, and it is dirty now. Something like that. Take a paper towel fold it into a little square and soak it with clean water, then wipe your hot iron tip on it with a rolling motion a few times see if you can make it shiny bright.
You should be able to get a droplet of solder to stick right to your iron tip. If you can't do that you can't solder. Well, not you can't solder, just you can't solder with that iron tip.
When you solder to a metal plate it is helpful if you sand the smooth metal with emery or sand paper to put some scratches in it that the solder can grip to. Solder won't stick to all metals either. Like you can't solder aluminum. Well you can solder aluminum, just not with regular solder.
Confused yet? Good! I think that is how they want us to be.
Insist on genuine lead solder!
http://i.imgur.com/l1z0g.jpg
Hope this helped
-Eric
http://tinyurl.com/27c77zm
The reason it works with everything connected to the same flow path is beyond my knowledge. So, when you talked about soldering onto a motherboard using the 'Thru Hole" (i guess you called it) method, my eyes started glazing over. Obviously that wouldn't be a problem and the advice perfect if my theory of "All connected to one" were accurate but I somehow doubt that to be the case. So, maybe you could show an application that repaired a broken circuit that could be re-soldered.
I realize that sounds moronic. If I can't understand the circuit pattern than how will I know if one is broken? It did to me, for a moment also but the truth is that I have had far more need to re-connect instead of creating one. It's actually more like, repairs - 10 & New circuits - 0. Just thought I'd ask.
Attaboyslim
" heat up the piece and stick the silver wire to it and your done. easy huh...."
It's nice ot get some quality insruction. thank you again for your time making this tutorial for us newbies!!
Cheers!
