3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Solder
Step 6Surface mounting components onto a circuit board
Soldering components onto a circuit board when the leads can be pushed through holes in the board is the easier of the two methods of soldering small components onto boards. Many circuit components need to be surface mounted on circuit boards, which forces you to be a little more precise then when you can work on the bottom side of the board.
To solder something onto the surface of a circuit requires a process called tinning. Tinning is when you apply a small amount of solder onto the materials you are joining before you connect them. In this case, it involves putting some solder on a contact on the surface of the circuit board then attaching the component to the solder pool. Mitch showed me how this process is done.
First he touched the tip of the iron onto the small pad on the top of the circuit board. He then introduced a small amount of solder onto the pad and took the iron away.
Then, a few seconds later he picked up the component he wanted to solder with a set of tweezers, heated up the small glob of solder that he had just placed down, and gently lowered the contact on the component into the pool of hot solder.
He took the iron away, held the component in place a few seconds longer, and released the component from the tweezers.
He then went to the other side of the component and finished making the connection by soldering the remaining two contacts together.
Surface soldering is done like this because you need to lower the component into place by hand, so it's hard to hold the iron, the tweezer and the solder all at the same time. Additionally, tinning is just a good thing to do while soldering small components. I didn't tin the wires before I soldered them because they were so big I was sure I was going to be apply enough solder to make a good connection. However, when soldering small components or doing surface mount soldering like this, tinning can be really helpful because you basically already have your solder applied to your pieces before you go to connect them. There is no need to glob on more solder and run the risk of getting it in a place where you don't want it to be.
The picture series below shows the process unfolding step-by-step.
10 comments
Jul 26, 2010. 11:49 PMmrwolfe says:
Great instructable!
I generaly don't tin the contact because that tends to make it more difficult to  get the component to sit flat on the board. Generally, a commercially produced board will have enough tinning on it to make the component stay in place until you can finish the joints.
Step 1 is to apply a small amount of rosin flux to the pads that the component is going to be soldered to (I have a small bottle with a brush in it)
Step 2 is to place the component using tweezers (As per the second pic), and WHILE HOLDING IT, touch one of the pads with the iron. If you have a clean, recently tinned soldering iron tip, the small amount of solder on the tip will wick into the joint and hold the component in place (once it cools)
Step 3 is to check that the component has stuck, then solder the OTHER pads before finishing the first one off. Try not to get too much solder on the joint. You're after nice smooth meniscuses rather than big blobs.
If you're solering onto a board that you have made yourself, tin the pads then remove excess solder with solder wick before doing step 1.
Jul 10, 2010. 6:27 AMgrk2meet says:
im going to solder a fan to my modem but im wondering if i solder it to my modem would i short circuit it and render the modem useless or wreck the flow of electricity through it?? (((i know absaloutely nothing about soldering)))
Feb 26, 2009. 4:45 PMWaffle man says:
When Solder Circuit Boards, here's a couple of tips. First make sure your grounded to something. You can fry small parts with just static electricity from your fingers. A simple Esd wrist strap and an alligator clip attached to a conductive surface will do. Also, for far better results when Soldering, go to an electronics supplier and buy a bottle of "Rosin" flux. you can buy a cheap dispenser there as well. It's a small plastic bottle with a needle sized nozzle on it. I worked as an SMT Solderer for a few years and this liquid flux was the norm. It makes for far better soldered joints than by simply relying on the flux in the Solder.
Apr 11, 2009. 3:37 PMjpoyner says:
Would you use the "Rosin" flux in place of the solder wire or in conjunction with it?
Jan 25, 2010. 12:48 PMMagellan7t says:
Flux is effectively a cleaning agent. It removes oxides from the surfaces to be soldered so the solder can flow well.
You use liquid flux in conjunction with flux-cored solder. Just a little extra flux in the right places makes the work go much more smoothly.
Jan 29, 2009. 2:52 PMBradlez92 says:
is it acceptable to tin both contacts your using on the circuit board?
Jan 25, 2010. 12:44 PMMagellan7t says:
You would if you were using a hot air soldering station. When doing it with a conventional iron, it's easier to do only one pad at a time.
May 20, 2009. 10:55 PMthe_letter_7 says:
you could but it would be tricky, as the solder will harden after just a few seconds. So you would have to keep both sides hot enough simultaneously and then quickly apply the component, which is kind of unrealistic as you can only apply the iron to one spot at a time, unless you have two irons and another hand.
Dec 1, 2009. 9:23 AMyankeee7 says:
doesnt the soldering iron melt the circuit board because it is so hot? could you explain why or why not?
Dec 3, 2009. 6:14 PMkillersquirel11 says:
no it doesn't because the melting point of the circuit board is higher than that of the soldering iron.  Extended exposure to heat can damage the boards by causing the traces to separate from the board.
Apr 9, 2009. 3:08 AMonecooldudemiester says:
this guide is helpful
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
894
Author:noahw
Editor of the Workshop and Outside channels...I'm back!
