Introduction: How to Solve a 5 by 5 by 5 Rubik's Cube
In this Instrucable you'll learn how to solve the 5 by 5 by 5 rubiks cube. First I wanted to say, that I'm german, so f I have any spellingmistakes please tell me. I also wanted to say that I invented all movements at my one exept of the special case.
Step 1: Before You Begin
Before begin Beginning you should know what the movements mean. If there are only the letters turn it clockwise, if there is the letter and ' turn counterclockwise. The directions "FC", "SC" and "UC" will come with arrows (→↓←↑)
Step 2: Scramble
Step 3: Center Cross
It's finally time to start! Just follow the pics.
The algorythmus for the first pic is:
U F l' U'
The algorythmus of the second pic is:
u2
Step 4: Compleating the Centers
Now you'll complete the centers.
The algorythmus of the first pic is:
Ff d f'
The algorythmus of the second pic is :
Rr' d' r
The algorythmus of the third pic is:
r' d2 r d Rr' d' r
Step 5: The "Diament"
Now you'll solve the center edgepieces of the first layer.
U'
U
U' FC← U
The algorythmus of the fourth pic is:
U2
Step 6: The Fat Cross
Now you'll make a fat cross
d F d' F'
u' F' u2 F
F u F'
F' d F D l D' l' F d' F'
The algorythmus of the fifth pic is:
d' L' d L
The algorythmus of the sixth pic is:
u L u2 L'
The algorythmus of the seventh pic is:
F' d' F
The algorythmus of the eighth pic is:
F d' F' D' r' D r F' d F
Step 7: Finishing the First Layer
It's time to finish the first layer.
The Algorythmus for the first pic is:
F D F'
The Algorythmus for the second pic is:
L' D' L
The Algorythmus for the third pic is:
L' D2 L D L' D' L
Step 8: Centerpieces of the Second Layer
Now you'll start solving the centerpieces of the second layer. You'll have to solve first the edgecenterpieces, then the cornercenterpieces.
The algorithm of the first pic is:
F2 d' F2
The algorithm of the second pic is:
d2 F R d F' d' F d F' d' F R' F'
The algorithm for the third pic is:
d2 F R d F' d' F R' F'
The algorithm for the fourth pic is:
Uu d F' L' d' F d F' d' F d F' L F Uu'
The algorithm for the fifth pic is:
Uu d F' L' d' F d F' L F Uu'
Step 9: Compleating the Second Layer
It's time to compleat the second layer.
D' L' D' L D F D F'
D F D F' D' L' D' L
The algorythmus for the fird pic is:
L' D' L D F D F' D L' D' F D F D F'
Step 10: Centerpieces of the Third Layer
Now you'll solve the centerpieces of the third layer.
F' Ll' d' F d F' Ll F
d' F Rr d F' d' F Rr' F'
Step 11: Compleating the Third Layer
It's time to compleat the third layer.
d R' Ff' d' L d L' Ff L
D' F Rr D F' D' F Rr' F'
Step 12: Centerpieces of the Fourth Layer
It's time to start the fourth layer!
F Rr UC↑ U UC↓ U2 UC↑ U UC↓ Rr' F'
The algorythmus ofthe second pic is:
l' U2 l U l' U l
r U2 r' U' r U' r'
Step 13: Finishing the Fourth Layer
Now you'll finish the fourth layer.
The algorythm for the first pic is:
D' F RrUC D F' D' F RrUC' F'
The algorythm for the second pic is:
UuFC d' F' LlUC' D' F D F' LlUC F
Step 14: Swapping the Cornerpieces
Now it's time to swap cornerpieces. They don't have to be turned correctly, just swaped correctly.
The algorythmus is:
B U B' U' B' R B R'
Step 15: Turning the Cornerpieces
It's time to turn the cornerpieces. The algorythmus is:
L U' L' U L U' L' D L U L' U' L U L' D'
Step 16: Swapping the Center Edgpieces
Now you'll start swapping the edgepieces. It doesn't matter how they are tilted.
The algorythmus is:
UC↑ U' UC↓ U2 UCt U' UC↓
Step 17: Tilting the Center Edgepieces
Now it's Time to tilt the center Edgepieces.
The algorythmus is:
L FC→ L2 FC2 L U' L' FC2 L2 FC← L' U
Step 18: Putting the Rest of the Edgepieces Into the Right Possision
Now comes the most complecated step. You'll have to put the rest of the edgepieces into the right posisson. You'll have to make first edgepiecepairs with opposit colors. You'll have to switch edgepairs to switch the edges correctly. You'll find everything on the pics.
r U2 l' U2 l U2 r' U2 l' U2 l U2
The algorythmus for the second pic is:
l' r U' l r' U2 l' r U' l r'
Step 19: Tilting the Edgepiecepairs
Your finally at the last Step! You just have to tilt the edgepiecepairs.
The algorythmus is:
R u' d R2 u2 d2 R U' R' u2 d2 R2 u d' R' U
Step 20: Special Case
You'll sometimes have a special case, that only one edgepair has to be tilted.
The algorythmus is:
r2 B2 U2 l U2 r' U2 r U2 F2 r F2 l' B2 r2
