In order for you to be able to finish the cube, you will need to be able to solve a 3x3 cube, but being able to solve a 4x4 cube would also enhance your abilities for it, since the algorithms can be used on both.
If anything is unclear, just ask and I can clarify it for you
Please note:
1. This is a LONG INSTRUCTABLE. It will take time and effort to get through this cube, and you need to have some free time to solve your cube.
2. I am Canadian, so deal with the u in colour.
3. I am assuming you have a 5x5 cube. If you do not, they cost up to $40 CAD, so be prepared to spend a little bit of money on it.
Remove these ads by
Signing UpStep 1My collection/experience
I can solve all the puzzles you see here, no instructions.
I found out how to do this by watching a long youtube video tutorial about how to solve this, and read some text instructions. I have 2 5x5 cubes, a few 3x3 cubes, and the 4x4 cube.
this may result in and edge swap (the opposite edges are swapped) put them in the TB and TF edges, and perform; 2Uu, 2Ll, 2U, 2l, 2U, 2Ll, 2Uu. that should fix those problems.
the algorithm to swap the two corners: place the two solved corners in the back of the cube (assuming the top is solved and not permuted) perform; R', F, R', 2B, R, F', R', 2B, 2R. email me at twpyromaniac@gmail.com if you have any other cubing questions
Mainly used on the 4x4.
Or what he used on step 14. (The one above is longer, but somewhat easier to memorize.)
-----> u know kinda like that?
Yes, I understand what you're talking about, and yes, there is an algorithm somewhere on the internet, but I never actually learned it. I just use the one that swaps two of the middle edge cubelets, and swap the cubelet over to the other side, then move the edge so that when you swap the cubelets again, two are in the right place, move those so that you can put the last piece in place, and repeat until you're done. I actually solve this a completely different way, chainsolving the edges now, makes it faster, but similar concepts.
Step 8:
"If you needed to rotate any faces, make sure you turn the piece out of the way, so that when you turn it back, the piece stays there"
What?
"Make the 2x3 center on the yellow side using this method"
What method? you haven't given us a method - you've just said "solve this bit..."
I'm not usually an idiot... Last night I was on:
http://www.alchemistmatt.com/cube/rubik.html
And managed to get most of the way to having the centres finished before I mucked something up...
And now - following your instructions - I can't even get the second one done...
the main point when you are moving the pieces to make the opposite center to the one you solved originally is that you need to make sure that once you get some 1x2 pairs that are of the same colour (ie a yellow center edge and yellow center corner), you simply rotate the piece up there, and move it such that your piece that you just put up to the yellow face does not get moved down from the yellow face when you rotate the section back.
I could make a video if that helps you out at all.
