Step by stepp!!
Remove these ads by
Signing Up
Remove these ads by
Signing Up
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
but look at yourself spying is a respectbel thing and your spyng white a nderwear!!!!!!!!!!!!!!!!
1. Change "Here im gonna show you how to Spy with a wirelles Microphone!!!!" to "Here I am going to show you hot to spy with a wireless microphone!!!!"
2. Change "InTroduce De Battery On It Hack!!!! Swith on... And look the LED!!!" to "Put the battery in it, turn the switch on, and look at the LED!!!" (I'm not exactly sure what you meant here... this is the closest I could come up with.)
3. Change "Place the mIc Where you want to Spy and In the Radio Sintonyse The Frequensy Of your mic!!! Almost always is on LOw numbers like 88.3 88.7 88.5 And like that!!!" to "Place the mic where you want to spy and in the radio synchronize the frequency of your mic!!! Almost always is on the low numbers like 88.3, 88.7, 88.5, etc."
These are just suggestions, I don't mean these in a critical way, I thought you did very good. (I think it would help your chances of winning if you used these, but then again; I am not one of the judges!) :)
A technical note:
Not many wireless microphones in the United States use the same frequencies as FM radio stations because it is against Part 15 of the FCC rules and regulations. Those that do are illegal in most places.
Good luck! :)
Thanks!
