3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to take a fall (Skateboarding)
  • last photo ←
This is an instructable on how to take a fall while skateboarding. In this example, Bruno will be showing you how to fall while grinding a ledge.
Step 1Step 1
Step 1
Bruno begins to crouch like normal to start his trick.
101 comments
1-40 of 101next »
Mar 24, 2012. 4:06 PMhyruler_ says:
nice. it was quite humorous but still stayed on topic!!
Aug 19, 2009. 10:30 PMbulletprooftaco says:
just saying I was in a martial art called judo and the first thing they teach you is when you fall don't land on your hands if you do it might brake your wrists
Nov 24, 2011. 1:52 PMPotatoCoffee says:
I think it's called Mari ukemi or something... I do judo to by the way.
Oct 30, 2009. 3:25 AMThePuppeteer says:
 ...neither with your head (as picture shows).
Try with forearm/arm/shoulder (the left from the picture) towards your chest. The you'll roll properly ;o)
Jan 11, 2010. 1:18 PMfoxtrot4697 says:
It is amazingly easy to break your arms that way(landing on your hands), my friend barely fell at all and landed on his arms. And guess what? He broke his arm
Nov 12, 2011. 4:42 PMfreeza36 says:
Falling like this would never work. Hit feet first and roll off to the side, while bending your knees. I'm surprised you didn't break your wrists.
Apr 18, 2010. 1:48 PMLucasReid says:
 you seriously all don't realize this is a joke??
Oct 13, 2011. 8:01 AMmelaniemelanie says:
Exactly
Oct 10, 2011. 3:33 AMjimmytvf says:
even i don't know anything of skateboarding, the way to fall like this, is very tough. You can fold your wrists and break them, therefore too, YOU'LL STOP THE IMPACT WITH YOUR HEAD WITH NO HELMET!! even with helmet, you can break your neck like your wrist. The best way to fall is like a cat, like nerd12 said. You land with your hands on the floor, over your head, the force pass to your arm and your shoulders, not the wrist itself, and then use your legs to make just the same. With some luck, you should do 3 or 4 steps, and you're up again. If not, you can use this parts like a spring and absorb the major part of the shock. Is just physics. action-reaction
Oct 5, 2011. 7:43 AMnerd12 says:
isint this kinda trivial thing to post on?
the best way to absorb the fall is like a cat.
bend your hands and knees and transfer the vertical movement to horizontal.
i always jump down the stairs by about 10ft at a time(diagonally) and this works for me.
May 16, 2011. 3:43 PMBAKEMASTER33 says:
Do not do this you WILL get HURT.
Aug 24, 2011. 6:56 PMjosh1324 says:
Do not roll? That is the stupidest comment i have ever seen, if you do fall properly, you could break your neck or split your head open. Next time you write a comment, think about it before you post it.
Oct 5, 2011. 7:41 AMnerd12 says:
if he rolled like that i am surprised he did not crack his skull like an omelet and break his neck.
1. that was a gymnastic roll, not a proper shoulder roll. so it hurts his neck.
2. at that angle he most certainly would break something.
3. rolling is fine is done properly. this is not properly.
Mar 23, 2011. 10:44 PMjordomaller says:
i always use the tuck and roll technique when falling depending on how big of a drop or bail it is. Most of the time you are going fast enough that when you push off with your hands you just do a sort of front hand spring and most of the impact gets absorbed throught rotation and not just downward momentum.
Mar 20, 2011. 5:47 PMzs says:
i was always told never put your arms down like that, as it ois how you break your arms. Just take the fall and dont risk further injury.
Mar 20, 2011. 6:46 PM_kira_ says:
True. I broke my wrist completely in half when I put my arms out when falling to drop in a half pipe (MINI).
The thing was 4 feet tall! What ever you do, never in your life stick your arms out.
Curl your arms around your head to prevent a concussion and lift the back of your head so it doesn't hit the ground. Head and arms protected.
Your ribs can take a serious beating and be fine. So you don't be afraid of breaking (or bruising) them.
Mar 11, 2011. 2:45 PMsupertoria12 says:
well what if you crack your head and its bleeding heavily. you cant hide that, not to mention you'd need immediate help and a trip to the emergency room. play it safe, dont grind on a ramp like that until you know how to without falling.
Mar 11, 2011. 2:40 PMsupertoria12 says:
In the last image, it looked like he could've landed easily on his feet.
Mar 11, 2011. 2:36 PMsupertoria12 says:
Where's his helmet?
Nov 28, 2010. 2:02 PMPeacemaker636 says:
I honestly don't know how he didn't get more hurt from this. His hands and head are taking all the impact. If at all possible, try to land on your feet, or at least have them hit first...they are much hardier than your head. If you're too off-balance, try rolling on your shoulder or side, tucking your head the whole way. Trying to catch yourself/go into a roll may be more difficult than you expect and next thing you know you've got a concussion.
Jun 18, 2010. 12:41 AMjilllemur says:
Now I know, and knowing is half the battle.
Nov 16, 2010. 3:52 PMspenfisher12 says:
thanks GI joe
Nov 22, 2010. 11:27 AMjilllemur says:
:D
Nov 19, 2010. 11:17 AMpaperairplanecreator says:
lol!
Sep 26, 2010. 9:44 AMjongscx says:
this is how you take a fall...
http://www.spike.com/video/family-guy-peter/2725034
Sep 8, 2010. 1:45 AMtukmol says:
the fall would damage your neck or spine, or even break your skull. at that height, even if you're muscular... you can never tell if your arms, elbows, wrist, and shoulders would bear all your weight at sudden impact.
search videos about Aikido Front Rolls on youtube. this is safer than the one illustrated. been pacticing Aikido for years and had performed these rolls (even hard falls/break falls) on concrete. no injuries.
Aug 29, 2010. 9:29 AMlilrocker90 says:
BAD IDEA
Aug 8, 2010. 9:47 PM1joel8 says:
At first i was like "lol wat?" and then i was like "lol fail"
Mar 14, 2010. 6:04 PMMonkeyboy13 says:
Having your head in that position while falling can give you a broken neck or concussion if your elbows go too far back. A better way to do this to do a side roll. Try to get your feet to the ground, then let yourself fall onto your dominant shoulder and roll off of that. It is much safer and doesn't kill your wrists. I can't fall on my hands anymore because I have "permanent sprain(according to the doctor)" in my right wrist due to falling on it so many times.
Aug 8, 2010. 8:29 AMarkho says:
It's amazing how these skaters survive failed trick falls. I watch them a lot in my hometown block. It's like they don't have no bones. I would have to comment on this position though. I practice judo rolling as well as Aikido jump and fall kind of drop. So, falling on both hands is better than no hands at all. If you're light enough(which skaters usually are) you might be able to carry your weight to support the fall. Just to add a safety precaution, it is best to tuck your head inwards when rolling like this. So inwards that your chin should touch your chest. If your falling to your right, tuck it down to your left and vice versa. This will take some practice to be effective. The purpose of this is that should you fail to support your own weight, you fall on your back and not on your head. Once again in martial arts rolling, you must roll line a wheel starting with your hand to your upper back or top shoulder down to your butt. Like a big red carpet being rolled out.
Jun 2, 2010. 1:34 PMThe Dark Lord says:
No harm meant to be done but... putting your hands out to catch yourself will dislocate your arm. Just saying.
Jun 14, 2010. 12:15 AMbluefly1215 says:
Putting your hands out will fracture your radius and ulna. I have seen many of this type of injury and casted them. Don't lock your arm either. I suggest using wrist splint protectors, and to learn how to absorb the shock with your body.
Jul 9, 2010. 10:03 AMseabananers says:
ow :f
Jul 8, 2010. 9:06 PMcovey12 says:
do a barrel roll! haha yeah no matter how bad it hurts get back up if you can physically do it hahaha
Apr 20, 2010. 3:57 PMEpicZombie says:
thanks. my son is a cub scout and he learned how to do it . (he got a belt loop)
Apr 20, 2010. 12:15 AMtokyosoho says:
I don't care if this is fake, that's pretty funny.
Jan 17, 2010. 1:40 PMnonoodlez says:
 Ok, let me start off with the good: it's nice that you are somewhat compelled to teach people how to prevent hurting themselves.
The rest of this instructable is so terribly misguided I can only list the problems:
1) The photos are very obviously photoshopped. The motion blur is all wrong.
2) The ledge isn't even grindable! The absence of wax or wheelmarks are dead giveaways. Plus, the concrete top is tiled; there are gaps in between that would make skating it even more absurd.
3) Ok all the falling stuff has already been said but you do not want to roll on your head. Period.
Anyways, who cares? Just go out and skate and have fun. You won't learn much about skating from here anyway (not to the detriment of the site; it's awesome!).
Apr 18, 2010. 10:42 AMarticice says:
4) picture 3 is not a real ollie, pictures 4&5 aren't a grinding position, esp. picture 4. Picture 7 is a definite neck-break and death if it was for real.
Apr 18, 2010. 12:07 PMnonoodlez says:
 Yarp!
Mar 20, 2010. 8:56 PMnoobiefied says:
 This is DEFINITELY not a safe way. I vouch for this to be removed. Rolling front ways on your head definitely as a way to kill yourself.
1-40 of 101next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Dj hentai
