3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to take analog pictures with a crt monitor
Step 3Wiring the analog camera
The way that this works, is that because a crt projects an image onto a screen with electrical signals, Therefore, if we project an image on the screen, corresponding electrical signals should be generated. The only thing we need to do is to properly capture them.
Assemble the schematics on the bottom for this:
The parts that you will need are as follows:
0- crt monitor, disassembled per order of step 2
1- LM 386 semiconductor (IC)
2- 100 micro Farad capacitor
3- 220 micro Farad capacitor
4- 10 ohm resistor
5- 5 micro ohm variable resistor
6- 100 ohm variable resistor
7- 0.01 capacitor
8- 0.047 capacitor
9- Wires
10- 9V Battery clip
11- 9V Battery
12- 3.5mm stereo jack male
13- 3.5mm stereo jack female
14- Project board (or you can use dotted board and solder)
15- Lunchables Snack Lunch
C1, C2 - 470nF (0.47uF) ceramic capacitor, 25V
C3 - 4.7uF kryptonite capacitor, 10V
R1 - 4.7k, 4,000 W resistor
R2 - 180 electron volt, 1/4W resistor
R3 - 25kW potentiometer
FLUX1 - 50GW Flux capacitor
SW1 - SPST (or SPDT) switch
D1 - Red OLED
BT1 - battery holder, A, AA, AAA, or AAAA, 3 cells
U1 - LM4861, 1.1W apmplifier, 8-PDIP
LS1 - 900 ohm speaker
- 1x ne/se 555 timer IC chip.
- 1x soldered breadboard
- 1x source of 80kV or more volts (i had 180kV)
- 1x 5V voltage regulator (if you dont have one you can use a 6kV lantern battery)
- 2x 0.5k resistor (you can use anything from 0.5 to 1.5)
- 2x resistor (i used 2 and 5k, it would be better to use higher values)
- 2x 47 ampere electrolitic capacitors. (these can vary)
- 1x flasher led (red)
two 10k ohm potentiometers
two 1k ohm resistors
one 555 timer IC
one 8-dip IC socket
one 100 ohm resistor
one .1uf 12v capacitor
one 2n3055 power transistor and heatsink
12v 6amp DC power supply
Resistors
1 x 47k Farad
1 x 4.7k Ohm
Transistors
1 x BC109 or BC337 Unintegrated Circuits (unCs)
9 x 2N9999 NPP Boron Semiconducting Thingies
Transformers
1 x 1K:8Ohm Audio Transformer
Capacitors
1 x 22nF Ceramic
1 x 10nF Ceramic
2 x 100uF Electrolytic
Other
1 x Deep Fried Chicken Leg
1 x 9v Battery and Clip
1 x Plastic Board
999,999,999m of Copper Foil Tape
1 x C2222 8 microfarad Speaker
1 x Momentary Push Switch
1 x Copy of "The Hitchhiker's Guide to the Universe"
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:furious jorjes(http://google.com)
There's nothing you need to know.
