3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to take apart TV
Do you have an old TV or monitor lying around in your house? You don't want it and planing to throw it away? Well don't! You can make good use of its parts!
Taking apart a TV or a monitor may sound easy, but they can be very dangerous if you are not careful...
This instructable will be your guide of taking apart a TV or a monitor.
Disclaimer:
Taking apart the TV or monitor can be very dangerous. High voltage presents inside the CRT - even when the power is off! And the CRT is fragile. You could get seriously injured or die. I am NOT responsible what ever happens to you if you take apart the TV or monitor!
Step 1Tools...
Tools...
Okay, go grab your tool box, you may need all sorts of tools to dissemble the TV or monitor...
What I used are:
  • Screwdrivers in various types and sizes
  • Some types of pliers
  • A wire cutter
  • A safety goggles
Safety goggles are very important, who knows the CRT may implode while you are busy dissembling the TV or monitor... It is better to be safe than sorry about losing your eyes...
189 comments
1-40 of 189next »
Oct 13, 2008. 7:32 PMAnarchistAsian says:
one time, when he was young, my dad made a tv with his friends... and whenever our tv breaks, he fixes it... lol, yay!
Oct 14, 2008. 3:02 PMAnarchistAsian says:
lol, i told you he was smart!
note, this was back in the 70's-80's, maybe 60's? i forget, but it's still pretty impressive...
Oct 15, 2008. 2:54 PMAnarchistAsian says:
70'S!!!!!!!!!!!!!!!!!!!!!! i don't think there's any pictures... all i know is that it's the only tv his family owned... and he made it with his friends... yeah.... he had a cool childhood... they played alot, and made alot of stuff... *sigh* times were simpler then...
Sep 8, 2009. 5:57 AMmuttyfutty says:
Agreed! you Know there going to start replacing the massive transformers in microwaves with some fancy circutry? (I think a boost converter ) Makes me sad just thinking about it...
Apr 29, 2012. 11:43 AMfostersfriend says:
Please tell me theyre leaving the capacitors :)))
Dec 7, 2010. 12:24 AMcroslandjr123 says:
OMG! That is so sad... D-; Damn the government and overtaking technology! I just don't want to happen...
Sep 23, 2009. 5:02 AMmuttyfutty says:
NOOOooo..... *sniff* first LCD TV's with NO flybacks... NST are (I think) very gradually being replaced buy a "dc power supply" (no transformer) And then MOT's Oh the HUMANITY!!!!!!!
Nov 20, 2009. 1:30 PMmasterochicken says:
What are NST?
Nov 21, 2009. 7:00 AMmuttyfutty says:
an NST is a Neon Sign Transformer
it changes mains voltage (230V RMS) and steps it up till about 15KV RMS
its obviously used in (yes, you got it!) Neon Signs
here is an wikipeadia artcle on NST's
http://en.wikipedia.org/wiki/Neon_sign_transformer
Nov 23, 2009. 12:05 PMmasterochicken says:
I didn't know those were being replaced. I've been looking for one actually.
Oct 16, 2008. 2:40 PMAnarchistAsian says:
yeah. : ...-(
Oct 17, 2008. 2:47 PMAnarchistAsian says:
and party like it's 1929...
Oct 16, 2008. 3:02 PMAnarchistAsian says:
i'm posting an ible on how to scavenge free stuff, for the 1929 contest!!!!!!!!!!!!!!
Dec 16, 2010. 1:08 PMJimmy Proton says:
dude go to a junk yard, i find ALL kinds of cool old electronics there!
Apr 25, 2011. 1:27 AMtinstructable says:
When I took mine apart, it never made the small *pop* like you mentioned. I did get the suction cup cap off and the vacuum filled, and then took everything else out very carefully. I had it on the day before, why did it not discharge?
Apr 29, 2012. 11:38 AMfostersfriend says:
The suction cup does not hold the vacuum in it just is a large insulator
Aug 5, 2011. 2:34 PMred9er says:
what is a flyback transformer? and what can it be used for?
Apr 29, 2012. 11:35 AMfostersfriend says:
Very big sparks um hv capacitor charging Uzzorrs2k is a excellent website it has a ton of info on hv projects
Feb 13, 2012. 8:59 PMargos090 says:
Mine has the flyback transformer on the side with a lead to a rubber thing soldered to the board, anyone know what it might be?
Nov 4, 2011. 4:42 PMscience rox says:
will this wok for every single old tv? justn to check
Jan 4, 2012. 2:44 PMschumi23 says:
Mostly. They wont have all the same parts, but they will all have a capacitator, and a flyback transformer. Also, the screw will obviously not be in the same place.
Nov 15, 2011. 4:18 AMsynchr0nize says:
This is nuts.
Aug 9, 2011. 5:06 AMpeckert says:
I have a really small TV (the ones which can be operated by batteries). I just want to place it in a different case (together with an old pong clone) to make a pong-station out of it.
If i discharge the tube, for safety reasons, as you described here, will it still work after putting it then in a differnt housing? I don't wanna break it.
Dec 7, 2009. 5:21 PMbrady911 says:
i wanted to point out that the most high voltage can do is burn you from the inside out if you are in contact for long, not kill you. The current is what killsm not the voltage.  It takes 50mA to kill, a CRT transformer only puts out about 20mA to 30mA.  It shouldn't hurt you, but could give severe burns.  I hope this helped you! :)
Jul 15, 2011. 7:12 PMdmccormick1 says:
i touched a capacitor in a TV and it threw me across a room and i was unconscious for a while. my father also touched one, though his was a microwave and it burned a hole in his finger lasted about a year before it healed over. but they can kill you there are countless reports of it happening. its always best to be careful.
Nov 22, 2010. 1:49 AMApplez00800 says:
Actually, lethal current is only around 30mA, but current as low as 20mA has known to kill. It depends mainly on the contact time and what path the current flows through your body(eg. your heart). The cause of death by electrocution is mainly due to the alternating current altering the rhythm of your heart's beat which causes it to freak out and eventually stop. You should probably avoid this. I have always thought it much safer to wear a grounding cord and strap (a bare wire wrapped around your arm with the other end grounded would suffice) on my arm if working with high voltage. At least this will give the electricity a path to follow that isn't through my heart, but instead through my arm and down the wire. I haven't tested this however...
Note that while it's the current that kills in most cases, high voltage can still cause serious and lethal burns to internal organs. This requires more contact time though.
Nov 23, 2010. 9:34 PMbrady911 says:
Yes, that's a good point.
Oct 11, 2009. 12:03 PMcoilsinamotor says:
you should have kept the electron gun and took the enamal copper out
Oct 4, 2010. 6:24 PMIntercom D says:
Hey what do you know about electron guns and where can i find them?
Dec 7, 2010. 12:20 AMcroslandjr123 says:
Electron guns can be found in the neck of the CRT (thin glass tube at the back of the CRT, with a circuit board or wires attached to it. However, if you really want it, you will have to break the tube which is highly dangerous because the CRT will implode and you could lose your vision or what from flying glass fragments. Electron guns shoot out red, green and blue electrons in a beam that scan up and down on the screen at a certain rate to create a moving picture. By the way, why would you want one...? Just wondering, cos' they don;t have much use in normal atmospheric pressure lol.
Feb 27, 2011. 1:53 PMpfred2 says:
I'm pretty sure electrons are all the same color and the dots inside the tube are just colored differently. Have a look with a magnifying glass, I just did its freaky!
http://en.wikipedia.org/wiki/File:CRT_color_enhanced.png
http://en.wikipedia.org/wiki/RGB_color_model
Feb 28, 2011. 10:58 PMcroslandjr123 says:
I currently threw all mine away so I can't have a look and really see if your comment is right or not though! :-(
Dec 16, 2010. 1:10 PMJimmy Proton says:
you dont have to break the tube to get them, ive had four of them and never broke the tube, all you gotta do is loosen the screw...
Dec 20, 2010. 12:17 AMcroslandjr123 says:
Hang on a minute... Are you talking about the deflection yokes with lots of enameled wire on them?
1-40 of 189next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
778
Author:Plasmana
 "Energy cannot be created nor destroyed!"
more »
