How to take apart a case fan by Punkguyta
I thought it would be helpful to some to put together a quick but informative instructable on how to take a case fan (or any computer fan for that matter) apart down to the bearings and motor assembly.
This way you can soak/clean/wash the fan blades without risking damage to the pcb from immersing it in liquids. You can oil it too afterwards if you like.
And yes, this applies to all computer fans of all sizes, however be warned, the smaller computer fans (such as those found on GPU's) are a lot trickier to pull the ring off to remove the fan blades.
Step 1: Remove the restriction ring
As you can see, you want to remove the white plastic ring from around the end of the axel. A pair of tweezers or the tip of a thin pocket knife also works, however be careful not to break the ring, as you'll need to for later when you put the fan back together.
Also, some case fans have metal clasps instead of plastic, I'll try to get a picture of one later this week.
Step 2: Clean the fan
Now for the fun part, everyone has their own methods, and depending on the build up it may need anything from a blast of air from an air compressor to soaking it to remove the caked up gunk
This isn't something I recommend doing a half-ass job on, as you'll only be taking it apart a month later because all the dust you left on the fan will collect even more dust, especially if it's still wet when you start using it again.
I myself soak the fan blades in a secret blend of hydrochloric acid and rubbing alcohol (I'm only joking about the former).
1-40 of 46Next »
zack247 says: Aug 3, 2010. 1:07 AM
lol. the kernels secret blend of 11 herbs and spices... mmmmmm... great info! and would sewing machine oil work for lubing the fan?
computer_guy says: Jan 10, 2010. 8:25 PM
Green gloW~
computer_guy says: Jan 10, 2010. 8:23 PM
ewww.... that's dirty... LoL
SoulNefarious says: Jul 11, 2009. 12:05 PM
Yo, when I took apart my fan I kinda... misplaced... the restriction ring. Do i have to make another one or is my case fan fine without it? Im using it as a side case fan, so if the blades somehow fly off, the case will stop them and they'll be nowhere to go. Thanks for a response.
Punkguyta (author) says: Jul 11, 2009. 5:32 PM
I lost one once too and Im running that same fan in either my pc or my server, not sure which, but there are no problems.
SoulNefarious says: Jul 11, 2009. 11:57 PM
Sweet, thanks. lol, I was afraid the blade might fly out and boomerang inside my new pc build XD
Dipankar says: Jun 22, 2009. 4:10 PM
Excellent idea of servicing the fan. I got an extra SMPS fan which I fixed on top of my Monitor and connected it to my PC power socket, now I get air when I switch on my PC.
Punkguyta (author) says: Jun 22, 2009. 10:21 PM
SMPS fan? What's that? And that's a good idea, are you using it to cool a crt monitor?
Dipankar says: Jun 23, 2009. 5:22 PM
Switched Mode Power Supply (SMPS) This is where the AC supply first comes to your PC. here it is converted to DC and voltage of 3, 5 and 12 are supplied to various components of your PC. It has a very powerfull fan which can be used for various purpose.
Dipankar says: Jun 23, 2009. 5:08 PM
Swiched Mode Power Supply (SMPS) This is where the AC supply first comes to your PC. There it is converted to DC and voltage of 3, 5 and 12 are supplied to various components of the PC. It has a powerful fan which can be used for various purpose.
Punkguyta (author) says: Jun 24, 2009. 5:55 AM
Gahhhh, only send me one message man. Check your pm's
Derin says: Jan 30, 2009. 9:55 AM
Also,don't underestimate cleaned and oiled fans.One hurt me,and got blood involved.
smn368 says: Mar 7, 2009. 3:28 PM
i sliced the tip of my finger off with a huge 150mm case fan (it had metal blades)
Punkguyta (author) says: Jan 30, 2009. 4:46 PM
How exactly are you gonna cut yourself on a plastic case fan?
humrattle says: Sep 28, 2009. 8:56 PM
Just this evening I nearly sliced the tip off of my middle finger while i was testing a potentiometer connected to a DELTA PFB0912DHE (8000RPM). It can happen, blood, pain, and all. Be careful with high speed fans no matter what they are made of.
Derin says: Jan 30, 2009. 11:56 PM
At 3000 rpm it can cut me on the edge.Just say I accidentally touched the edge of the blades....
Punkguyta (author) says: Jan 31, 2009. 9:09 AM
I have a 7300rpm thermaltake fan on my AMD's cpu, I've stopped it more than once with my index finger, sans blood. I still have no idea what you're talking about unless you have the skin of a 80 year old.
sdallesasse says: Feb 1, 2009. 10:54 AM
If he touched the wrong side of the fan, the blade would slice into and not away from the finger.
Punkguyta (author) says: Feb 2, 2009. 10:35 AM
Shouldn't really matter where you put your finger in, all the blades still rotate in the same direction. And I still haven't cut myself off a fan, that's why I think it sounds rediculous, sorry if It's not.
Derin says: Jan 31, 2009. 12:23 PM
But you touched the middle,right?
Punkguyta (author) says: Feb 2, 2009. 10:34 AM
No, this is what I have, as you can see, you can't touch the middle part of the rotor to slow it down. I've put my finger right in there where the spokes turn several times both accidently and not on accident. I didn't even get a scratch.
zack247 says: Sep 26, 2009. 10:16 PM
man, that is the BEST heatsink EVER!! now im jealous cause i don't have one
Punkguyta (author) says: Sep 27, 2009. 12:39 PM
I have actually since removed this heatsink from my computer because it was too loud for my liking, I shouldn't have to turn my stereo up half way to drown out the sound of the fan.
zack247 says: Sep 27, 2009. 5:32 PM
well, i had a really loud fan, but i cleaned it, now you can't even tell it's there! its amazing!
Punkguyta (author) says: Sep 29, 2009. 1:16 PM
Actually no, it's just a really loud fan out of the box.
zack247 says: Sep 29, 2009. 5:03 PM
i still want one.
Plasmana says: Feb 5, 2009. 12:59 PM
Now, imagine the fans are spinning in the opposite direction...
Dr.Bill says: Feb 13, 2009. 8:50 AM
Just used your Instructable on a fan I'm turning into an anemometer. Thank you.
Punkguyta (author) says: Feb 13, 2009. 9:09 AM
Sweet deal, let me know how it goes for you!
Dr.Bill says: Feb 13, 2009. 2:04 PM
I just got the blade off and the fins trimmed off and put it back together. All I need now is plastic easter eggs for wind cups. Thanks again Dr. Bill
Plasmana says: Feb 5, 2009. 1:01 PM
Wow, i wish I had this information a few years before, I had already ripped up my fan accidentally by trying to get the blades... I will try again... Thanks for this great instructable! 5 stars!
Punkguyta (author) says: Feb 5, 2009. 8:31 PM
No prob, I'm glad my instructable was of any use to you!
Scott_Tx says: Jan 20, 2009. 9:20 AM
I like to use grease instead of oil, it lasts a lot longer before needing re-lubed.
Punkguyta (author) says: Jan 20, 2009. 3:50 PM
I suppose.. But the only place you could really use grease properly would be when you had the fan prop removed and rub the shaft with grease. Just shoving it into the end cap under the sticker will not only do no good (how is it supposed to seep into the bearing? they aren't open bearings, they have covers around them) But not only that, when you do need to re-do them, it's a mess to clean out I could imagine. I haven't tried it, but I think perhaps a light grease would be good for the fan shaft and use oil for the bearings (actually I guess I forgot to mention how I take the bearings out and soak them in a container of oil, does wonders.)
Scott_Tx says: Jan 20, 2009. 4:24 PM
It does work itself in if you put it on the end, I've done it many many times that way but only if its spinnable. If its completely seized up you have to take it apart.
Punkguyta (author) says: Jan 21, 2009. 12:56 PM
yeah I've had a couple completely locked up fans, but soaking the bearings usually fixes that up pretty quick.
Derin says: Jan 28, 2009. 10:23 AM
Mine provides some resistance to my hand,but it turns.
Derin says: Jan 28, 2009. 10:24 AM
The motor does not turn it by itself.
Punkguyta (author) says: Jan 28, 2009. 2:40 PM
No it doesn't, when did I say that? The motor is built into the rotor ( the fan blades).
Derin says: Jan 29, 2009. 10:13 AM
I know,I meant the prop does not turn by itself.
1-40 of 46Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
