3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to take apart a case fan
I thought it would be helpful to some to put together a quick but informative instructable on how to take a case fan (or any computer fan for that matter) apart down to the bearings and motor assembly.
This way you can soak/clean/wash the fan blades without risking damage to the pcb from immersing it in liquids. You can oil it too afterwards if you like.
And yes, this applies to all computer fans of all sizes, however be warned, the smaller computer fans (such as those found on GPU's) are a lot trickier to pull the ring off to remove the fan blades.
Step 1Remove the restriction ring
As you can see, you want to remove the white plastic ring from around the end of the axel. A pair of tweezers or the tip of a thin pocket knife also works, however be careful not to break the ring, as you'll need to for later when you put the fan back together.
Also, some case fans have metal clasps instead of plastic, I'll try to get a picture of one later this week.
46 comments
1-40 of 46next »
Aug 3, 2010. 1:07 AMzack247 says:
lol. the kernels secret blend of 11 herbs and spices... mmmmmm... great info! and would sewing machine oil work for lubing the fan?
Jan 10, 2010. 8:25 PMcomputer_guy says:
Green gloW~
Jan 10, 2010. 8:23 PMcomputer_guy says:
ewww.... that's dirty... LoL
Jul 11, 2009. 12:05 PMSoulNefarious says:
Yo, when I took apart my fan I kinda... misplaced... the restriction ring. Do i have to make another one or is my case fan fine without it? Im using it as a side case fan, so if the blades somehow fly off, the case will stop them and they'll be nowhere to go. Thanks for a response.
Jul 11, 2009. 11:57 PMSoulNefarious says:
Sweet, thanks. lol, I was afraid the blade might fly out and boomerang inside my new pc build XD
Jun 22, 2009. 4:10 PMDipankar says:
Excellent idea of servicing the fan. I got an extra SMPS fan which I fixed on top of my Monitor and connected it to my PC power socket, now I get air when I switch on my PC.
Jun 23, 2009. 5:22 PMDipankar says:
Switched Mode Power Supply (SMPS) This is where the AC supply first comes to your PC. here it is converted to DC and voltage of 3, 5 and 12 are supplied to various components of your PC. It has a very powerfull fan which can be used for various purpose.
Jun 23, 2009. 5:08 PMDipankar says:
Swiched Mode Power Supply (SMPS) This is where the AC supply first comes to your PC. There it is converted to DC and voltage of 3, 5 and 12 are supplied to various components of the PC. It has a powerful fan which can be used for various purpose.
Jan 30, 2009. 9:55 AMDerin says:
Also,don't underestimate cleaned and oiled fans.One hurt me,and got blood involved.
Mar 7, 2009. 3:28 PMsmn368 says:
i sliced the tip of my finger off with a huge 150mm case fan (it had metal blades)
Sep 28, 2009. 8:56 PMhumrattle says:
Just this evening I nearly sliced the tip off of my middle finger while i was testing a potentiometer connected to a DELTA PFB0912DHE (8000RPM). It can happen, blood, pain, and all. Be careful with high speed fans no matter what they are made of.
Jan 30, 2009. 11:56 PMDerin says:
At 3000 rpm it can cut me on the edge.Just say I accidentally touched the edge of the blades....
Feb 1, 2009. 10:54 AMsdallesasse says:
If he touched the wrong side of the fan, the blade would slice into and not away from the finger.
Jan 31, 2009. 12:23 PMDerin says:
But you touched the middle,right?
Sep 26, 2009. 10:16 PMzack247 says:
man, that is the BEST heatsink EVER!! now im jealous cause i don't have one
Sep 27, 2009. 5:32 PMzack247 says:
well, i had a really loud fan, but i cleaned it, now you can't even tell it's there! its amazing!
Sep 29, 2009. 5:03 PMzack247 says:
i still want one.
Feb 5, 2009. 12:59 PMPlasmana says:
Now, imagine the fans are spinning in the opposite direction...
Feb 13, 2009. 8:50 AMdrbill says:
Just used your Instructable on a fan I'm turning into an anemometer. Thank you.
Feb 13, 2009. 2:04 PMdrbill says:
I just got the blade off and the fins trimmed off and put it back together. All I need now is plastic easter eggs for wind cups. Thanks again Dr. Bill
Feb 5, 2009. 1:01 PMPlasmana says:
Wow, i wish I had this information a few years before, I had already ripped up my fan accidentally by trying to get the blades... I will try again... Thanks for this great instructable! 5 stars!
Jan 20, 2009. 9:20 AMScott_Tx says:
I like to use grease instead of oil, it lasts a lot longer before needing re-lubed.
Jan 20, 2009. 4:24 PMScott_Tx says:
It does work itself in if you put it on the end, I've done it many many times that way but only if its spinnable. If its completely seized up you have to take it apart.
Jan 28, 2009. 10:23 AMDerin says:
Mine provides some resistance to my hand,but it turns.
Jan 28, 2009. 10:24 AMDerin says:
The motor does not turn it by itself.
Jan 29, 2009. 10:13 AMDerin says:
I know,I meant the prop does not turn by itself.
1-40 of 46next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:Punkguyta
I'm one hell of a guy, what can I say, hey and as a human being, I even feature a cranial capacity of 1350cc, how's that for feature listing?
