How to test Bipolar Transistors if you have an Analog Multimeter
 by Talking Electronics
Step 2: For PNP Transistors
1. Set your Analog Multimeter to Ohmmeter X1 Ohm Scale.
2. Connect the Negative Probe (Black) to Emitter and the Positive Probe (Red) to the Base. The needle should deflect to the right side,reading less than 100 ohms.
3. Now invert the probe connections to the Emitter for the Red Probe and to the Base for Black. The Needle should not deflect.
  • If the results are the same as above, your Emitter-Base junction is OK.
4. Now we will be testing the Base-Collector junction. Connect the Red probe to the Base and the Black probe to the Collector. The Needle should deflect to the right, resistance usually is not less than 100 ohms.
5. Invert the probes again, Black to the Base and the Red probe to the Collector. The Needle should not move.
  • If results are the same as above, your Base-Collector junction is Ok.
6. Connect the probes to the Emitter and Collector (probes may be inverted), a reading above 1Kohms indicates a working transistor.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
