How to Tie a Trinity Knot
4,051
158
Posted in CraftFashion
Introduction: How to Tie a Trinity Knot
The Trinity Knot is a fun and interesting knot. Being that it is so uncommon many people often are impressed by how much it stands out. It's definitely a crowd pleaser!
Step 1: Get Your Tie in Position
Being that this knot is tied with the narrow end you should get the wider end at a comfortable length; which for  most people is around 1-1.5" above their belt line. Whichever hand is best suited for you put the narrow end of the tie in that hand.
Step 2: Put the Narrow End Over the Wider End
As aforementioned this knot is tied with the narrow end. Take the narrow end and cross it over the front of the wider end.
Step 3: Wrap Around and Up
Once you cross over the wider end wrap behind it and pull up
Step 4: Pull the Narrow End Down
Pull the narrow end down and to the side
Step 5: Wrap Around to the Back
Now pull the narrow end behind the loop and out to the other side
Step 6: Pull It Upwards
Once your narrow end is around pull it upwards, but at an angle towards the center so that it is easier to complete the next step.
Step 7: Pull Around
This is basically the same as Step 4 but brought out on the opposite side. It's very important that you pull the narrow end out on this side. This is the original side the narrow end started on.
Step 8: Pull Around the Front
Pull your narrow end around the front
Step 9: Pull the Narrow End Up
Pull the narrow end up around the back
Step 10: Windsor It!
If you're familiar with tying windsor knots then you know what's going on here, but if not, then you need to put the narrow end down through the front in the loop you just made by going around the front in Step 8.
Step 11: Tighten Up!
Pull the narrow end down more and tighten it up a little bit. Don't make it too tight though as you will have to fiddle with it later.
Step 12: Do the Twist
Twist the narrow end around behind the wider end to the left. This is a VERY important step. Your goal is to make sure the wider end is in the front like on most ties.
Step 13: Wrap It Up
Once you twist the narrow end around the wider end, then you start bringing the narrow end up and over your knot. Come from behind and start arching towards the middle
Step 14: It's Tricky
This is where the difficulty begins and ends. You're going to need to push the narrow end through the loop right above the knot you just created. Take your triangular knot and loosen up the piece that goes through the top.
Step 15: Keep It Concealed
Once you figure out the conundrum that Step 14 is and pull the narrow end through the piece at the top you just loosened up; you're just about done. Now you have to take the narrow bit you have left and put it behind the part of the tie wrapped around your neck.
Step 16: Pose for the Frame!
Now with some slight readjusting pull your collar down and show off your necksterpiece (neck + masterpiece).
    • Trash to Treasure
      Trash to Treasure
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    3 Comments
    did this for prom, love the knot
    I never heard of a Trinity Knot, where did you learn about this type of knot? It looks very unique, I like it!
    I learned about it from a guy named Alex Krasny on youtube
