3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to tie various knots
Knots, as a way of joining rope without special equipment, are useful in many situations. On a sailboat, knots are essential both for daily use and for emergency repairs. This instructable describes several different common knots:, e.g.
Sheet Bend - to tie two lines together
Bowline - to make a loop
Reef Knot - to fasten a bundle of material
Fishermans Bend - to secure a line to a post or ring
These knots are good for regular rope - braided or 3-strand polyester or natural fibre (hemp, sisal). Monofilament (fishing line) or steel cable performs better with different knots.
Knots are typically quite a lot weaker than straight rope - when rope goes around a tight radius, such as in a knot, the outside is under more tension than the inside. Splices (which require special tools, and are time-consuming to make) are stronger, so permanent fittings usually have eye-splices
Step 1Sheet Bend
Sheet Bend
The sheet bend is used to tie two lines together. It is perhaps the most generally useful knot of all. When used to tie a line to itself, making a loop, it is called a bowline.
The strain is taken on the ropes in the middle - not the one coming out the side.
How the knot is made is not critical - it is the final shape that is important. One can make the flat loop first, and work the other rope around it. Or one can make the crossed loop first - required when tying a bowline.
The two images show front and back views of the same knot
Advantages:
Easy to make
Easy to undo when tension is removed
Does not easily capsize
Disadvantages:
Hard to make under load
Dangerous to make under heavy load
Uses:
Joining two equally-sized ropes
Extending a towline or stern line
Method 1: the same as a bowline
Method 2: starting with the flat loop
58 comments
1-40 of 58next »
Apr 2, 2012. 6:10 AMtigerbomb8 says:
speaking about knots.....
http://www.youtube.com/watch?v=aMxcAaR0oHU
May 23, 2010. 3:53 AMsellulose says:
Please could you post a video for this one and for all the other knots without videos. Its will make it so easy to learn.
I totally did not understand this one.
Jul 12, 2011. 2:56 PMdurgledoggy says:
Well, the simplest way to explain it is to first master the fisherman's bend.
Make a fisherman's bend but only with the first half hitch (you know through the round turn). You then take the end of the rope you are working with back through in the opposite direction of only one loop of the round turn. If you take it through both it will undo the half hitch you just made as you are going back in the opposite direction to the first half hitch.
The underside of the knot should look like the second picture on this page shows you. The first picture is not that helpful.
That is terrible as an explanation but the only one offered in over a year. Hope it helps a bit.
Sep 11, 2009. 7:13 PMbig al psyches1048 says:
when i clicked onto this comment site, i got the we have a 'be nice' comment policy statement so i'm going to slip and slide on the side of political correctness.
When a rope has a splice formed at its end, again stronger and more permanent than a loop or bight, that is called an 'eye splice' !
when two ropes are joined making an open splice, and used to apply equal 'sideways' pressure from the directions of the newly formed ropes 'new ends' the pull exerted 'closes' the splice against the bullard,pin,spike,or cleat
-- said splice is technically called a c*nt splice, and was listed along with
instructions to make it in both the midshipmans manuals, and blue jackets
manuals,at least until just before WW 1 ! !
Jun 14, 2011. 2:38 PMRabidAlien says:
Good info on splices! One trick I picked up as a lifeguard in the Boy Scouts (aeons ago, now) was to take a two-foot length of three-strand hemp rope (or something thereabouts, just not too short and not plastic), put about six or eight inches of end-splice on one end for a handle. On the other end, start the same thing, but after tying the crown knot to hold the un-twisted ends in place, leave the three strands free and start to untwist the individual strands until you have a nice fuzzy "mess" hanging. Grab the spliced handle, and the fluffy part makes for a very excellent fly-swatter, an essential tool for anyone sitting still for hours on end in horsefly country. Everyone had one, and everyone loved em...until some idiot tried to cat-o-nine tail the wrong person with it, and ended up in the deep end. The individual threads on the fly end are strong enough to stand up to several weeks' worth of fairly frequent use, yet limber enough that you don't feel like your whacking yourself with heavy-gage wire.
Mar 27, 2011. 1:26 PMdurgledoggy says:
This needs a video methinks. I could do it, but my method is still a bit sloppy and "not pretty".
Apr 30, 2010. 1:25 AMibcallus says:
Very well explained thank you very much,
ibcallus
Apr 19, 2010. 8:21 AMrspetersga says:
I'm not understanding how to tie this knot from the pictures.........
Apr 26, 2010. 3:09 AMpaulzer02 says:
The looped end of the rope is passed through the double loop far enough to open it up enough to  pass the whole of the rest of the knot back through it, which effectively puts it on the other side of the free ends of the rope. It is then pulled back through the double loop to tighten the knot.
Apr 26, 2010. 6:49 AMrspetersga says:
(dope slap to forehead) I call myself trying that and it not working, but tried again with your instructions and it did.
Thanks for pointing out the obvious!
Sep 20, 2009. 1:23 PMcbrown222 says:
sheet bends are for joining two ropes of different thicknesses
Apr 18, 2010. 9:12 PMmystikmunkee says:
That they are, and reef knots are for tying ropes of equal thicknesses. Great Instructable though !
Apr 19, 2010. 7:11 PMpmartel says:
Well, the sheet bend can be used for rope of the same thickness.  The reef knot can come apart (capsize) under tension and so should not be used, for instance, to tie together two ropes you are planning to climb.
Apr 19, 2010. 7:42 AMrspetersga says:
This knot (at least used to be) taught in the boy scouts, to be used for rescuing people - the rope goes around the waist and the knot tied in front.  This knot is good for this application since the knot doesn't travel (and therefore the loop won't tighten around the person) and the knot gets more secure with tension.
Apr 19, 2010. 6:38 AMrabidpotatochip says:
Great instructable!  It coincides nicely with my new ropework hobby.  Your pictures look a lot better than the ones from the 1800's manual I've been working with. hehe
Apr 18, 2010. 8:19 AMNathan_ says:
 Bends connect two ropes. Isn't this a hitch?
Apr 18, 2010. 6:13 PMGeeDeeKay says:
[Respectfully] A hitch is used to attach a rope to a fixed object, a bend is used to join two lines, and a knot is a general term used to describe some sort of line or cord bound into some sort of configuration. Bends and hitches are both knots. Stoppers are knots. A tangled mass of line is a knot. All bends, hitches and stoppers are knots, but not all knots are bends, hitches or stoppers.
Apr 18, 2010. 8:07 PMNathan_ says:
 So yes, it is a hitch and not a bend?
Apr 19, 2010. 4:35 AMGeeDeeKay says:
Technically, yes, although it seems to be known as the fisherman's bend. This knot might have had another life in the past, attaching a fishing line to another line or leader. The name could also refer to the part of the knot that differentiates it from a round turn & 2 half hitches.
The term bend can also refer to a part of a knot. For example, a bowline is made up of a loop and a bend. A bend in this case is a turn in a piece of line that doesn't cross over itself, whereas a loop crosses over itself.
The arcana of knot lore hides a lot of the details of why knots got the names they have...
Apr 19, 2010. 3:29 AMdraghi says:
A lot of these knots have to be learned by scouts (I'm not talking about "boy scouts" because I'm Australian ergo i don't know what they need to learn)! BTW Great instructable.
Apr 18, 2010. 6:32 AMMowinTheLawn says:
Truckie's Hitch? Australian term...
I think that's also what jlhuge is referring to... It's a great knot, I have never had the chance to learn it though!
Apr 18, 2010. 8:36 AMgreatpanda says:
 You're probably looking for what's actually a "bell-ringer's hitch" formed in the bight  and used as a tackle.  It's 1/2 of a sheepshank, if that helps.  Also known as a trucker's hitch (there's an ible for it), taut-line hitch, or lorry knot it's most often used with a loop knot in the middle of a rope being used to bind a load.  Unfortunately, if a loop knot is tied, as previously mentioned the rope is weakened at that point, and the end of the rope must be fed through (reeved) the loop- tedious with long rope.  The sheepshank version (couldn't find a decent link, sorry) allows you to make a trucker's hitch in the middle of the rope.
Apr 18, 2010. 3:25 PMMowinTheLawn says:
Thank you so much! =]
It's nice for someone to bring it all together!
and I'll now go searching, armed with the keywords you've given.
Thanks s much once again. =D
Sep 14, 2009. 12:29 PMTechnologic says:
Those are great, but can you teach me how to tie my shoes?
Apr 18, 2010. 10:35 AMcateddy says:
http://video.search.yahoo.com/search/video;_ylt=ArC8uWTdZC3JO3Z9lx6uRcibvZx4?p=how+to+tie+shoes&toggle=1&cop=mss&ei=UTF-8&fr=yfp-t-892
Tech. Maybe this link will help with you. It show you how to tie shoes. Chuck
Apr 18, 2010. 10:29 AMsolo.card says:
 Bowline and Figure 8 can also be used for tying in to a harness, for climbing purposed,
Apr 18, 2010. 7:49 AMndinitz says:
 Another useful knot is the Fisherman's knot.
It joins two pieces of fishing line in a low profile knot which is very secure.
Oct 26, 2009. 7:30 PMandrocinco says:
very usefull!!
Oct 11, 2009. 8:47 PMsukinmaru says:
how about a noose? :D
Sep 22, 2009. 12:08 PMattilas says:
bravo ! i nodi soni cose molto e sempre utili , perche' non ne fanno materia anche per le scuole ?
Sep 18, 2009. 8:51 AMseamountie says:
Sorry Adaveil, but you have laid up the Carrick Bend incorrectly. Have a look at the photo here ( http://www.uspowerboating.com/images-knots/carrick-bend.jpg ) for the what a Carrick looks like before you pull it to.
Sep 17, 2009. 12:06 PMstatic says:
Oddly enough most of the knots shown here can be found illustrated in my Websters print dictionary under knot. On the web somewhere there is an animated knots page, where you can slow down the animation speed to suite yourself.
Sep 13, 2009. 9:48 PMberky93 says:
I like the idea of that prussic knot. Ill have to try climbing something (small, with a harness) sometime. I know I have some climbing rope around here somewhere...
Sep 12, 2009. 8:41 PMGage987 says:
Noose
Sep 8, 2009. 9:50 PMpancho del rancho says:
now we can hang stuff(like um sesame street that bid bird gets on my nerves)foo
Sep 12, 2009. 11:43 AMharley_rly says:
with a noose, which is relatively easy to make(my older brother taught me how to make one when i was 6 lol...and still havent forgot, and its been 8 years)
Sep 12, 2009. 5:02 AMgreeenpro says:
Thanks for a great reference guide here. I will be using the info. in this!
Sep 11, 2009. 2:44 PMJohnnyPgood says:
Great ible! I was just surfing wikipedia the other day learning some of these! :thumbsup:
1-40 of 58next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
36
Author:adaviel
