loading
Step 1: Sheet Bend
The sheet bend is used to tie two lines together. It is perhaps the most generally useful knot of all. When used to tie a line to itself, making a loop, it is called a bowline.
The strain is taken on the ropes in the middle - not the one coming out the side.
How the knot is made is not critical - it is the final shape that is important. One can make the flat loop first, and work the other rope around it. Or one can make the crossed loop first - required when tying a bowline.
The two images show front and back views of the same knot
Advantages:
Easy to make
Easy to undo when tension is removed
Does not easily capsize
Disadvantages:
Hard to make under load
Dangerous to make under heavy load
Uses:
Joining two equally-sized ropes
Extending a towline or stern line
Method 1: the same as a bowline
Method 2: starting with the flat loop
hi <br>I am a boy scout. <br>Scouts love. <br>I live in Iran.
I was looking for this... <br>Thanks <br>Very useful!!
speaking about knots.....<br><br>http://www.youtube.com/watch?v=aMxcAaR0oHU
when i clicked onto this comment site, i got the <em> we have a 'be nice' comment policy </em> statement so i'm going to slip and slide on the side of political correctness. <br/><br/> When a rope has a splice formed at its end, again stronger and more permanent than a loop or bight, that is called an 'eye splice' ! <br/><br/> when two ropes are joined making an open splice, and used to apply equal 'sideways' pressure from the directions of the newly formed ropes 'new ends' the pull exerted 'closes' the splice against the bullard,pin,spike,or cleat<br/>-- said splice is technically called a c*nt splice, and was listed along with <br/>instructions to make it in both the midshipmans manuals, and blue jackets<br/>manuals,at least until just before WW 1 ! !<br/><br/>
Good info on splices! One trick I picked up as a lifeguard in the Boy Scouts (aeons ago, now) was to take a two-foot length of three-strand hemp rope (or something thereabouts, just not too short and not plastic), put about six or eight inches of end-splice on one end for a handle. On the other end, start the same thing, but after tying the crown knot to hold the un-twisted ends in place, leave the three strands free and start to untwist the individual strands until you have a nice fuzzy &quot;mess&quot; hanging. Grab the spliced handle, and the fluffy part makes for a very excellent fly-swatter, an essential tool for anyone sitting still for hours on end in horsefly country. Everyone had one, and everyone loved em...until some idiot tried to cat-o-nine tail the wrong person with it, and ended up in the deep end. The individual threads on the fly end are strong enough to stand up to several weeks' worth of fairly frequent use, yet limber enough that you don't feel like your whacking yourself with heavy-gage wire.
Please could you post a video for this one and for all the other knots without videos. Its will make it so easy to learn.<br /> <br /> I totally did not understand this one.<br />
<p>Very well explained thank you very much,<br /> ibcallus</p>
I'm not understanding how to tie this knot from the pictures.........<br />
The looped end of the rope is passed through the double loop far enough to open it up enough to&nbsp; pass the whole of the rest of the knot back through it, which effectively puts it on the other side of the free ends of the rope. It is then pulled back through the double loop to tighten the knot.<br />
(dope slap to forehead) I call myself trying that and it not working, but tried again with your instructions and it did.<br /> <br /> Thanks for pointing out the obvious!<br />
sheet bends are for joining two ropes of different thicknesses
That they are, and reef knots are for tying ropes of equal thicknesses. Great Instructable though !
Well, the sheet bend <em>can</em> be used for rope of the same thickness.&nbsp; The reef knot can come apart (capsize) under tension and so should <strong>not</strong>&nbsp;be used, for instance, to&nbsp;tie together two ropes you are planning to climb.
This knot (at least used to be) taught in the boy scouts, to be used for rescuing people - the rope goes around the waist and the knot tied in front.&nbsp; This knot is good for this application since the knot doesn't travel (and therefore the loop won't tighten around the person) and the knot gets more secure with tension.<br />
Great instructable!&nbsp; It coincides nicely with my new ropework hobby.&nbsp; Your pictures look a lot better than the ones from the 1800's manual I've been working with. hehe<br />
&nbsp;Bends connect two ropes. Isn't this a hitch?
[Respectfully] A&nbsp;hitch is used to attach a rope to a fixed object, a bend is used to join two lines, and a knot is a general term used to describe some sort of line or cord bound into some sort of configuration. Bends and hitches are both knots. Stoppers are knots. A&nbsp;tangled mass of line is a knot. All bends, hitches and stoppers are knots, but not all knots are bends, hitches or stoppers.
&nbsp;So yes, it is a hitch and not a bend?
Technically, yes, although it seems to be known as the fisherman's bend. This knot might have had another life in the past, attaching a fishing line to another line or leader. The name could also refer to the part of the knot that differentiates it from a round turn &amp;&nbsp;2 half hitches. <br /> <br /> The term bend can also refer to a part of a knot. For example, a bowline is made up of a loop and a bend. A&nbsp;bend in this case is a turn in a piece of line that doesn't cross over itself, whereas a loop crosses over itself. <br /> <br /> The arcana of knot lore hides a lot of the details of why knots got the names they have...<br />
A lot of these knots have to be learned by scouts (I'm not talking about &quot;boy scouts&quot; because I'm Australian ergo i don't know what they need to learn)! BTW Great instructable.<br />
Truckie's Hitch? Australian term...<br /> I think that's also what jlhuge is referring to... It's a great knot, I have never had the chance to learn it though!<br />
&nbsp;You're probably looking for what's actually a &quot;bell-ringer's hitch&quot; formed in the bight &nbsp;and used as a tackle. &nbsp;It's 1/2 of a sheepshank, if that helps. &nbsp;Also known as a trucker's hitch (there's an ible for it), taut-line hitch, or lorry knot it's most often used with a loop knot in the middle of a rope being used to bind a load. &nbsp;Unfortunately, if a loop knot is tied, as previously mentioned the rope is weakened at that point, and the end of the rope must be fed through (reeved) the loop- tedious with long rope. &nbsp;The sheepshank version (couldn't find a decent link, sorry) allows you to make a trucker's hitch in the middle of the rope.<br /> <br /> <br />
Thank you so much! =]<br /> It's nice for someone to bring it all together!<br /> and I'll now go searching, armed with the keywords you've given. <br /> Thanks s much once again. =D&nbsp;
Those are great, but can you teach me how to tie my shoes?<br/><sup></sup><br/>
http://video.search.yahoo.com/search/video;_ylt=ArC8uWTdZC3JO3Z9lx6uRcibvZx4?p=how+to+tie+shoes&amp;toggle=1&amp;cop=mss&amp;ei=UTF-8&amp;fr=yfp-t-892<br /> <br /> Tech. Maybe this link will help with you. It show you how to tie shoes. Chuck<br /> <br />
&nbsp;Bowline and Figure 8 can also be used for tying in to a harness, for climbing purposed,&nbsp;<br /> <br /> :)<br />
&nbsp;Another useful knot is the Fisherman's knot.<br /> <br /> It joins two pieces of fishing line in a low profile knot which is very secure.<br /> <br /> <br /> <br />
very usefull!!<br />
how about a noose? :D
bravo ! i nodi soni cose molto e sempre utili , perche' non ne fanno materia anche per le scuole ?
Sorry Adaveil, but you have laid up the Carrick Bend incorrectly. Have a look at the photo here ( <a rel="nofollow" href="http://www.uspowerboating.com/images-knots/carrick-bend.jpg">http://www.uspowerboating.com/images-knots/carrick-bend.jpg</a> ) for the what a Carrick looks like before you pull it to.<br/>
Thanks for pointing this out. I have deleted the step. It's not one I use much and I mis-copied it.
Oddly enough most of the knots shown here can be found illustrated in my Websters print dictionary under knot. On the web somewhere there is an animated knots page, where you can slow down the animation speed to suite yourself.
I confess I didn't check what other material was already out there - I had some time to kill while sailing home, with a camcorder and lots of rope lying around. I had someone shoot over my shoulder so the camera would see my hands the same way round as I did.
I like the idea of that prussic knot. Ill have to try climbing something (small, with a harness) sometime. I know I have some climbing rope around here somewhere...
Noose
now we can hang stuff(like um sesame street that bid bird gets on my nerves)foo
with a noose, which is relatively easy to make(my older brother taught me how to make one when i was 6 lol...and still havent forgot, and its been 8 years)
Thanks for a great reference guide here. I will be using the info. in this!
Great ible! I was just surfing wikipedia the other day learning some of these! :thumbsup:
Splices require special tools? I haven't done many but I've never used a tool for it. The Boy Scout Handbook gives some instructions for eye splices, end splices, and short splices.
A fid is handy, or marlinspike. There's one in my sailing knife. I guess you can open 3-strand with just your fingers though.
I like that you have a behind the back example. When I was learning knots in school we all had to learn to tie every knot behind our backs. For an added challenge we also had to work in pairs, each using only one hand.
Notice I fluffed it at first .. I had a bit of "caterpillar syndrome" - mostly in outtakes, but thinking about how to do it made it harder. The only one I can do dead-on every time is the figure-8.
The Carrick Bend's strength is in bending dissimilar lines but instead of keeping its pretty layout you can let it collapse, the lines can be loosened easily.
yeah the second video method is the one I'm used to tying
I need a knot that connects a rope to a fixed loop of metal or hook, and does three things: #1: When it's tied, it designed to tie down tight, leaving no slack in the load-bearing portion of rope. #2: It unties quickly and easily. Anyone know a knot like that?
Try looking up "Highwayman's Hitch"
This is a great introduction to many key knots. I'm a knot lover, and if you are serious about learning this old art, I'd recommend the "Ashley Book of Knots" by Clifford Ashley. It is the encyclopedia of knot know-how.
I'm sure plenty of people will add their favorite knots but I'd like to suggest the <a rel="nofollow" href="http://www.netknots.com/html/truckers_hitch.html">Trucker's Hitch</a> and the <a rel="nofollow" href="http://www.netknots.com/html/tautline_hitch.html">Tautline Hitch</a>. In my life, where I don't use knots that frequently but rather time to time for many various situations, I'd put the trucker's and tautline hitch third and fourth behind the bowline and the (usually double) sheet bend. Which, you as you pointed out, is really the same knot. Securing a load always sucks unless a trucker's hitch is used in which case it's always quite secure. And I don't know how anyone goes camping without a tautline hitch. I also use the tautline hitch to secure inflatable decorations around halloween and christmass. Two invaluable knots.<br/>
About This Instructable
166,006views
969favorites
License:
More by adaviel:Multi-Input Electric Vehicle Charging Station Cargo Cover for Nissan Leaf Lightweight solar panel (12V battery charger)
Add instructable to:
